Tips on my processing of bode's galaxy!
13 replies292 views
Horriblebaby avatar
Hey everyone! I got out last night and decided to shoot bodes galaxy and the cigar galaxy, I also just got a filter and was able to use it tonight. My filter is a svbony cls eos-c clip on. I shot bode’s galaxy for an hour and 30 minutes of total exposure time, I used iso 800 and 30 second sub exposures! I’m happy with the final image, But it seems quite noisy and the background still has these tiny little gradients. I tried manually doing curves and stretches, I also tried graxpert background extraction, But it seemed to be pretty much the same. I also was able to minimize any direct light pollution while shooting.
I shot the photos at 300 MM with my canon eos rebel t6. But even though I had a total exposure time of an hour and 30, Should I be able to get more detail of bodes galaxy? I do see the spiral but no dust lanes and such.
The first image is straight out of deepskystacker with the blue haze from the filter, Second image is after doing stretching with curves and histogram and background extraction. If anybody has any tips on how to make it better I would be very thankful! Thank you for taking the time to read :).
Also! Don’t mind the dust, I didn’t do any flat frames for this photo.
Helpful Respectful
Interactive Sky avatar
Which software did you use for background extraction?
I usually do stacking in Siril, and then I do background extraction and denoising in GraXpert.
That workflow helps me reduce gradients, noise, etc.
Hope this helps. 😀
Raw stacked image in Siril.
📷 image.pngimage.pngAfter Background Extraction and Denoising in GraXpert.
Rick Veregin avatar
You did not mention doing darks. With an uncooled film camera the sensor gets hot, so aside from read noise the thermal dark noise can be a big problem. Even in winter the sensor can get very hot. In the best of times, darks are needed to help remove noise. Darks should be done with the same exposure and temperature, which means you should do them somewhere when doing your lights. Bare minimum is 10 darks, but more would be better. Just put on the dust cap say after you are done with your lights, and take the darks.
You should also do flats and flat darks, 10 to 20 should be enough. This might help with the uneven red/green patches, this might be sensor variation, though it might also be a problem with how you did your background extraction. By the way, all those dust donuts do not help trying to get a good background extraction, it will be easier to get the background right without them.
You don’t mention how dark your skies are, but if you are using a CLS filter I presume that you don’t have super dark skies. In general, 1.5 hours isn’t enough to overcome the noise to get good details, your image is just too noisy. And if your skies are not dark, you will need to take even more exposure time. I assume you are at f6 or so with your lens? If you search on AB for M81 and 300 mm FL at your fratio you can see how much time people are using, my guess is 10 or more hours to get something that is getting there to bring out detail, but depending on how bright your skies are, maybe even more exposure than that. The 30 sec sub length should be good if you are in suburban skies, just more total exposure is needed.
Hope this helps
Rick
Well Written Helpful Engaging
Horriblebaby avatar
Rick Veregin · Mar 19, 2026 at 07:45 PM
Hope this helps
Rick
Thank you so much Rick! This does help a lot, I apologize for forgetting to say I did both bias and darks around 20 each. I also do flats on my other images but they sorta have the same gray background. I’m also in bottle 8 skies with a f 5.6 so I’ll look on AB to see how long people are doing it. Thanks again 😀!
Respectful
Agreed, I don’t think there’s much to talk about here until you clean your rig and do proper image calibration. Without that you’re just making it harder on yourself.
Well Written Concise
Horriblebaby avatar
Interactive Sky · Mar 19, 2026 at 07:17 PM
Hope this helps. 😀
Thank you so much! I use deepskystacker, I had no clue you can stack in Siril. I’m gonna look for a tutorial on how to and give it a shot right now!
Clear skies!
-Horriblebaby 😀
Respectful Supportive
Rick Veregin avatar
Horriblebaby · Mar 19, 2026, 07:54 PM
Hope this helps
Rick
Note that flats may look just gray, except for donuts, but there can be subtle variations that are difficult to see in the flat, but nonetheless, do improve image evenness. Remember you will be hugely stretching the image, so it doesn’t take a lot of unevenness to show up in the final stretched result.
