Green banding issue in WBPP when using flats
4 replies80 views
Evan Viljoen avatar
Does anyone know what might be causing this green banding? I’ve never encountered this issue before, and it disappears when I exclude flats from WBPP. I have inspected my flats, and they seem normal. I’ve yet to try retaking the flats or do more testing. Just hoping someone has seen this before and knows. This is the stacked image from WBPP, including biases, darks, and flats.
📷 masterLight_BIN-1_3008x3008_EXPOSURE-300.00s_FILTER-NoFilter_RGB_drizzle_2x_autocrop.jpgmasterLight_BIN-1_3008x3008_EXPOSURE-300.00s_FILTER-NoFilter_RGB_drizzle_2x_autocrop.jpg
Tom Boyd avatar
No clues, but channelling Andrea - I would try to do the stack by hand, outside of WBPP, to see where things are going wrong…
Brian Puhl avatar
This looks like registration doing it’s thing. Blink your images, I think your framing is jumping around. The green areas are just a lack of signal.
Just a guess. If not then I’d lean towards a USB issue. This is not a flat or bias issue.
alpheratz06 avatar
How do the masters dark and flat look like?
Evan Viljoen avatar
I think it may have been a USB issue that affected the flats. I noticed that one of the flats was actually an empty file, so something must have happened while writing to USB (ASIAIR saving to USB). Nonetheless, if I have a look at the master flat from this data, we see the exact pattern present in the master light. If I exclude flats or use flats from a different night, no issues.
📷 integration_RGB_VNG.jpgintegration_RGB_VNG.jpgBlinking the flats doesn’t reveal anything, at least not easily noticeable. Must have been the subtlest of errors in the files that, when stacked, give me this.
Thanks all
Helpful Insightful Respectful
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Green banding may relate to dark frame gradient issues affecting calibration.
Mar 5, 2026
ASI2400MC – Red, Green, and Blue Dots & Vignetting Issues
Last night, I finally had a clear sky to test my new ZWO ASI2400MC camera. However, I noticed numerous red, green, and blue dots appearing in the image, along with noticeable vignetting. Does anyone know what might be causing this? Any insights or tr...
Green banding issue may relate to color channel problems with Quad Band filter.
May 24, 2025
Dark streaks in stacked data
Still getting used to the ASI6200MC camera. Among my first images if this stack of the whirlpool galaxy. When I denoise this, the black streaks get enhanced causing dark splotches. I'm wondering if strong dithering is the solution for this. I don...
Green banding issue involves artifact enhancement during processing, similar to denoising problem.
Jul 20, 2024
MaxIm DL 7?
Hi: I wonder if anyone tried MaxIm DL7? There seems to be a bit more features. But does it worth the price? CS Tian
Green banding issue in WBPP when using flats — Does anyone know what might be causing this green banding? I've never encountered this issue before, and it disappears when I exclude flats from WBPP.
Jul 24, 2024
533mc Pro - Terrible Reddish Artifacts
Hi everyone, I’m experiencing an issue with my 533mc Pro camera and could use some advice. When I take RGB pictures using the Antlia Quandband filter, I notice two large reddish areas in my images. This problem persists even in my flats, and the WBPP...
Green banding issue in WBPP when using flats — similar WBPP artifact problem with persistent structures.
Jun 27, 2024
