The literature on this problem is very vast and dispersed, and having recently purchased an RC optic and faced collimation problems for the first time, I ask for some advice. I don't want to spend a fortune on items or devices for collimation and let's say that I have available to do it: a) Reego collimator 2) Collimable laser collimator 3) Tilter ring 4) mirror. What I have found is that to collimate the primary and see the ring I have to screw the fok directly to the breech, because I am not going to unscrew the last part of the internal hood. So I would proceed like this:
1) Complete optical train with spacers: I insert the laser and with the mirror I check that the laser centers the circle: to do this I act on the screws of the tilter 2) By acting on the secondary mirror I try to re-center the laser beam on the reference of the laser collimator. 3) When the two previous operations have been done I unscrew everything and directly screwing the fok on the breech through the Reego I try to center the shadow of the secondary at the center of the primary (anellus). As the primary interacts with the axis of the fok: 4) Control and fine collimation with the laser and tilter. Is this a fair procedure or am I doing something wrong? Thanks in advance and clear skies.
