Richard Jones avatar
I am retired and on a small pension and so I need to find a low budget option to make my Astronomy hardware work easily with the right software. I’ve looked around and there are a mesmerising number of solutions, which all seem to have difficulties.
My Hardware
1) SVBony SV705C camera, just bought for taking good pictures
2) Sky-Watcher Star Adventurer GTI Equatorial Mount
3) Bresser Solarix 114/500 Newtonian Reflector
4) Macbook Pro late 2014 running on High Sierra OSX
5) Altair GPCAM 0130C - For Guiding and lower definition pictures
I have looked around for a solution and many seem to use a Raspberry Pi but all seem to have difficulties. There seem to be many options for getting this to work. I live and I’m constricted to a Bortle 8-9 location with limited visibility the horizon being 20 degrees altitude. With my disabilities I find it practically impossible to align the mount using the inbuilt finder.
Questions
(a) Is there a trick to using the Sky-Watcher inbuilt finder , when you cannot get down low?
(b) What is the best free software to capture images fromSV705C?
(c) What is the quickest and easiest method way to align my mount with few visible stars?
bigCatAstro avatar
For my better understanding, are you saying that you don’t have visibility after 20 degrees altitude?
Well written Respectful
No. Basically my visible horizon starts 20 degrees above the actual horizon and so I cannot see a star unless it has over 20 degrees altitude.
AstroRBA avatar
But it also sounds as if you can’t see Polaris with the built in polar scope?
I could see Polaris if I was physically able to reach the eyepiece but it is too low for me to stoop because of my disability.
I tried to use a mirror but found that too difficult
bigCatAstro avatar
Richard Jones · Jan 7, 2026 at 02:15 PM
Alright, thank you for clarifying. So, there are several options for your situation and I’ll try to answer your a-c questions with them.
A) With an image capturing and mount controlling software like NINA or KStars/EKOS (more on these later), you no longer need to use the built-in polar finder. Instead, just rough/daytime polar align your mount. The strain wave mount I use doesn’t have a polar finder at all, so I use the app PS Align Pro in daytime mode to get close. You can use a properly declination-calibrated compass or even your phone’s compass to do this step as well.
B) For imaging and mount controlling software, you’ll probably get a number of answers—both regarding hardware and software.
Are you thinking about using your Mac for image capture/mount control? I don’t have experience withMacOS for this function, so I’ll leave it there, but I have used Macs for image processing and they are great.
If you already have a RPi, you could either install KStars and EKOS manually or you can get it all packaged together with the StellarMate platform. Currently, StellarMate for RPi is $59 USD. Personally, I would pay the fee in order to have a packaged and fully functional installation of KStars/EKOS, but that’s my preference. There’s also Astroberry which is free and packages KStars and EKOS. There’s a small community here that uses it and might be able to help you.
Finally, I use NINA on a Windows 11 Pro mini pc (MeLe Quieter series). NINA is free, but the cost here will be getting either a mini pc or a Windows laptop since NINA is only Windows compatible.
There are more options, but they do get more expensive, so I won’t list them.
C) The image capturing/mount controlling software should have a Polar Alignment routine built in and will use your main imaging camera to align with. NINA and softwares using EKOS can polar align to any star and don’t need Polaris to do so (Polaris is obstructed from my view by trees, so I know it works). It will pick-up more than enough stars, I also image in B8 conditions and it is excellent.
bigCatAstro · Jan 7, 2026, 04:14 PM
C) The image capturing/mount controlling software should have a Polar Alignment routine built in and will use your main imaging camera to align with. NINA and softwares using EKOS can polar alignment to any star and don’t need Polaris to do so (Polaris is obstructed from my view by trees, so I know it works). It will pick-up more than enough stars, I also image in B8 conditions and it is excellent.
Thank you for your suggestions. I will definitely use the Macbook for image capture and processing because I am more familiar with that. For guiding and alignment I will probably get a RPi as feeding all the cables to the laptop would be too physically cumbersome. Thank you very much for your help.
Cole Fenger avatar
KStars/Ekos is Mac compatible so I would start there as a free piece of software that would be your full control suite. This would have your polar alignment tool (so no need to use the polar scope on the GTi). Use PHD2 for guiding which is Mac compatible and that will connect to Ekos for guiding. Ekos will connect directly to your main imaging camera for imaging/sequencing control.
