How to shoot HII Region in mono in light polluted zone
4 replies58 views
Eric Gagne avatar
I live in a bortle 6 zone and my neighbors have lots of light in their backyards which turns my bortle 6 into a 7 easily. I only have view on HII regions this time of year and I shoot with a miniCAM8M. The L filter that comes with it is just Luminance + UV/IR Cut, no light pollution filtering. AI tells me to do Ha for the luminance with long exposures and short RGB exposures for the stars.
I don’t believe AI is ready to be trusted 100% so I ask here. Is it possible for me to shoot HII regions ?
Yes and AI was partly right. I’m in B8 and here’s what I do. For narrowband I’ll often use the Ha frame or a combination of all the narrowband frames (superlum) to serve as the L frame. For broadband objects I’ve found it to be extremely effective to use a IR pass filter to create the L frame. I still have to struggle with RGB but without the near IR filter, these objects would be almost imposable to image from my location.
Helpful Concise Engaging
alpheratz06 avatar
To my humble opinion, the use of a NB Halpha filter is mandatory. L filter by itself, whatever exposure time, cannot separate Halpha signal from the continuum due to pollution.
Jim Raskett avatar
Or, shoot short (30 second) exposure’s for the stars and capture Ha and OIII for an HOO image. Also, you could add S if you desire SHO.
I live in B7 and have had good success with both using a Minicam8M.
alpheratz06 avatar
I realise that I have read the initial post too quickly , since the minicam does include NB filters.
The problem in heavy polluted skies is to achieve a good balance between stars (including colour calibration) and nebulae.
A good hint would be to “scout” forehand the intended area with e.g. Stellarium with the narrow band northern sky survey , in H, O and S band : signal density, for instance in S, will provide indications to adjust exposure time or even the opportunity to acquire images in an area where spectral response is too low to be worth the time spent.
It will maybe be necessary to use several sessions, depending of unobstructed field of view on ground :
  • one session with LRGB to get a good star coverage, and colorimetric calibration, with short exposures
  • one session with NB sequences , band selection according to the target area, with longer exposures compatible with sky background signal. More efficient if you have the 3nm filter version
Helpful Respectful Engaging
Advice on duo-band filter selection for astrophotography setup
Hi, I am looking to expand my astrophotography setup with a duo-band filter. Well, possibly two depend on how the pricing goes. I’m looking to have my feel-pinions validated and possibly a correction from someone who knows what they’re talking about....
Duo-band filters directly address light pollution filtering needs for HII region imaging.
Aug 31, 2025
What’s Wrong With My Luminance?
I really didn’t want to post another knucklehead question, but I am not sure how to proceed. The title says it all. I am a new mono shooter (Minicam8) and this is my first project that I included a luminance image, M33. I image in Bortle 7 skies. I h...
Same camera model; luminance channel issues relevant to author's setup and concerns.
Jan 7, 2026
UV/IR Cut vs Luminance
I’m sure this is discussed at lengths here and in the internet but still I failed to find an answer. So are the 2 doing the same thing ? Are they interchangeable? I own 2 mono camera, Touptek ATR585M with a 8 position filter wheel that have LRGBSHO f...
Author transitioning to narrowband imaging; discusses HII region shooting with mono cameras.
Feb 28, 2026
