How to determine proper exposure ratios between narrowband and broadband filters
3 replies110 views
Juju.Ziggy avatar
I just was curious how you guys determine the ratio between filters (narrowband + broadband or just narrowband). I have a hard time really knowing what I’m doing when I say I’m gonna shoot this amount of Ha vs this amount of anything else. Where can I check to see the amount per filter I should be capturing? Is there a normal ratio or does it differ with each target.
You'd want all channels to have the same SNR. Hardly ever you get to achieve that.
Ideally what Andrea said is the goal. I think what you want to shoot for is getting good signal from all the filters. How you combine the data will take care of the rest. Short answer is, don’t stress about it, just get good data that results in a decent SNR from each filter.
Mikołaj Wadowski avatar
Highly depends on the target and what you want to capture. In general, I would split the target into it’s components: individual narrowband channels and continuum/broadband.
Take M31 for example:
Just going for the main disk? An equal split of RGB is enough
Want want to capture the halo and ifn? Now you should capture some L too. The halo and ifn aren’t too faint, so it’s probably enough if you do a 2:1:1:1 LRGB split.
Want to capture the extragalactic Ha? Add at least a couple hours of Ha data.
Want to capture the foreground Ha? Make that couple dozen hours instead.
Ambitious enough to go for the Oiii arc on top of that? You’ll likely need tens of hours of Oiii data at least.
The precise data amounts per filter are highly variable. To estimate how much time you need per filter you either look at other images of that target, or look at NSNS and compare the brightness of your target to ones you’ve done previously.
Two good rule of thumbs I personally follow are don’t exceed like 4:1:1:1 LRGB split (after that point your color data will not support the lumiance enough imo), and keep the Narrowband/continuum ratio below like 10:1 so continuum subtraction doesn’t introduce significant noise.
RGB integration time for LRGB images (mostly galaxies)
Was just collecting some rgb data on Ngc 7217 and I was just curious; how long does everyone go for each filter when doing an LRGB image?? How much RGB do you think is sufficient to properly bring out good color in galaxies?? clear skies!!!
Discusses filter ratios and balance, directly relevant to RGB exposure planning.
Sep 27, 2025
Combining OSC data with dual narrowband data
I have a Zwo 533MC Pro and a L-extreme dual narrowband filter. I’m working on a project where I have about 20 hours of broadband data for M51 and 30 hours of narrowband data also for M51. I want to combine the detail and all the Ha data that I was ab...
Addresses determining proper exposure ratios between narrowband and broadband filters.
Jun 10, 2025
H-Alpha Solar Imaging on a Budget?
Hello, I have a potentially silly question, but I am curious about imaging solar flares and the like so I will ask. I have discovered that solar H-Alpha filters are extremely pricey and I am just wondering: [size=100]Would it be possible to have a &q...
Discusses narrowband and broadband filter ratios relevant to author's filter combination question.
Apr 19, 2024
Astro pixel Processor - How to combine a OSC broadband image and Extracted Ha and OIII from a dualband filter?
Hello All, I have a 2600MC-pro and have been using APP for a couple of years. I normally am only using 1 filter so no issues stacking. APP has been great. Now I would now like to take broadband subs and add the Extracted Ha and OIII from my antlia AL...
Combining OSC broadband with extracted narrowband filters addresses multi-filter integration.
Sep 5, 2025
