Interactive Sky avatar
Hi everyone,
I’ve been looking at some amazing images where a comet is captured together with galaxies in the same frame, and I’m really curious how you manage to get such clean results.
From what I understand, there are a few challenges:
  • the comet is moving relative to the stars/galaxies
  • stacking on the stars makes the comet blurry
  • stacking on the comet makes the galaxies trail
So I’m wondering — what workflow do you usually use for this?
Do you combine comet-aligned and star-aligned stacks, or is there another approach that works better?
If anyone has experience or tips (especially with APP or PixInsight), I’d really appreciate it!
Clear skies!
Médéric Hébert avatar
Never done it myself, but from what I’ve heard from other that have done it. You capture them seperatly then recombine them like you would when adding RGB stars to NB image
It would be pretty easy if you did a session for the comet and then a session for the field once the comet has moved on. Then you could just screen in a starless image of the comet onto the background field.
Tony Gondola · Mar 19, 2026, 03:07 AM
Yeah, that’s a good idea.
I will definitely try it.
Thank you. Clear SKies
First Telescope – ASKAR 71F | Any good resources on how to use it?
Hi everyone, I’ve just bought my first telescope, the ASKAR 71F, and I’m really excited to start my astrophotography journey. I’ve done some photography before, but this is my first proper telescope setup, so I’m very much in learning mode. If anyone...
Not relevant; focuses on telescope equipment rather than comet imaging techniques.
27 days ago
Stacking tips for comet A6 Lemmon captured with 35mm lens
Hello there everybody, how are you doing? Pablo here, again. I have a couple of questions about the comet of the moment... the A6 Lemmon and I was hoping to ask for some help if possible. The only clear sky I had a few days ago was really unexpected,...
Relevant; directly addresses stacking techniques specific to comet photography.
Nov 2, 2025
Why do We Got Blured Processed Comet Images After Stacking?
Hey everyone, I have a question about processing comet images using Siril. I've noticed that after stacking, the comet images appear badly blurred. I'm not sure if this is due to the comet's movement between frames or if it's a common...
Directly addresses comet stacking workflow and processing techniques.
Oct 23, 2024
Need Help Processing Comet Images Taken With seastar
Hello everyone! I’m reaching out because I’m feeling a bit lost when it comes to processing comet images taken with the Seastar. This year, I captured two different comets, but I'm not sure how to process them. I tried following the tutorial from Dee...
Relevant; covers comet image processing workflows and techniques.
Sep 3, 2025
Stacking multi-telescope imaging data with different focal lengths and sensors
Hi everyone! 👋 I have a question for the DSC team (and anyone working on collaborative imaging projects). If you’re willing to share, I’d love to learn a bit about how you approach stacking data from different telescopes and setups. For example, comb...
Discusses stacking workflow techniques combining different celestial objects and datasets.
19 days ago
