Lunar eclipse photography advice for two telescope setups
8 replies56 views
Reid avatar
Hello all!
I am hoping on shooting the lunar eclipse on Tuesday morning, providing it is high enough to see, and have zero experience in lunar photography. I am planning on using both of my rigs and looking for advice. As I understand I should be capturing video.
The first rig is a Sharpstar 140ph (677mm focal length) with an ASI2600mc pro.
The second rig is a Redcat 51 (250 mm focal length) with an ASI585mc Air.
Where should I start with exposure lengths and how long should the videos be?
Should I use any filters?
TIA!
Both setups will be fine. Since you’re shooting color camera, all you’ll need for filters will be a uv/ir cut and that may already be incorporated in your cameras. I would use SharpCap for this, 8 bit color to ser file. For processing you can use autostakkert or my fav, Astro Surface.
I would start practicing now if you get a chance.
Helpful Concise Supportive
Bob Lockwood avatar
Reid:
Only if you want a video, most just shoot single exposures. Remember the eclipse takes a long time, just take a shot of whatever phase of the eclipse you want to capture.
As I’m sure you know, the reason to shoot video is to be able to apply lucky imaging techniques to gain a much higher resolution result.
Shooting full frame single shots (say 1 sec) is the way to go. Don't bother with the RedCat, waste of time.  Video is pointless.
I guess we need to know just what the OP wants, a sharp full disk image or series of images or a time lapse of the event or all of the above.
Concise
Reid avatar
I want a sharp full disc image of the eclipse.
If you can get the full disk in the larger scope, use that. If not use the smaller.
To get the sharpest possible final image use lucky imaging as I outlined in my first post.
If you want to keep it simple, do single exposures. The actual exposure time will change as the event progresses. Keep an eye on the highlights, you don’t want to clip the highlights which is very easy to do when most of the moon isn’t in shadow.
Well Written Helpful Respectful Concise Supportive
Reid:
Take it from someone who has done it time and again, single shots of short duration (say up to 80 of the histogram) but short enough not to cause image blur is the way to go. The drift rate of the Moon is around 0.4"/s so a couple seconds exposure will do nothing against resolution. I want to capture the field stars and whatever lurks behind in the field. Don't waste time with the mini-scope, use the big beast instead, assuming the focal length is correct that is what it should look like:
Well Written Helpful Concise Engaging
Gear advice
Hello, Please feel free to let me know if this topic is in the wrong area… but I have the 9.25" EdgeHD. I have been using it for a few months now, primarily for visual work and just learning the scope and mount. In the time that I have had...
Lunar eclipse photography directly relevant to author's moon photography interests.
Dec 16, 2024
combining multiple sources at different image scales in planetary photography
Hello planetary people. Is it possible to combine data from two different sources at different imaging scales in planetary astrophotography? I have an idea to combine OSC data from a 120mm refractor with luminance data from a 10" newtonian for d...
Lunar eclipse photography advice for two telescope setups.
Mar 2, 2025
