John Tucker avatar
Working on transitioning from more or less EAA to better astrophotos. Last night was remarkable seeing for this part of Florida, was able to get my guiding down to an average of about 0.4 for the entire night and down below 0.3 for extended periods.
The Whirlpool galaxy is an overworked target, and there is nothing unique or creative about this framing, but it was a good opportunity to test out my new Nexus focal reducer. My stars have tails that get worse as one goes from upper right to lower left. Is it tilt? I just finished a careful collimation of the scope and have checked that the corrector plate and secondary mirror have the correct rotational alignment iwth the primary mirror.
I’m not going to complain about the OTA. I picked it up for $100 used from a guy who only wanted to sell locally.
Looks like coma. Tilt usually ends up showing astigmatic stars.
John Tucker avatar
andrea tasselli · Mar 15, 2026, 02:33 PM
Can it be fixed or is that just the price of doing AP with a $100 OTA?
Does it show without reducer? If it does and if the collimation is spot-on then yes, that is an issue. I suppose that you being in FL temperature equalization isn't a concern there but in case it is are you sure the scope has reached thermal equilibrium?
John Tucker avatar
andrea tasselli · Mar 15, 2026, 02:47 PM
We have massive dew problems here and I had the heater on the dew shield turned up pretty high. I’ll look into that, thanks!
TiffsAndAstro avatar
John Tucker:
What scope, and do you have a guide log?
I only ask as I recently got similar stars, but my guiding showed a BIG ra spike every few seconds.
John Tucker avatar
TiffsAndAstro · Mar 15, 2026, 05:50 PM
John Tucker:
I’ve never been able to figure out how to generate/find a guide log on the ASIAIR. But the seeing was outstanding, and everytime I looked at the guiding it was below 0.5 arc seconds and never saw a spike greater than 1 arc second. Probably overall the best guiding I’ve ever gotten.
This is an old carbon fiber C8 that I picked up used. The collimation was all screwed up, in part because the secondary had been rotated out of position, so I tuned it up as best as I could.
John Tucker:
That could be quite likely, given that at the resolution of the pic I can't tell if it's one or the other. Insulated dew shield, reflective insulation and dew strip kept at minimum are the best way to combat dew (see this thread: Reaching Out to John Hayes - AstroBin)
John Tucker avatar
Looks like the problem(s?) varied over the course of the night, so probably something thermal. 📷 image.pngimage.png
Yeah, I'm pretty positive about that.
Craig Towell avatar
Also agree on the thermals as cause of those flares.
BTW on ASIair if you go into the memory the guide log files are in here…
John Tucker avatar
Craig Towell · Mar 15, 2026, 08:15 PM
thanks!
oymd avatar
Looking at your very first image of M51, you barely have ANY tilt!
It looks like coma what you are referring to, not tilt.
Newton collimation
Hello . I have a question about collimation . Im gonna make this very simple . I have a quattro 200p with starizona coma reducer , so im at F3 . I collimate using a laser and that's it . I dont double check on a star . Obviously i dont have perfe...
Explores image quality problems including potential collimation/tilt issues.
Jan 1, 2025
Star shapes on Samyang 135mm
I have adapted the lens using the Vetec IMX571 camera. The problem is the the bad star shapes in 3 of the corners. In 1 corner it looks prolonged, another corner it has a tail. The tilt is 11 % according to ASTAP. On my EOS 6d my stars look good. I a...
Directly addresses tilt diagnosis in astrophotography; core concern of your post.
Jun 17, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration causes star trailing; author experiencing similar tailing issues.
Nov 18, 2025