Rick
Horriblebaby avatar
Rick Veregin · Mar 19, 2026 at 08:16 PM
Hope this helps
Rick
Rick
Okay yeah! Next time I won’t forget to do my flats. Thanks for all your help!
Respectful
Horriblebaby · Mar 19, 2026, 07:56 PM
Hope this helps. 😀
Clear skies!
-Horriblebaby 😀
Since you just have lights, put these in a folder and name it lights. Put this in another folder name with the name of your project. In Siril make the project directory your home directory. At that point you can stack using the script “OSC-preprocessing without dbf” It’s really easy…
Horriblebaby avatar
Tony Gondola · Mar 19, 2026 at 08:34 PM
Hope this helps. 😀
Clear skies!
-Horriblebaby 😀
Thank you! I just finished doing that, and now I’m in graxpert doing background extraction and denoising. It’s actually already looking quite a lot better!
Cal Schmidt avatar
📷 BodesandCigar.jpgBodesandCigar.jpgHows this? I cropped the artifacts out and did some processing on it.
I have almost the same camera, the Canon Rebel T5 with 300mm zoom lens.
Cal Schmidt avatar
To get the dust lanes on Bodes Galaxy your going to need more intrigration time. Not bad for only 1.5 hours with a Canon T6 I would expect that much noise for that small amount of intrigration time. Can only do some much with a jpg. I used Siril to crop your image down and used Prism Deep to denoise the image and then deconvolution on the stars. Graxpert is great but your image needed a bit more TLC to reduce the noise.
Horriblebaby avatar
Cal Schmidt · Mar 19, 2026, 10:31 PM
Thank you so much for taking the time to edit my image :). It looks extremely nice! especially since I had to compress it so much for the forums. I will also try and give PRISM deep a try and see how that works out!
Clear skies!
- Horriblebaby
Cal Schmidt avatar
No problem, I am still learning the processing end of this hobby. So I wanted to give a jpg a try and see what I could do with it. Prism deep is well worth the money. Im going back several months and using it on all my photos. It way outperforms Graxpert which I had been using.
Helpful Respectful Supportive
Help needed for dithering with NINA!
Hello everyone! I hope everybody is doing well today. last night was a great night in my area for astrophotography so I decided to shoot the leo triplet. This time I used nina and direct guider (Since I have no guide scope!) For dithering. I set it a...
Processing techniques for deep-sky galaxy imaging with filters and stacking.
11 days ago
Target candidate storage with ChatGPT
Here’s another experiment I’m running with ChatGPT. I search for targets based on focal length on Astrobin and I save targets I’d like to shoot as my bookmarks. Then I tell ChatGPT to save the target in my “target list”. It will keep a running list. ...
Finding astrophotography targets similar to Bode's and Cigar galaxies.
Aug 26, 2025
Gain and Offset settings for ASI585MC Pro
Just did first light on Bode's galaxy with my brand new ASI585MC Pro. Came out pretty nice! I was using the recommended gain of 252 and I set the offset to 8. Seems like 180s exposures are over exposed, should I be reducing the gain and allowing ...
Processing tips specific to Bode's galaxy imaging you just captured.
Apr 15, 2024
Stacking tips for comet A6 Lemmon captured with 35mm lens
Hello there everybody, how are you doing? Pablo here, again. I have a couple of questions about the comet of the moment... the A6 Lemmon and I was hoping to ask for some help if possible. The only clear sky I had a few days ago was really unexpected,...
Processing techniques for galaxy imaging similar to comet photography workflow.
Nov 2, 2025
Exposure time recommendations for my setup
Hello everyone. First let me list my equipment: Telescope: William Optics RedCat 71 WIFDCamera: ZWO ASI585MC ProMount: ZWO AM5NGuiding: ZWO 30mm Guide Scope (120mm) + ZWO ASI120MM MiniAccessories: ASIAIR PlusFilter: Antlia Quad Band Light Pollution F...
Author recently acquired filter; processing advice for filtered astrophotography images relevant.
Jun 5, 2025
