Stacking multi-telescope imaging data with different focal lengths and sensors
4 replies91 views
Interactive Sky avatar
Hi everyone! 👋
I have a question for the DSC team (and anyone working on collaborative imaging projects).
If you’re willing to share, I’d love to learn a bit about how you approach stacking data from different telescopes and setups. For example, combining data with:
  • different focal lengths
  • different pixel scales
  • different cameras/sensors
Do you typically resample everything to a common scale before integration, or process datasets separately and combine later?
And how do you handle differences in the field of view when mixing full-frame and smaller sensors?
I completely understand if parts of your workflow are something you prefer to keep within the team — even general guidance would be greatly appreciated. 😀
Thank you!
Tom Boyd avatar
Limited experience here, but I am combining data from my FLT132 and my CarbonStar200. I stack the data for each scope separately. I then remove gradients from the each of the results. I then register the gradient-corrected images - which in PixInsight resamples the data. And then stack the registered results.
Well Written Helpful Respectful Concise Engaging
Thank you, Boyd.
I’ll try to do that as well.
I’m also interested in whether WBPP can handle data from different cameras and focal lengths together.
Clear skies!
Tommy Mastro avatar
While I use WBPP, I find APP better at this. That said, I know WBPP can handle such combos, but it’s not so obvious. If you Google (AI) you question, I believe it will explain the WBPP process.
Thank you, Tommy.
I also thought that APP would be better, but I just wondered if anyone uses WBPP like this.
Clear Skies!
Respectful
Most effective processing approaches for small astronomical targets
Hi everyone 🙂 I’m just wondering what people typically use for imaging small planetary nebulae. What setups have worked well for you in terms of:focal length and aperturecamera choice (pixel size, sensor type)exposure strategyAlso curious what proces...
Discusses stacking with different focal lengths and sensors for imaging targets.
10 days ago
Stacking data from different telescopes/cameras in PixInsight?
Hi everyone, I have a question about combining datasets from different equipment. Let’s say I have images of the same target taken with different telescopes and cameras, meaning the data has different focal lengths, pixel size, and resolutions. I kno...
Directly addresses stacking data from different telescopes and cameras in PixInsight.
23 days ago
Capturing comets and galaxies together: stacking workflow techniques
Hi everyone, I’ve been looking at some amazing images where a comet is captured together with galaxies in the same frame, and I’m really curious how you manage to get such clean results. From what I understand, there are a few challenges:the comet is...
Discusses stacking workflow techniques combining different celestial objects and datasets.
19 days ago
Request for Data Collaboration of Sh2-174
If anyone is interested in sharing data to create a very deep image of Sh2-174? I collected 30 hours (22.5 Ha and 7.5 OIII). The image is attached here. Some of the Ha emissions in the upper right look interesting, but are very faint. It would be int...
Involves collaborative data sharing and integration from multiple sources for deep imaging.
Oct 14, 2025
Processing M42 in GIMP - a complete workflow :)
Hi guys, here is my tutorial, showing a complete workflow for processing M42, The Great Nebula in Orion, in GIMP. The image was taken with Skywatcher's ED80 + 0,85x reducer / flattener and astro-modded Canon 450D. Comments and questions are welco...
Potentially relevant for advanced multi-instrument astrophotography projects beyond single-telescope workflows.
Jan 23, 2025
