EQ6-R PRO Speed Compensation
1 reply155 views
Xavier LEYRE avatar
Hi to all, I used the Speed Compensation tuning item (+/- ppm) on the SynScan Pro App on my EQ6-R PRO Mount . I used it with a +1000 ppm and it seems to work well . I tried a larger value (+2500 ppm) and it seems not to work , a larger value gave erratic results . I am wondering if there are limits on the parameter itself and I am quite convinced there are some . I would like to get your feedbacks on this very specific topic. I will continue to experiment : +1999 ppm to check the limit on my next try .
The method is the following : I take a serie of photos (10 sec each with 6400 ISO) for at least 10 mn and I use astrometry plate solving in SIRIL to recover the coordinate in J2000 in AD and DEC. Then I can follow the evolution (PEC off for the moment) and I recover a quite nice sinusoid : the inchworm periodic error plus a slight linear decrease of AD that I correct with Speed Compensation unit . A AD curve (unit are equivalent to asec of angle in Y axis, I delete constant value) . You can see the decrease linear decrease by measuring the top of the sine.image.png.a910fffd96fa8b2cfdf2a3aec17b20f2.png
Xavier LEYRE avatar
A new acquisition of post processed Plate Solving on 180 images on Alnitak with my EQ6-R PRO mount unguided , I think it is interesting and quite easy to do with SIRIL and a python script I can join if interested.
analyse_derive_ra.thumb.png.83b31ea190a9fe25f2d2e68f81486c8e.png analyse_suivi_eq6r.thumb.png.567570fb957aa8f7dfc2f1be8a7b6cfe.png
Opio - France
Canon 600D partiellement défiltré - SkyWatcher 90/910 Refractor - EQ6-R PRO Mount
Slew rate does not make sense
Hi, I have a problem where NINA (or possibly SynScan Pro or the mount) is slewing way faster in the RA axis than it thinks it is. This leads to the mount overshooting substantially and I have no idea how to fix this. The following is what I can see:P...
Speed compensation tuning directly addresses RA axis speed calibration issues.
Oct 13, 2025
Advice about Juwei 17
Hi, I am very interested in purchasing this mount, has anyone measured the periodic error? Is the height adjustment mechanism precise enough and not wobbly? Thanks to everyone who will share their experiences of using this mount. Clear skies Carlo
Mount speed compensation and precision tuning for tracking performance.
Apr 17, 2025
