Hello, I have a problem I can't seem to solve. If anyone can shed some light on it, I'd appreciate it.
I'm testing a new setup: SkyWatcher APO ESPRIT 120 / x0.77 Reducer SkyWatcher / QHY 268 mono / Chroma Ha 5nm 36mm / Chroma SII 3nm 36mm / Chroma OIII 3nm 36mm.
Sunlight, light, and dark (S/H/O) exposures with a gain of 56 and an offset of 25 at 300 seconds produce a circular pattern that I've never had with other setups. Then, when I take flat exposures, I get the same pattern, and it only corrects the Ha exposures correctly; the SII and OIII exposures are not corrected properly.
I've tried changing the light source for the flat exposures (looking at a clear sky) with the ADUs (20000/25000), but it doesn't improve anything.
I've also tried increasing the value of the "Output pedestal (DN)" field between 100 and 500 in the "ImageCalibration" process, specifically in the "Output Files" section, but it didn't solve the problem. I've tried many different values and adjustments, but it either overcorrects or undercorrects. I haven't been able to find the solution, if there even is one.
If anyone has had a similar problem or knows of a solution, I would appreciate it.
Regards.
