Asiair mosaic planning: why do panel rotation angles vary?
3 replies72 views
Benjamin DeHaven avatar
Quickish Question. Setting up a plan for a 3×3 panel mosaic of the Sadr region for the future. I’m new to the asiair ecosystem and never done a mosiac before anywhere. I noticed that the rotation needed for each panel is different. I would have expected a uniform camera rotation angle to get everything to line up perfectly. Is this an error? Is this because the sky is a “dome” going up to the zenith, so rotation angle is different for each panel? Just want to make sure… Thanks!
Benjamin
That’s about it. If you want the sides of the final mosaic to be square each panel needs to be rotated slightly. I think NINA has the option to rotate or not. It’s logical that the AIR uses rotate as the default as I think that’s what most people want. Th differences in projection won’t matter much unless you have a huge fov or many panels.
Jeramie avatar
There is angular rotation associated with how targets move through the night sky. These rotations can be more or less severe based on the target you are imaging and your location on the planet.
You can solve this in a couple of ways.
1. Learn to rotate your camera sensor precisely to match the rotation of your target as it moves across the sky. The ASIAir can help with this, but it is tedious in my opinion.
2. Buy a camera rotator that rotates the camera precisely and automatically to match your intended target framing as your target moves and changes angle.
3. Use a camera that has a square sensor. (Less important, but this has helped me with framing mosaics)
I like mosaics, and I found that having the large areas of overlap at weird angles induced image artifacts that were difficult for me to remove or solve for. Things like mismatched brightness/gradients, target framing, and other odd issues pushed me to spend the money on a rotator and camera with a square sensor.
If you're using the ASIAir platform, go buy their CAA. I love mine.
Jeramie
ItsMeAstro avatar
Indeed, rotations can be more or less severe based on the target you are imaging and your location on the planet.
An example is a mosaic of the Heart&Soul Nebula :
Example without rotation :
📷 image.pngimage.png Example with rotation :
📷 image.pngimage.pngList with position and rotation, copied from Telescopius :
📷 image.pngimage.png I’m using a (large) WandererAstro rotator, as I have heavy equipment Good quality, nice price and three different sizes, see :
https://www.wandererastro.com/en/h-col-126.html
Advice on Mosaics - Tips and tricks
Hello All, I will be sending my scope to a remote hosting facility very shortly. I will not be using a rotator and will do mosaics. I have never done mosaics before. I plan to set the chip at 90 degrees and just do mosaics when i need more FOV for a ...
Directly addresses ASIAIR mosaic planning and panel rotation angles for beginners.
Feb 17, 2025
Learning to process a larger mosaic.....is difficult
Hey All As summer draw closer, I set out to try and build a bigger mosaic. 2x7 panels. Nothing fancy, just a small constellation. I have acquired 1 hour of data for each of the 14 panels and then I need another 6 to plug a few gaps. Each individual f...
Relevant for understanding mosaic planning considerations and panel orientation setup.
Apr 2, 2025
Mosaics with ASIAIR - Help!
Hey everyone. Getting my spacecat51 ready for starfront. just testing the rig and making sure all is working correctly before i send it out. I will be using the ASIAIR plus and a 2600MC. I spoke to a number of people and they state that i dont need a...
Directly addresses ASIAIR mosaic planning and panel rotation angles.
Feb 11, 2025
Mosaic Question
A pick your brain question. I have not done a mosaic before, but am starting to think about doing so. Boiled down, as I understand it, you end up stitching together two masters (lets assume a two-panel mosaic) . When taking the subs for each master, ...
Discusses mosaic planning with Asiair; author is new to mosaics like the source post author.
May 6, 2025
