Fairly Cold Weather (15 degree Fahrenheit) and Tracking
10 replies277 views
Jerry Gerber avatar
When the temperature drops to 15F or lower, can tracking be affected?  I have a 10Micron GM1000 mount and the stars are looking slightly oval on some subs while others look fine.  If temperature is a factor, is there anything to be done with the mount that might improve this?
It's at a remote site, so I don't physically have access to it but can ask the observatory people to look at it. Up till now, the mount tracks very well.  I am imaging unguided with 180" and 300" subs.  I built a 100 star model and the polar alignment is excellent.
Thanks,
Jerry
Jan Erik Vallestad avatar
I don’t know, but it probably can have an effect. I regularly have to do a safety check on various nuts and bolts due to temperature changes as the metal expands and contracts. Things getting a bit loose will certainly have an effect. Internally I guess it also depends on what kind of grease is used as viscosity may change with temperature.
15F would translate to about -10c I think, which is a pretty standard winter temperature for my area. I can’t say I’ve noticed any changes in tracking however. I’ve been working my mounts at -30c without issues as well and they seem to handle it just fine. It’s within the specs at least which is something I’ve made sure of before buying anything.
You’re probably doing unguided subs then, so there’s probably no log to review in terms of finding any anomalies?
ArchStarGazer avatar
If it is very cold, tracking can be affected. I have an AM5 and in AsiAir I need to switch on “Heavy Duty Mode”, which slows down the mount’s movement. With this, it works also at -15 to -20 degrees Celsius perfectly.
Well Written Helpful Concise
Quinn Groessl avatar
I’ve never had an issue with my Skywatcher mounts even in to the negatives Fahrenheit. The grease gets a bit thicker, but my tracking with guiding has always been just fine.
Astro Jeep avatar
I have an AM5N, and I routinely track with round stars at 15ºF since I am often am at higher elevations. I use NINA, and I just use my normal tracking movement.
Dave Rust avatar
SfRO kept the roof open one night last winter at 11 degrees F and my AM5 tracked/guided just fine, though it was in “winter” mode.
There’s a type of grease designed for winter use…even at the poles. I suppose it would be possible to have the mount repacked with this compound.
Here’s a link to one brand as an example.
https://www.superior-industries.com/slc_400_product_115.html
Tommi Liinalampi avatar
I can use my both CEM70 mounts -20 celsius without problems. It’s my temperature limit because of EAF and other stuff.
Jerry Gerber avatar
Dave Rust:
Thanks Dave, I'll check it out.
Jerry
SonnyE avatar
I use what Scott Losmandy puts on his mounts at the factory, Super Lube Multi-Purpose Synthetic grease.
Good to -45° F (-45°F = -42.778°C) or Pretty damned cold.
Of course, Your Milage May Vary depending on your mount.
My weather generally here rarely goes below freezing (32° F) so I never worry about it. And for good cause, my mount never has a problem.
But if people think they are smarter, and use some water pump grease in the fine machinery of their mounts, well that is operator error.
Ruediger avatar
Hello Jerry,
-10°C is not a big deal for the 10M. They work down to -15°C with normal grease and with adaption to cold environments with special grease down to -40°C . I advise to turn on the motor preheating in these temperatures to avoid current peaks when slewing. This is exactly the use case for the heating. It heats the motors for 120 Seconds. Chapter 6.3.17 in manual V3.
Tracking is not impacted by the mount, but due the changed flexure of the gear. So the model could differ a bit. If you notice it, just create a new model. That’s all.
CS - Rüdiger
Jerry Gerber avatar
Ruediger:
Hello Jerry,
CS - Rüdiger
Thanks Ruediger,
Everything is back to normal now.  During the winter months, or when humidity is high, I am going to leave the mount powered on 24/7.   I think that's the best approach from what I've learned from others.
Solve & Sync
I am getting advice to delete Solve & Sync from the NINA advanced sequence because I have already built a 99 star model using 10Micron Tools. I am imaging unguided and getting excellent results. Should I follow this advice? Is the model itself al...
Cold weather tracking issues relevant to mount model performance.
Jun 15, 2025
