TouTek filter wheel registered as a camera..?
2 replies37 views
Eren avatar
Hey, I just got my new ATR585M + AFW-M by ToupTek and the camera works absolutely fine. My only issue is the filter wheel, I could originally not find it in NINA under filter wheels but then I saw it was registered as a camera..
I already tried updating the drivers for the filter wheel and even updated ASCOM. When I run ASCOM Diagnostics, it doesn’t show up there as well just a bunch of simulators.
This seems like a driver issue for me but I don’t know how to fix it, any ideas?
Thank you!
Well Written Respectful Concise Engaging
I suspect it’s a driver issue. If you see everything else, ASCOM is working. I would make sure you have the latest firmware and drivers. I would also try a different cable and different USB plug on your PC. I have the same setup and it works fine in NINA, no issues showing up as a filter wheel.
Eren avatar
Tony Gondola · Mar 16, 2026, 06:44 PM
Thank you.. I had to reinstall the drivers a few times and then it worked.
PC power failure caused the mount not to connect in Sharpcap
I’ve created a major issue with my rig’s MeLe 4c PC not connecting to my HE5 Pro mount after a power failure via a power box. A Runtime error 62: input past end of file is shown, which given the log from Sharpcap seems related to a server issue, see ...
PC power failure caused mount connection issues; similar driver/connection troubleshooting approach.
Nov 13, 2025
UV/IR Cut vs Luminance
I’m sure this is discussed at lengths here and in the internet but still I failed to find an answer. So are the 2 doing the same thing ? Are they interchangeable? I own 2 mono camera, Touptek ATR585M with a 8 position filter wheel that have LRGBSHO f...
Author owns ATR585M with filter wheel; directly addresses their specific equipment setup.
Feb 28, 2026
Diagnostic help, please
Hello, I have searched many sites looking for similarities regarding a worsening issue I have been fighting for some time. I hope that posting here and attaching some photos will help with the diagnosis. Essentially, my stacked light frames using the...
Diagnostic help post may contain relevant troubleshooting strategies for hardware detection issues.
Oct 19, 2025
