Shooting "in the zone"
7 replies216 views
After a few years of experience shooting both OSC and MONO under B8 skies it’s become clear to me that for the most part, getting data, especially L frames below an altitude of 60 degrees, just isn’t worth it. Anything much below that and transparency really starts to drop off, gradients and HFD nmbers get much worse. To the point where 2 hours above 60 is sometimes better than twice that at lower elevations. I know it’s a big restriction but with careful sequencing of objects you can keep a system busy for an entire night and the quality of the data is just so much better. I wonder if those shooting under similar conditions are also following similar restrictions.
Helpful Insightful Respectful Concise Engaging
V avatar
This is exactly the method I use, however I never shoot under 45-50 degrees.
SonnyE avatar
I start at 30° fairly normally. It just works for my location.
Not every object I would like to collect runs high enough for me to limit myself to higher angles. Instead, I begin at my 30° limit and climb from there. (And 30° happens to clear the back fence well.)
Tonight, since everything is finally working as it should again, I’m imaging Bodes Galaxy in two different sessions, and the first started at 30° and is about to finish at ~45°. Then my second session will follow from 45° up to nearly 60° before it subsides.
The first is 100 images at 60 seconds each. The second will be 100 images at 180 seconds each. I think the 3 minute exposures will carry the rest of tonight.
Ah-Ha! It just switched from the first to the second. It’s doing the starting Slew, Center, And Rotate. Now the autofocus, and away it will go.
And me… away I go to bed and my CPAP. Tomorrow I should have two sets of files of Bodes to play with. Finally, things are working great again. Such a trying sport to play.
I bid you ado.
Brian Puhl avatar
Even in my fairly dark skies and flat horizons, I still have my limits. I don’t image below 45 to the north (It’s my only significant light dome) and I don’t go below 30 degrees in 95% of cases. At 30% I definitely take a small hit in sharpness, but it’s negligible.
In your case, being in the city, you probably have heat rising, causing some seeing related issues, as well as the light pollution, everything you say makes sense.
Rick Veregin avatar
Hi Tony
As you know, seeing and FWHM is affected by altitude in a big way, once you get below about 35 to 40 degrees. Here is one example of data on this, but there are many others you can find on the web that show similar or even worse shifts. http://brucegary.net/ASD/x.htm
Personally, about 40 degrees is my absolute limit for RGB (I don’t do a lot of Luminance), but even then I can see bigger changes than expected. My local problem is that the city and houses, including my own house, is around me, so the lower you look the more you are affected by local heating effects from roads, roofs, even trees, which degrade seeing as well. So unless you have flat fields around you seeing will worsen even more rapidly than this chart shows at lower elevations.
The second impact on FWHM is refraction. Our atmosphere refracts light, it acts like a prism, the lower the altitude the bigger the effect. This is huge for planetary imaging where an ADC (Atmospheric Dispersion Corrector) is required for the very best images, especially at low altitudes. This is a prism or set of prisms that can help correct the problem when properly aligned with the horizon. This effect is also present for deep sky imaging, especially with larger apertures. Looking at Pellier’s book on Planetary Astronomy at 100 mm aperture, without an ADC, his suggested B,G,R and L lower limits in degrees altitude are: 45, 19, 12 and 55! Luminance is the very worst as it has the broadest range of wavelengths input, which I think is why you specifically mentioned luminance as the big problem. At 350 mm he gives minimum altitudes of 74, 51, 36 and 89!
By the way, while Pellier’s book is on planetary astronomy, it goes through the detailed advantages and disadvantages of different telescope designs and the effect of the atmosphere and local conditions on imaging, aw well as being totally comprehensive on planetary imaging, so an excellent book I think even for those that don’t do planetary.
Rick
All good information. I do think that personal limits are going to vary widely depending on the aperture, sampling, wavelength and local conditions. I’ve been doing a lot of imaging lately at 0.38” per/pixel which is a lot more demanding and really is enforcing my personal 60 degree rule.
Noah Tingey avatar
I unfortunately don’t have the images easily on-hand to demonstrate this anymore, but with an LRGB image you can pretty substantially Gaussian blur your RGB data (more than you would think) without seeing much noticeable impact once you’ve added your luminance data in.
Not that I would recommend blurring your RGB data on purpose — I say this just to illustrate the point of how RGB sharpness matters much less than luminance sharpness. Because of this, I have my Target Scheduler plugin in NINA set up to prioritize shooting Luminance when my target is nearing meridian.
That’s a good point Noah. If you get all your resolution from your L frame, it makes sense to relax the standard a bit for RG and B. I think the limiting factor there will be gradients which will get progressively worse the lower you go.
Well Written Concise
Improving RGB imaging quality under Bortle 8 light pollution
On thing I’m really struggling with is getting usable R,G and B data under B8 skies. For bright, high surface brightness objects it’s not too bad but with slightly dimmer objects it’s a real struggle. Getting good data in the near Ir and anything nar...
Directly addresses RGB data acquisition challenges under light pollution conditions.
Mar 4, 2026
