Synscan mount pointing wrong direction before manual star alignment
6 replies83 views
Rocksen avatar
What to do when Synscan sends my mount in the complete wrong direction in the step before the manual centering for the star alignment process?
For context I have a Sky-Watcher Sky-Adventurer GTI…
I have ensured that Synscan has my coordinates and the scope is roughly polar aligned, so why might this be happening? Is there a way to star align in Synscan completely manually so I can avoid this altogether?
Would appreciate help, Thank You.
Robin Bosshard avatar
Hi! Have you checked the time that synscan is working with? If that reverted to some generic value or another time zone, the directions would be off…
Well Written Respectful Concise Supportive
One thing that comes to mind, have you entered your longitude with the correct sign, east or west, plus or minus?
Well Written Concise Supportive
Brian Puhl avatar
When pointing fails it’s almost always a time related issue, assuming you have the correct coordinates for your location input.
Médéric Hébert avatar
Might be related, but my EQ6R Pro can’t point correctly if it’s set to JNow instead of J2000. Never had issues with J2000. Not sure if this is only relevant to EQmod or if it affects the Synscan controller too
Morian avatar
I have experienced the same issue myself.
If the mount behaves crazy and wants to go in a completely different direction than planned, I do this: I go to the park scope and when this is done and the hand controller says turn off system, simply cancel this and start again.
I have also experienced this after 3 star alignment and when you are going to your target.
Hope this helps…
Supportive
MaksPower avatar
Causes:
  1. You’ve set up 180 degrees out (RA axis facing south instead of north, or vice versa) - trust me - I have seen people do this;
  2. Site location set to the wrong hemisphere (south instead of north, or vice versa) - classic human error;
  3. Did not set the scope to the PARK position before starting the polar alignment ie scope pointing at the pole, (Dec ± 90 degrees) and counterweight down.
Well Written Helpful Concise Engaging
Slew rate does not make sense
Hi, I have a problem where NINA (or possibly SynScan Pro or the mount) is slewing way faster in the RA axis than it thinks it is. This leads to the mount overshooting substantially and I have no idea how to fix this. The following is what I can see:P...
SynScan slew direction issues may relate to axis calibration or speed problems.
Oct 13, 2025
Polar alignment at high focal length
I was searching the internet for polar alignment methods at high focal lengths. I can’t find a standard method for this.So, what do you prefer? (Assuming you do it with the high focal length scope..)
Discusses mount alignment issues that may relate to polar alignment procedures.
Dec 2, 2024
Polar alignment produces absurd correction angles
Hi, I am using an ASIAir Mini with a Skywatcher EQ AL55i mount connected via the serial cable (could not get any other connection to work properly). I can control the mount from the ASIAir app and I got my camera and focus set up. Plate solving works...
Polar alignment problems can cause incorrect mount positioning during alignment.
Aug 18, 2025
Adding stars to starless image causes them to bloat - what am i doing wrong?
I have HOO & RGB data for the crescent nebula. I processed the HOO and the RGB seperately but ensured I had a staralignment done before processing. The images are the same size, I've tried to combine them both in 16bit and 32bit format and st...
Mount alignment issues could affect star positioning during image combination.
Jun 19, 2025
