My ASI6200mm is acting up again
9 replies216 views
Bruce Donzanti avatar
I had an issue last night in that a perfectly round black dot appeared on individual frames hours after the ASI6200mm had been running at its usual settings: 100 gain at -5 degrees with the dew heater on. It did not look like the oval-shape black dot one sees when there is dew on the camera windows that eventually dissipates. The scope lens was clear, and the black dot was not filter dependent. Sky conditions were fine: clear, 65 degrees with no significant humidity. What is really odd is that the black dot shifted positions in various exposures and in some cases, there were two less intense black dots. Early in the evening the black dot was not present in all exposures, but it was present, and darker, in the exposures starting at around 2:30 am (humidity around 94% but not unusual for this area). Finally, when I turned everything off and started it back up, I did not see the black dot on any exposures I took. I am assuming the camera (which I had ZWO repair a few months ago for a bad board) is the culprit, but I am tossing it out here to seek other opinions.
Here is a screen shot of the last exposure.
Note: I just received a response from the ZWO US service center who replaced the main board back in November. They are not sure what this issue is but suggested to have the sensor board replaced.
SonnyE avatar
That looks like a significant problem to me. If it is still under warranty I’d get it back to ZWO US Service.
It does sound odd that A. It moves. and B. It went away when you cycled the power.
Good luck with it. If it were me, and out of warranty, I’d be shopping for a Non-ZWO camera. Then they are good they are very, very good. But when they are bad they are horrid. Personally, I’m moving away from ZWO.
So sorry to hear you are having repetitive problems with this camera.
Well Written Respectful Concise Engaging Supportive
Bruce Donzanti:
By the look of it seems like frosty patch on the sensor but I can't see at pixel scale so just tossing it.
Could it be something on your sensor window? I’d pull the image train apart and inspect just to be sure. I pulled mine apart of other reasons a few days ago and found a small leaf clinging to the side wall of my 2” Barlow, just waiting to pounce!
Pete Bouras avatar
Could be some debris that is moving around? I would inspect the FW and camera window carefully.
Is your 6200MM one of the new 2025+ model?
Pete
SonnyE · Mar 24, 2026, 01:50 PM
Thanks. I’ve had ASI2600 (color and mono) and 6200 cameras, of which, two had to have new main boards put in after about 6 years of use in my observatory which is both temperature and humidity controlled. I tested a more expensive QHY camera a few years back- built much better than ZWO but I didn’t like the software.
Tony Gondola · Mar 24, 2026, 03:14 PM
I just took it apart as it is high up in my observatory and bolted to the filter wheel. All looks perfectly fine.
Pete Bouras · Mar 24, 2026, 03:42 PM
Pete
Hey Pete
Nothing moving around or loose.
Mine is an old one- almost 6 years old.
Rick Veregin avatar
Hi Bruce
This is such an odd defect. It looks like the stars are normal through the spot, it is just the background level appears to be much lower than everywhere else. And I have never seen a spot that is just round and black, certainly not dust in your image train.
So this may be an odd thought, but since all other avenues are covered by others, one thing that might look like this is if the offset is not being applied in this round area, but everywhere else has the normal offset. This would definitely be something in the camera hardware, though unclear why it would happen. I’m pretty sure the offset voltage is applied at the back side of the sensor, so this would not be due to contamination on the front.
So when you see this problem I would look at a dark, is the spot there on your dark that is darker than everywhere else? Note that spot would still have hot pixels, but the general dark level would be different. I assume you use an offset, if not I would add one, or even increasing the offset might make it go away?
Rick
SonnyE avatar
Rick Veregin · Mar 25, 2026, 06:53 PM
Hi Bruce
Rick
On second thought Rick, maybe it’s a watermelon seed in the lens?
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Black dot artifact may relate to stray light issues with optical system.
Mar 1, 2026
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Dew heater operation and dew-related problems directly relevant to troubleshooting.
Nov 28, 2025
Dew shield modification: painted and insulated, but concerned about reflections
Some time back, a user here (I can’t recall his name, sorry) posted his physics lecture on dew shields and how to best utilize them. The recommendation was that flocking is bad, you should paint the inside of your dew shield and wrap it in insulation...
Dew shield modifications and dew prevention techniques applicable to camera issues.
19 days ago
