Equipment Failure and Replacement
7 replies218 views
Mossyback avatar
The weather at my location (like many others) has been terrible all winter. I now have some equipment problems that I can hopefully solve before some clear nights arrive.
Problem #1: My MeLe mini computer in the observatory has started to do weird stuff - not connecting off and on using RDT. Also it doesn’t show any Ethernet connectability so I can’t establish a connection that way. When it does run it’s very slow and sometimes doesn’t respond for over a minute. It’s about 3 or 4 years old. I’m thinking of replacing it with the latest MeLe version. Are there any other options that I should be considering?
Problem #2: My Pegasus Focuser Cube has also quit working and I need suggestions for a replacement. My current setup is an Esprit 120mm scope, Starlight Xpress FW and ZWO533 mono camera.
Hank
Problem #1: cheaper to get a more recent unit with better thermal management.
Problem #2: Gemini Pro focuser
Rostokko avatar
Humidity is your enemy; sounds like you need to keep it under control in your observatory at least during prolonged bad weather periods.
Well Written Concise
SonnyE avatar
Before you give up on your MeLe, can you do a reset on it and take it back to out-of-the-box configuration? That sweeps all bad data out so you can determine if it is connection troubles, or the MeLe itself that is the fault.
Your focus Cube can also be simply corrosion of the USB and/or power connections. Exercising your cord connectors by unplugging and reinserting them can often reconnect the sliding contacts.
These are routine maintenance many fail to realize can reconnect your equipment. Connections, especially USB types are not “forever” connections. They often get contaminated over time. Especially where moisture can be a factor. Folks in Great Britian have it the worst with their location and the weather.
So try some general maintenance first before you start throwing money at the problem.
One of my circuit pieces that seems to fail often is my USB hubs. So I keep spares on hand for when it happens. Hubs, as well as most USB connected items are particularly prone to connection degradations. My mount and laptop are easily reset, failing cables easily substituted.
But a couple of code bangers accused me of using a hammer to fix problems with their mistakes. So be it. I simply go back to before they poured Apple butter on working code written for Windows. ASTAP was one. When Han K. discovered what one had done, he wrote a cleaned version that works. I keep a download for when ASTAP acts up. So I can remove a corrupted version (HATE updates!) and go back to a working install.
I would try updating the OS in the Mele, if that doesn’t restore things then it’s time to replace it.
Mossyback avatar
Thanks for the suggestions. I’m checking cables and I’ve tried rebooting the computer without success. Thanks for the tip on the Gemini. The Lazy Geek has a video on it that’s quite interesting.
SonnyE avatar
Mossyback · Mar 20, 2026, 11:35 AM
Not rebooting, Reset.
Reset a MeLe Minicomputer.
Or you can see the whole results here.
But it clears all the data, bad and good, and you start over fresh.
Cuiv’s videos.
I don’t have a MeLe, I use a laptop at my mount connected by a Powered USB hub. But doing factory resets occasionally gets rid of all old crusty data, and starts fresh. Really speeds things back up.
I also do the occasional Factory Reset on my mount.
It’s a PITB to reinstall everything, but at least the gremlins are gone.
Thomas Picciani avatar
In regards to RDP disconnecting at random, I ran into 2 issues that were causing it. 1. I had the remote computer using a Microsoft account as opposed to a local account. The computer was calling home for authorization every so often and when it found no internet, i.e. when I was in a remote location, it would drop the link. 2. My travel router was being powered from a usb port on the mini computer. Once I switched to a local account on the mini pc and started using a wall wart to power the router, the problems went away. Note that I use an AC to DC power supply that can deliver up to 30 amps to the equipment. And at home I keep a UPS battery backup under the tripod. It stays on the deck all winter. As to the focus motor, I prefer Primaluce Sesto 3. I have an EAF and don’t like it as much because it locks the focus know down when the unit is powered off. The Sesto 3 allows you to turn the know, for instance, when storing the scope for transport.
Well Written Helpful Engaging
ASAIR Plus - Mini PC
GDay all. I was pulled into astro when watching youtube three years ago. The ASIAIR Plus made it pretty simple for this non guru and besides I had no laptop. I run an ethernet cable to the Air an monitor via IP address on my desktop PC. I have no dra...
ASIAIR Plus mini PC alternative for observatory remote control setup.
Dec 8, 2025
Mini PC crashing caused scope to hit mount
Looking for some help/advice please, on how to understand what caused my mini pc to crash & also how to stop the mount continuing to drive in the event of a pc hanging-up.. Following a recent imaging session I awoke to find my mount (an EQ6-R) ha...
Mini PC crashing issues relevant to observatory equipment problems.
26 days ago
Very Weird NINA Behavior (or ASCOM?)
Are there any known new bugs in the latest versions of ASCOM and/or NINA? Last night all the images were taken properly but NINA's sequencer shows that only 1 out of 45 blue filter images were taken when in fact I just downloaded 180 images plus ...
NINA sequencer not recording correct image counts; timing issues with flat exposures.
Dec 18, 2025
StarGo Avalon M-Zero – Connection impossible, looking for the latest StarGo version
Hello, I have been struggling for several sessions to connect my Avalon M-Zero mount. From what I can see, the issue might be related to the StarGo version provided on the USB key. It seems to be an old version, and apparently a newer one is availabl...
Software/firmware updates for mounts may resolve connection issues like yours.
Dec 31, 2025
Windows remote app on iPad
I’ve recently switched to a Mele mini pc and NINA to run my astrophotography setup and connect remotely via the windows remote app on my laptop. I know it’s also possible to use the Windows remote app on an iPad which could be very helpful when I go ...
Mele mini PC remote connection troubleshooting directly matches your situation.
Oct 14, 2025
