Paul O’Brien avatar
Hi - I'd love some feedback on my Pacman.  I started imaging a little less than 2 years ago and dove into PI after taking several tutoring sessions with Ron Brecher last summer.  I started processing by myself in late August/early September and finished this Pacman in October.  The Pacman is something like my second attempt at PI processing. I'd do some things different now but I'm relatively satisfied with it given my level of knowledge in October (not that I'm an expert now - far from it!).   Is the reddish background outside the main nebula noise or nebula?  Not sure.  Anyway, thanks for your feedback!
Paul
https://www.astrobin.com/oa7l27/
Vivian Budnik avatar
Hello Paul,
I love the color composition, and in general this is nice work. The only criticism I would have is that the stars are surrounded by dark halos. This is particularly noticeable in the stars overlapping the nebula, but I can see this in other stars as well. Did you do any kind of star redaction/substitution? The halos seem to be more pronounced in small stars. My guess is that when you do star reduction/substitution, you should make different masks for different star sizes. This can be accomplished by using morphological transformation using the "close" option. This would allow you to have different masks for several star sizes (e.g. large, medium, small, very small). Then you can refine your masks for each group of stars with morphological transformation dilation or erosion, until the mask is fairly similar to the star mask.
The problem when making star masks, by any method is that different star sizes are not similarly covered by the mask. For the large stars the mask might be too small, while for the smaller stars, the mask might be too large (in this latter case resulting in the presence of halos when substituting) You can solve this by using different masks depending on star size. I hope this helps
Clear skies,
Vivian
sorry…some typos and bad sentences above. I the first paragraph, last sentence, I meant: to make the star mask, making sure that it is approx the same size as the stars.
Uwe Deutermann avatar
Can only agree with Vivian above, the star handling suffered from reduction done too harsh. Color assignments look very good! I do not like the dark area inside Pacman either, not sure what was done to make it look like that, looks too blotchy if you ask me. Overdone noise reduction maybe?
The red parts outside of the Pacman is indeed Hα, and that you caught this is really good!
All in all, a nice image, I think if you get the star and ark area handling under control it will be a wall hanger 😊.
Paul O’Brien avatar
Vivian Budnik:
Hello Paul,
Clear skies,
Vivian
Thanks, Vivian, and I agree.  I did not use star reduction.  I believe part of the problem was that I screwed up my decon process.  At that time, I was kind of lost in correctly applying this tool.  Your tips in creating different star masks using morphological transformation is much appreciated.   I'm probably doing something wrong with MT but I seem to get weird core artifacts when processing galaxies so I've shied away from it recently.  I also have started using StarXTerminator, which I've found very useful.  I'll definitely try your suggestions.   Live and learn!
Paul O’Brien avatar
Vivian Budnik:
sorry...some typos and bad sentences above. I the first paragraph, last sentence, I meant: to make the star mask, making sure that it is approx the same size as the stars.
Got it!  Thanks.
Paul O’Brien avatar
Uwe Deutermann:
Thanks for your comments, Uwe.  The stars I understand but I'm not sure what dark areas you're referring to.  Could you please be a little more specific?  Are you talking about the large dark structure at the top or something else?   I thought the reddish parts were Ha but given my relative inexperience, wasn't sure so it's good to know it's real.
Paul
Just read you response to Vivian, and yes, now this makes sense, the Deconvolution does do that, had it many times, and sometimes I cannot find any setting to avoid it.
I meant this dark area:
I compare that with one of my images (easiest to do ... there are much better ones out there though) and it looks like this:
I hope you see what I mean. I also see that the images are horizontally mirrored, hmmm ... I wonder now who of us did the flip 😉.
Hope that helps as explanation!
John Favalessa avatar
Decon can certainly mess up stars.  Decon is also difficult to get right.  There is a good youtube video by Adam Block on using it, but also there is a script "EZ Processing Suite" which does a fairly good job out of the box.  It's an add-in to Pix.  https://darkarchon.internet-box.ch:8443  After adding the URL to "Manage Repositories", do an update.  Once you do this you should see the Suite under the main menu, Script.  It also has some other good scripts in it.
John Favalessa:
Nice John, I always wondered where to get it and now I do. I  saw already many YouTube videos about it and it looked nice to save some processing time! THANKS!
Paul O’Brien avatar
Uwe Deutermann:
Thanks for the clarification, Uwe.  I understand now and completely agree.  Starting with a couple of my first images, including this one, I began to see a pattern of these strange "globules" showing up when I used an excessive combination of HDR, LHE and sharpening and started correcting it in later images. If it's not one thing, it's another, right?
Paul
Paul O’Brien avatar
John Favalessa:
John Favalessa:
Thanks, John.  Yes, after doing my first couple of images, I downloaded the "EZ Processing Suite" and used it a few times.   It's worked on several projects and not so good on one or two others, in which I've gone back to doing it manually through Decon.  I've also recently started using Herbert Walter's scripts and used a number of them too.  Love GAME, AdvSharpen, MaskGen, PSFImage, etc.  Very cool.  Keep those comments coming!
Paul O’Brien avatar
Paul O’Brien:
John Favalessa:
John Favalessa:
Thanks, John.  Yes, after doing my first couple of images, I downloaded the "EZ Processing Suite" and used it a few times.   It's worked on several projects and not so good on one or two others, in which I've gone back to doing it manually through Decon.  I've also recently started using Herbert Walter's scripts and used a number of them too.  Love GAME, AdvSharpen, MaskGen, PSFImage, etc.  Very cool.  Keep those comments coming! OH
BTW, I subscribed to Adam's Fast Track and Fundamental instructional videos.  Boy, they are crammed with info.  I can only watch them for a while before I need to go out and take a break.  Awesome info.
Paul O’Brien avatar
Paul O’Brien:
Paul O’Brien:
John Favalessa:
John Favalessa:
BTW - I'd be interested in how you get the right balance in sharpening.  I know I tend to over sharpen in an (probably misplaced) effort to maximize the benefits of my 61MP camera.  I know some of it is a matter of personal taste, like so much of AP, but I'm curious if all of you have any thoughts about how you go about sharpening a target.
[RCC] The Andromeda Galaxy
Hello everyone, I am still new to Astrophotography and still learning how to process images. I started to learn PixInsight about 3 weeks ago. I paid for the 3 RC Astro plug-ins. NoiseX, BlurX, and StarX. This was my 3rd try at processing Andromeda wi...
Learning PixInsight processing as a beginner, similar timeline and experience level.
Nov 11, 2023
[RCC]M45
Greetings! I've been practicing astronomy for a little over 3 years now and imaging for about 2 of those years seriously. I'm a fairly new user of PixInsight and am learning as much as I can, and there is still a ton to know. I'm also ver...
RCC thread showing processing work from someone with comparable imaging experience.
Jan 4, 2024
[RCC] How to make a picture more "catchy"?
Hello, I am wondering how some images get more attention than others - are there some basic rules for making a picture more "catchy"? Following example here: https://www.astrobin.com/1j53nc/ While this picture was processed in a decent way,...
Discusses image processing and presentation techniques relevant to improving work.
Sep 13, 2023
