Optimizing LRGB workflow and processing approach in Siril
3 replies63 views
Claudio Pedrazzi avatar
Hello everyone,
this is my first post here, I hope it is appropriate.
I am still trying to find a solid and repeatable LRGB workflow in Siril, and I would like to ask whether my current approach makes sense, or whether I am overcomplicating it and introducing unnecessary sources of error.
At the moment, my workflow is roughly this:
  1. I start from the raw stacked masters for L, R, G, and B.
  2. I use RGB Composition on the raw L, R, G, B masters, with alignment enabled, so that all channels are registered consistently.
  3. I then take the aligned luminance master and process it separately. This usually includes background extraction, denoising, aberration removal, sharpening, and then stretching.
  4. Separately, I compose an RGB image from the (aligned before) R, G, and B masters only, without luminance.
  5. On this RGB image, I perform plate solving and then (S)PCC.
  6. After that, I process the RGB image, again with operations such as background extraction, denoising, aberration removal, mild sharpening, and stretching, usually less aggressively than for luminance.
  7. I then split the stretched RGB image back into its R, G, and B channels.
  8. Finally, I recombine the processed/stretched luminance and the processed/stretched R, G, B channels into a final LRGB image.
So, in short, I process luminance and RGB separately, and only at the end I recombine them.
My doubts are these:
  • Is this workflow conceptually correct?
  • Is splitting the already processed RGB image back into channels and recomposing with L a reasonable approach, or is it a sign that I am doing something in a clumsy way?
  • Is there a better / simpler / more robust way to build an LRGB image in Siril?
  • Could this workflow itself be one of the reasons why my final LRGB results often look somewhat washed out compared to the standalone RGB?
What worries me is that this workflow feels quite heavy and error-prone. There are many steps, many intermediate files, and many opportunities to make inconsistent choices between the luminance branch and the RGB branch.
Also, my final L+RGB recombinations are often less vivid than I expect: the result is usually smoother and more detailed, but also somewhat desaturated or “flat”. I am not sure whether this comes from my processing choices, from stretching L and RGB independently, or from the recombination method itself.
I would be very interested to know whether this is a sound workflow, or whether more experienced users would recommend a different strategy.
Thanks a lot.
Well written Helpful Respectful Engaging
There isn’t a super simple way to do LRGB in Siril. I used to do what you pretty much do with one exception. I would do LRGB combination to get everything aligned and then for the RGB plate I wouldn’t include the L. I’ve found that the result, even if you include a very well processed L really doesn’t give a great result.
Once I took the basic RGB, L and star plates as far as I could in Siril, it was time to go to a layer based photo editor to do the rest. I use Affinity to make final adjustments on all three plates. I would also use it to bring in the L plate as luminance into the RGB plate and to screen the stars back in and then any final adjustments as needed. Bottom line is I would not consider the result out of Siril to be finished at all. It’s the work in Affinity that really is the polish on the process.
I work in PI now which is wonderful for dealing with heaps of data from different filters and different nights but, I still bring the 3 plates out to Affinity to complete.
Hope that helps!
Thank you, this is very helpful.
It is reassuring to hear that the issue is not just my workflow, but also the fact that Siril does not seem to make the final LRGB combination especially easy or refined.
I forgot to mention that I also use Affinity, so your comments are very relevant to me. My impression so far is exactly that: Siril can take L, RGB and stars quite far, but the final polish seems much easier in a layer-based editor.
One point is still not fully clear to me: when you mention working with RGB, L and a separate star plate, where do those stars come from exactly? Do you usually extract the stars from the RGB image, from the luminance, or from some temporary LRGB combination before moving to Affinity?
Also, before moving to Affinity, did you usually stretch L and RGB independently (I think this is necessary, but I always doubt the correct amount of stretching)?
You could take the stars from any filter but I generally take them from the RGB plate before stretching. Just extract using starnet++ and stretch. I like to use AsinH Transformation for this as it preserves the colors better. Once you have it where you want it, save as a 16bit GIF and it’s ready to be screened in via Affinity.
On the L and RGB plates, yes, those should be stretched with everything else done that you can do in Siril before finishing up in the editor. Affinity has some excellent sharpening and noise reduction tools that are available when you go into development area. These are very useful for putting that final polish on the L frame.
Well written Helpful Respectful Concise Engaging
Pixinsight Help - Processing OSC data plus mono camera Luminance data
Hello, I recently acquired a mono 533mc camera. I captured luminance data on ngc 7331 with a uv-ir filter. I already owned a 533mc color camera and had some OSC data on the same target. I want to add the luminance data to my OSC dataset to improve th...
LRGB workflow with mono luminance data directly relevant to author's question.
Sep 1, 2025
[RCC] Galaxy post processing M101
Request you to provide your critique - It is my first attempt to post-process galaxy data. I obtained the data from TAIC workshop. The LRGB subs were already stacked and registered, even cropped to good extent. I proceeded with these steps, providing...
LRGB post-processing workflow example with practical processing steps.
Aug 19, 2025
The How and Why of Superluminance
I am hoping to tap into the Astrobin braintrust. I regularly collect substantial amounts of RGB and Luminance data. I equally regularly replace the lightness component of my RGB images with the Luminance data. If I run 10 hours of each of RGB and L, ...
RGB and Luminance data processing techniques applicable to LRGB work.
Mar 7, 2026
