Struggling with gradient artifacts around stars in mosaic merge
2 replies41 views
Bruno Mendes avatar
Hello,
Im learning how to do mosaic but Ive been struggling quite a bit with the merge. I’m trying to follow the usual steps “ MosaicByCoordinates → dnalinearfit → GradientMergeMosaic”. I’ve tried to do merge with and without BE/Denoise and play around the settings but it seems that I keep getting this kind of gradient around the the stars (see image). Depending on the merge setting its stronger/weaker but its always there. Is there anything I’m missing or that I can do to improve the merge?
Kind Regards
Respectful
Alex Ranous avatar
Are you seeing the artifact in stars along the edge of one of the mosaic panels, or is it everywhere? I had issues with GradientMergeMosaic when a bright stars fell on the edge of one of the panels. Adjusting the crop can fix the issue, but if you have a dense star field, it can be a game of whack-a-mole. I recommend using PhotometricMosaic instead. I find it a lot more reliable than GradientMergeMosaic. It’s a third party plugin. The repository for it is https://pixinsight.astroprocessing.com/
Alex
Well Written Helpful Respectful Concise Engaging Supportive
Bruno Mendes avatar
Hello! That is exactly what is happening, some of my brightest stars are on the edge of the panels. I will check your recommendation thank you a lot.
Respectful
Strange grainy artifacts in background when applying NXT - normal or error?
Is this normal or am I doing something wrong? When I apply NXT, I get really strange grainy artifacts in the background. It looks like colored specs all over the image (see below). Doesn’t appear to matter whether I do NXT early in processing on line...
Grainy artifacts in background may relate to merge gradient issues.
Sep 29, 2025
