Cassio Pieroni Trevisani avatar
I had a hard time focusing today at Askar 71F; even with EAF, I was unable to get proper focus. Do I need to get extensions to connect with my DSLR? Do you have any suggestions? It is pretty disappointing as this was my first night out with my scope. But oh well. Any help super appreciated.
My camera is Canon R6 Mark II, with ASIAir Plus, ZWO Electronic Automatic Focuser (EAF) 5V USB-C, and ZWO ASI 120MM Mini USB 2.0 Mono Camera
This was the setup, before I organized the cables.
Soul crushing, but it is not going to deter me. :)
Help please!
Respectful Engaging
John Tucker avatar
My 91F came with two big extension rings. These were needed to reach focus.
If you find yourself so far out of focus you aren’t seeing anything at all, try doing a 1 or even 3 minute exposure. You’ll probably then see some huge out of focus star. Tweek the focuser a couple of turns one direction or the other and take another long exposure. The big circle should get bigger (wrong direction) or smaller (right direction).
Well Written Helpful Concise Engaging Supportive
All you should need is the photographic adapter and the ring that adapts to your DSLR. There isn’t a specific back focus requirement. What you might do is try focusing on something far away during the day. See if you can at least get it close. If you can then on your next night out you should be close enough to go from there. To do this manually you’ll just have to loosen the coupling to the EAF.
I feel your pain but most of use have been crushed many times in this hobby. I used to be 6’5”…
Well Written Helpful Respectful Concise Engaging
Hadi Zaheer avatar
Edit: I hadn’t completely read what Tony had written and went and repeated it all 🤦 Apologies!
Out of curiosity, did you happen to try reaching focus by hand before you attached the EAF? If not, it may be worth trying to remove the EAF and trying to focus on a distant tree or building during the daytime.
If nothing else, it will get you close to where you need to be and then you can reattach the EAF and go from there at night.
If you're still unable to reach focus that may be a good indication that you may need extensions. But like Tony said, you really shouldn't, as the way you have it attached at the moment, it should just work because of the kind of telescope it is.
Hadi Zaheer · Mar 19, 2026 at 06:20 AM
Hi Hai
I did try focusing during the day and that worked really well with and without EAF. But when I tried to focused the stars only big donuts and I was at the limit of the scope and I was unable to focus. Tried everything for hour, connecting and disconnecting the EAF. I looked up online and it seems I need a tude extension to increase the distance from the focal length point. But not sure which extension would be best. Thanks Cassio
John Tucker · Mar 19, 2026 at 12:09 AM
Hi John, thank you for your suggestion even when I got the best focus the stars where still very blown (donut like) . I also tried different long exposures to no avail.
John Tucker avatar
Cassio Pieroni Trevisani · Mar 19, 2026 at 07:39 AM
Can you post a picture?
Tony Gondola · Mar 19, 2026 at 01:08 AM
Thank you for your suggestion. I will try it.
Hadi Zaheer avatar
Cassio Pieroni Trevisani · Mar 19, 2026, 07:32 AM
Hi Hai
Ah I see! Having had a bit of a read online as well it looks like a 15mm extension tube might be worth trying out (something like this for example). You'll have to make sure it's a M48 female thread and the male thread on it matches the threading on the DSLR adapter. Which DSLR adapter was it that you purchased?
John Tucker · Mar 19, 2026, 08:25 AM
It will have to be tonight as the image are on ASIAir and I am at the office today, I will definitely send later.
Robin Bosshard avatar
Hi Cassio
I posted a reply in your other thread. Short summary: it could be that the ZWO EAF hits a limit (max steps) before the focuser is sufficiently extended. In that case, first find a rough focus (by day, some object in the distance), then mount the EAF. But first have a look at the focuser while the EAF is working in the current state. if the focuser does not extend to the max, you’ll need to pre-focus…
Best of Luck!
Robin Bosshard · Mar 19, 2026 at 11:40 AM
Hi Cassio
Best of Luck!
Thank you Robin. Clear skies!!!!
Hadi Zaheer · Mar 19, 2026 at 08:32 AM
Hi Hai
Thank you! I am waiting for the extension to arrive and test it again. Thank you for your suggestion. Clear skies!
New (first) APO: Askar Fra 400 x Askar 71F + Reducer + ZWO EAF
Hi all, I am looking for my first APO refractor (currently, I am using a Skywatcher 130/650 reflector). Based on extensive research and my budget, the final list is: Askar FRA 400Askar 71F + reducer (with the savings, I could also buy the ZWO EAF). B...
Focusing issues relevant to Askar 71F purchase decision and camera connection.
Feb 18, 2025
First Telescope – ASKAR 71F | Any good resources on how to use it?
Hi everyone, I’ve just bought my first telescope, the ASKAR 71F, and I’m really excited to start my astrophotography journey. I’ve done some photography before, but this is my first proper telescope setup, so I’m very much in learning mode. If anyone...
First telescope focusing issues with ASKAR 71F and EAF troubleshooting guidance.
27 days ago
Autofocus dial in
Is there anyone using a 130phq with an eaf and ASIAIR that is willing to share their backlash and auto focus setup numbers? I’m battling auto focus weirdness.
EAF focusing issues with telescope; relevant to autofocus hardware troubleshooting.
Dec 2, 2024
Polar alignment produces absurd correction angles
Hi, I am using an ASIAir Mini with a Skywatcher EQ AL55i mount connected via the serial cable (could not get any other connection to work properly). I can control the mount from the ASIAir app and I got my camera and focus set up. Plate solving works...
ASIAir connection and equipment setup issues similar to your configuration.
Aug 18, 2025
Controlling a UMi 17X: MiniPC or StellarMate/StellaVita/ASIAIR
Hi there! I’m decided to pair my Sky-Watcher Wave 150i with my C8 EdgeHD for Galaxy Season. For this I ditched the AVX mount head, got a ZWO Pier Extension which fits the AVX Tripod and voila: one sturdy, big and not so mobile setup (new guide scope ...
ZWO equipment control and pier extensions for DSLR camera connections.
27 days ago
