RCC NGC2244 - Request for Critique
12 replies431 views
Mike Patrick avatar
Hello -
I'm new to astrophotography, and I'd appreciate any critique you'd like to give on this image of NGC2244. Thanks in advance for any help you can provide!
Peter Robertson avatar
I am also new, but I think this looks amazing. Congratulations.
Dynamic range looks good, colors are nice, balance of clarity and nebulosity looks good. Was it cropped much, stars look round but do have a slightly "stick on top" look that I also struggle with. But great image I'd be very happy.
Maybe tell us a bit about the exposure and gear.
Ian McIntyre avatar
Not sure what constitutes "new" to you. I am 7 months into it (nothing the last 3 due to weather) and feel like I am years from creating anything with this depth and detail.
kuechlew avatar
Hi, very nice image indeed. A tip from beginner to beginner: I find it worthwhile to double check via the Astrobin search function what results other users achieved for the same object - preferably with a similar integration time and similar equipment. You'll find an abundance of great examples for Rosette Nebula, even limiting the search for the top picks yields more than one page of results: Search - AstroBin
A quick glance reveals that the top picks do a little bit better to control the "star bloat" which is always a problem (to me at least) when you have a combination of a nebula and bright stars. But that's nit picking.
Have fun and clear skies
Wolfgang
Helpful Respectful Supportive
Steven avatar
Can't see anything "wrong" with the image.  Colours look good, nice balance of SHO, stars are round, not a lot of noise.
Any things that I would change are more personal preference than issues with the image.
Perhaps you could describe if there is anything you're not happy with? so people could provide better critique.
Also maybe list things like camera, scope, integration time, software used, etc, etc.
The only things I would change
- is to make the stars smaller/dimmer. This would pull more focus into the nebula.
- I would personally go for a little more contrast and sharpening in the nebula itself, to try and pull out the darker details and dust.
- If possible I would change the crop, I would try and shoot in a way to get the entire nebula in the frame, but this is obviously depending on your equipment and focal length, it's not always something that can easily be changed. (So this point is only valid if you cropped the image at all)
Again, these things are personal preferences.
Mike Patrick avatar
Thanks so much for your reply Steven. I’m happy with the image, but I’m so new to this that it’s one of those “I don’t know what I don’t know” things. This is my second attempt at taking a shot of a deep space target, so I was just looking for feedback. Thank you for your comments, I really appreciate it!
Mike Patrick avatar
Thank you kuechlew for your comments.  I did do the search you mentioned, but found very few examples for the scope and camera combination I’m using.  I really appreciate your feedback. Thanks.
Mike Patrick avatar
Thanks for your comment Ian. This is my second attempt at shooting a target, so I think I'm pretty new. I was following the suggestion here at Astrobin to get opinions from those who have been doing this for awhile. I think this is invaluable and is helping me to learn what I don't know. Thanks again for your comment!
Mike Patrick avatar
Thanks for your comments Peter. I'm using a William Optics Zenithstar73 with an Ioptron CEM26 mount and a ZWO ASI183GT monochrome camera. Thanks so much for your comments! The image was barely cropped, taking off just a very narrow artifact band at the top. I used a .8 reducer to try to capture as much of the nebula as possible. I might shoot a mosaic next time to try and capture the entire nebula. This is a 27.5 hour exposure using HA, SII, and OIII filters from ZWO. Thanks again for your comments!
Helpful Respectful
Tim Hutchison avatar
Hi Mike.
First, let me start by saying that this is an extremely good job for a second DSO image. You are certainly well on your way and doing the right things to improve by asking for feedback.
All of my feedback is aimed at providing positive guidance to you as others did for me. Please don't take any of this as criticism.
On a technical note, the stars in the lower right corner seem to be slightly elongated. You can use something like ASTAP or other tools to check for sensor tilt. It may be worth evaluating. It's not terrible, but, as I say, may be worth looking at.
Two processing notes…
The image looks a little bit bright, and as a result, looks flat. Try using HDRMultiscaleTransform and then LocalHistogramEqualization. These two tools will help to reduce brightness and increase edge contrast and will add some depth and texture to the image. Be careful with them. A light touch is always better. These are easy to over do, especially LHE.
