What do you do when PHD2 sees ghosts?
4 replies96 views
Rostokko avatar
I have been chasing a problem in my guiding for several hours yesterday night and tonight. I use an OAG with a SCT (C8); PHD2 (managed by NINA) is the brain.
The experienced problem was that, for a specific target, guiding would work well “in most cases”; but in some other cases - always after some NINA operation that stopped and restarted guiding - I would get a rapidly accelerating drift, as if PHD2 was guiding in the opposite direction (mostly RA).
I investigated the rotator; calibration; settings; nothing. I did notice that exposure time seemed to be correlated - shorter exposure times seemed less likely to trigger this behavior.
Finally, I saw it - and it explained everything. During a re-calibration attempt, I noticed all the stars in the field moving the opposite direction of the “star” locked for calibration; and it dawned on me: PHD2 was locking on a ghost, a reflection. You can see it here - a bit exaggerated with a longer exposure to see it well:
📷 image.pngimage.pngKnowing it’s a ghost, you can see hints that it is somewhat peculiar. But to PHD2 (and me, honestly) it was a reasonable star - for an OAG field in a SCT… HFD of 3.5, nice curve… but when the field moves down, that one moves up; when the field moves up, that one moves down; when the field goes right or left, that does go right or left as well… I don’t think this is caused by the moon - I guess I’ll know for sure in a couple of weeks; the moon is 45 degrees away tonight, and yesterday it was 60 away or so; more likely is a relatively bright star nearby.
I couldn’t come up with any way to fix that in PHD2; HFD of 3.5-4 is good for normal stars; it’s not a hot pixel - so, darks or BPM won’t help. My only workaround was to change my chosen framing rotation; I found one which is not my favorite, but the ghost is gone there.
It’s the first time I have seen something like this with this OAG (a Pegasus Indigo); has anyone else experienced similar problems? What did you do to address them? I was literally bumping my head against the wall, at some point. Should I even venture “chasing ghosts” by cleaning the OAG prism or what else?
Well Written Helpful Insightful Respectful Engaging
alpheratz06 avatar
Didn’t see that personnally, but I would chase if there are unwanted reflective surfaces on the edge of the optical path, especially in the OAG assembly or a bit up in the light path ?
Was the ghost visible on the imaging camera ?
When “ghosts” show up in the optical main path, it’s frequently a problem of unadapted baffling. It’s a known issue on some RC’s.
Rostokko avatar
alpheratz06 · Mar 31, 2026, 07:36 AM
…no, I couldn’t spot anything suspicious in the imaging camera - even if I can’t totally exclude that possibility.
oymd avatar
I had your same EXACT problem yesterday night while imaging M63, with the moon about 40 deg on the other side!
C8, 2600MC Pro with a ZWO OAG-L and 174MM Mini guide cam.
My first issue was PHD2 could not find or lock on to a guide star.
At 1280mm there are barely any stars around M63! I think the Moon had a big role in that, as it was flooding the sky with light, and the fainter stars were hard to be picked up by PHD2.
I had to manually stop guiding every few minutes and manually choose a guide star, but PHD2 would very soon loose the star…
I also started thinkg if I was choosing ghost stars….
The pleasures of imaging galaxies with SCTs and OAGs!!
Rostokko avatar
Yep, fewer stars in the OAG FOV (in part caused by the bright moon) were definitely a big part of the problem. I will definitely try the same position, same rotation angle in a weeks or so; my guess is that PHD2 may find more stars then and be shielded from problems, but I still expect to have the ghost visible; we’ll see - I will report back.
It is somewhat unfortunate that PHD2 abandons your manual selection on stopping/restarting guiding - especially considering it can easily check that the mount and rotation positions are about unchanged.
How to avoid guiding on reflections in the OAG within PHD2? (Gif of the issue included)
I have been having problems, especially when imaging on bright moon nights, where reflections on the OAG pickoff prism are causing significant deviations in guiding, where PHD2 locks on these reflections and the stars go 20-30 arc seconds in the oppo...
Both posts describe guiding failures where PHD2 appears to guide in the opposite direction, causing significant star drift during imaging sessions.
Mar 17, 2025
Lost lock
I have been having a problem lately that when there is the slightest breeze, PHD2 looses lock on the guide star. This is eating up a lot of time while it settles itself to start guiding again. Is there a setting to look at that can make it less sensi...
Both posts describe problems with PHD2 autoguiding losing or malfunctioning during observations, seeking solutions to improve guiding stability.
Jul 19, 2025
Problem with calibration PHD2
Hello to everyone, I'm writing here cause i have a problem with PHD2. My setup is composed: EQ3 OnStep (I know, it's a bad mount, i'm at the limit of paypload for astrophotography but i'm waiting the new mount) Tecnosky 72/432 FPL53 w...
Both posts describe troubleshooting issues with PHD2 guiding software in their astrophotography setups.
Aug 23, 2024
My Problem with PhD2
I've never been able to get PhD2 to work as it should. I know that it's me, not the program. For background, my setup is an MtY, TSX, N.I.N.A. and an Esprit 120mm. I've had reasonable success simply using the above equipment for up to thr...
Both posts describe difficulties achieving reliable autoguiding performance with PHD2 software in their astrophotography setups.
Jun 19, 2025
