using two different setups with different resolutions
3 replies142 views
Alex Penzias avatar
Hi to everyone,
there is a lot to read about it and I still have a lot of research to do on my own here, but I would still like to ask this question to our lovely community.
I am currently using an upgraded SW 150 pds with a newly installed Touptek ATR2600m with filter wheel on a Proxisky UMi 20s. I am really happy with this setup now but due to my limited fov at home I can only image the western part of the sky. My maximum imaging time for an object per night is approx. three hours when it becomes visible to me until it sets behind the building opposite of me.
Now I am beginning to ask myself the question, if I could mount an Askar SQA55 with my trusted 533mc onto my SW 150 pds and use both setups in tandem, weightwise this should be no problem for the mount. The fov of both setups, SQA55+533mc and 150pds+ATR2600m, is actually somewhat similar, however the resolution is different due to the different focal lengths of the scopes - 2,94”/pixel vs 1,03”/pixel.
Would it make sense to use the SQA55+533mc for the RGB part of the image and to use the 150pds+ATR2600m for luminance (and/or Ha where possible) data? Would the lum image at a resolution of 1,03”/pixel bring the desired and current level of detail or would I be losing details in the image due to the RGB image having a resolution of 2,94”/pixel? The hope is that this would work and I could “double” my imaging time from my imaging location without having to make any larger changes.
Clear Skies to you all, I hope your local weather is better than mine here,
Alex
Rick Krejci avatar
It should work OK as long as you don’t have 2 setups with diffraction spikes, which you don’t. I did this quite a bit, but with FF and APSC on differing focal lengths and it works great with the longer focal length as luminance and shorter as chrominance. Here’s one I did like that: https://app.astrobin.com/u/Ricksastro?i=4a8kl2
For some targets, where Oiii isn’t very detailed, I’ve even done SHO, with SH from the longer focal length and Oiii from the shorter. Like these:
https://app.astrobin.com/u/Ricksastro?i=cjvmsx
https://app.astrobin.com/u/Ricksastro?i=89drnr
I use Nina, which allows running a session for each scope/camera on one PC and has synchronization features built-in, particularly dithering. Don’t think you can do that with ASIAirs.
Diffraction spikes won’t have their specific colours and so the halos but otherwise it should work.
Alex Penzias avatar
Thank you to both of you for your replies! I guess this’ll be my next project then. Due to the limited amount of time I can image this would make the available time more effective. And I have another way to continue to make my wallet cry!
@Rick Krejci thank you for showing me some of your images taken in this way. They look amazing!
Clear Skies to you,
Alex
Respectful Supportive
Newt to complement 80mm APO?
I currently image with a TS Optics 80mm APO (544mm, f/6.8) on a SkyWatcher Wave 150i, with a Touptek 533 and filter wheel. The image quality is great, but under Bortle 7–8 skies here in Ireland, the limited number of clear nights means f/6.8 forces m...
Similar telescope and camera setup; discusses complementary imaging approaches.
Oct 23, 2025
Combining dual telescope setup data for narrowband imaging efficiency (Mono Ha/OIII + OSC L-Extreme)
Good morning, For some time now, I have been experimenting with how to get the most out of my dual setup. Basically, I have the following instruments mounted in parallel on my mount, which capture the same subject synchronously: 1) A WO FLT 120 with ...
Directly relevant; addresses dual telescope setup optimization for narrowband imaging.
Oct 11, 2025
Imaging narrowband versus a 'darker' sky location.
Hi all, If I am imaging with 3nm filters (either mono or OSC) say from a Bortle 6 location - no moon (my garden). Would using the same filters/cameras in a Bortle 4 location provide much better data, worth travelling to…. or would it not be really as...
Relevant; discusses narrowband imaging strategies from limited sky access locations.
Oct 23, 2025
Dual-telescope rig: seeking advice and strategies
I live in an area of the world with seeing that is average on the best nights, non-existent on most. And those nights that are best tend to be extremely short summer nights at 48º north latitude. I am trying to create a rig to best utilize the few qu...
Relevant; addresses dual-telescope rig strategies for maximizing limited observing conditions.
Oct 30, 2025