Also, I notice that you've removed all of the green from the image, probably with SCNR.  While I realize there are lots of folks out there that tell you this is what you should do (and is what I started off doing) for Hubble palette images, IMHO this is completely incorrect. If we only wanted two colors in our images we'd only shoot with two filters. You need green to be able to realize the broad range of colors possible with three different channels. Instead of removing green, what I think you should strive for is balancing the red and blue channels with the green channel (since Ha is so dominant). Balancing the the channels is the key! There are lots of techniques for doing this. DM me if you are interested in exploring some techniques.
It seems like you ARE doing the right thing with stars. But just to mention it, tonemapping the image to process the nebula and adding in the stars back later is (my opinion) the right move. I think you are doing that based on how your stars look, but if this is new news to you let me know. I can help with some direction.
Lots of folks helped me improve. If I can pay it forward I'm happy to. Feel free to reach out if I can help.
Again, great job for a second attempt!
Tim
Mike Patrick avatar
Tim - thank you so much for your critique. These are exactly the type of points I was looking for.  After review I came to some of the same conclusions you did regarding brightness and the stars. I'm thinking of reprocessing, and I'll attempt to use some of your suggestions. Thanks again for the feedback, and I may take you up on your offer for clarification on the tools you mention, since I haven't used some of them. One point I'm particularly interested in is your mention of "sensor tilt."  I was thinking it might be related to the flattener/reducer, but I'm so new to this I wasn't sure. I'll research this. Thanks again Tim!
Mike Patrick:
I probably should have said that better...What I meant was that something in the imaging train MAY have your camera sensor slightly out of square with the light path.  It could be coming from anywhere.  The only way that I know to fix it is with tiny "shims" that can be used to square up the camera.  Not a trivial task, but not real complicated either. ASTAP or CCDInspector can look at a single sub and show you if your sensor is out of square.  Easy to diagnose, typically very hard to attribute to one thing in the imaging train, but can be solved by shimming (if you're not using a rotator that is).
Also, it may be that it's so slight that it isn't worth messing with.  (With my setup it was so small that I said "The heck with it...")
Tim
Mike Patrick avatar
OK thanks Tim. I really appreciate the feedback. It's great to know there are others out there who will take the time to help those seeking it, as that really is the fastest and best way to improve. Thanks again!
[RCC] How to make a picture more "catchy"?
Hello, I am wondering how some images get more attention than others - are there some basic rules for making a picture more "catchy"? Following example here: https://www.astrobin.com/1j53nc/ While this picture was processed in a decent way,...
Discusses making images more visually appealing; relevant to improving astrophotography presentation.
Sep 13, 2023
[RCC] The Andromeda Galaxy
Hello everyone, I am still new to Astrophotography and still learning how to process images. I started to learn PixInsight about 3 weeks ago. I paid for the 3 RC Astro plug-ins. NoiseX, BlurX, and StarX. This was my 3rd try at processing Andromeda wi...
Another beginner learning astrophotography image processing; similar experience level and goals.
Nov 11, 2023
First Astrophotography Setup
Hello fellow astrophotographers! I am excited to venture into the world of astrophotography and have been diligently researching and assembling my first setup. I have some prior experience with photography using a Nikon DSLR, but now I'm eager to...
First astrophotography setup guide; relevant for newcomers starting their astrophotography journey.
Jul 25, 2023
(RCC) Why my capture is not enough good ?
hello everyone, last week I created an image that I call my best photo. https://www.astrobin.com/uz9nkv/ This one only had two positive votes from the judges. As it is an area that is rarely photographed and I spent 11.5 hours capturing it @F2 , I am...
Beginner seeking critique on astrophotography images; similar request for feedback.
Jan 15, 2024
Feedback on my latest images
Hey guys, inspired by Chris thread https://www.astrobin.com/forum/c/astrophotography/critique-requests/rcc-how-to-make-a-picture-more-catchy/ I would like to ask you what I could do and work on to get "better" astrophotos. i am a few years ...
Beginner sharing images for feedback; directly relevant to critique requests.
Sep 14, 2023