In my opinion, KStars/Ekos is a little harder to learn than NINA, it’s also just less popular so there is less content out there to learn from, but it has a lot of the same features and it is Mac compatible whereas NINA isn’t. Spend some time watching tutorials, reading documentation and working with the software while you have everything connected during the daytime in the comfort of your home to ensure that everything is connected and you are familiar with the controls before you take everything outside in the dark.
One area of concern I would have would be the age of your MacBook and the OS: According to the release notes- the latest supported release for KStars/Ekos is 10.15. You are running 10.13. A Late 2014 MacBook Pro Should support up to MacOS 11 BigSur (released in 2020). If you can update to that - it should solve a lot of potential compatibility issues with both KStars and other software. However, you are capped at that version and Intel Macs are quickly going out of support so I would’t expect too much more life out of that machine. (keep in mind it is 11 years old) If you are willing to make the switch to Windows eventually - that would be much more cost effective than upgrading to a new Mac when the time does come that support gets completely dropped.
EDIT: Saw your reply that you are going with an RPi - I think that’s a great option to run KStars and Ekos as well!
Well written Helpful Insightful Engaging Supportive
Cole Fenger · Jan 8, 2026, 04:25 PM
Thank you for that very practical advice. I shall try the Kstars/Ekos on my current Macbook and see what happens. I think I may have to upgrade my laptop as there are increasing difficulties with all my software over time.
You can run NINA on a MacBook (I did, same vintage) if you install Windows (10) with BootCamp on a separate partition.
Well written Concise
Noah Tingey avatar
Here to also recommend NINA. It’s windows only, but as Andrea suggested you could run BootCamp on your Macbook (if it’s an Intel macbook — pre-Apple Silicon). Or you could get a cheap windows mini PC… can often find a used MeLE Q3 for like $150 or so.
Actually @Richard Jones I have an old Beelink SER windows mini PC that you can just have for free if you’re willing to pay shipping. I’m in the US. It’s not a blazing fast computer but it’s certainly capable of running NINA. It’s just collecting dust at the moment. Send me a DM if you’re interested.
One thing I haven’t seen mentioned yet is that NINA has a plugin called “Three Point Polar Alignment” that allows you to polar align without needing to see Polaris and without the uncomfortable ergonomics of using a polar scope. My girlfriend (who has terrible back issues and has had a few spine segments fused) can polar align using TPPA without any pain, whereas she is straight up unable to use a traditional polar scope.
One other advantage of NINA: It lets you build a custom horizon so you can have your scope start/stop imaging or switch targets based on when your targets get near the horizon.
bigCatAstro avatar
Noah Tingey · Jan 8, 2026 at 07:25 PM
Yes, TPPA is great. It was mentioned, but not by name.
Noah Tingey · Jan 8, 2026, 07:25 PM
Thank you for that suggestion I will look into Windows PCs as well.
After doing some research on all the options, I have decided to try the following.
1) Update the OS on my Macbook to OSX11 Big Sur, to make it compatible with faster software.
2) Put Kstars/EKOS on the Macbook as a prototype trial.
3) Use a Raspberry Pi 5.0 running Astroarch with Kstars/EKOS to control the mounting and the fast processing power needed for the image capture.
4) Process the captured data on the Macbook
I would like to thank everyone for their very helpful suggestions, as I was a bit lost beforehand. Also thanks for the very kind offer of some hardware. As a newbie I am very impressed by this site.
Respectful Supportive
bigCatAstro avatar
Richard Jones · Jan 9, 2026, 09:17 AM
I think this should work out fine and is a good choice. Personally, I would have gone with StellarMate OS since there is a larger user base and support, but this is a good choice as well.
bigCatAstro · Jan 9, 2026, 04:43 PM
After digging a bit deeper I agree. I think that the StellarMate OS is a better solution and so I think I will go with that. Thank you for that suggestion.
TiffsAndAstro avatar
Richard Jones:
I used Nina via bootcamp on my 2015 MacBook Pro and it worked great.
Your 2014 MacBook, as long as it's an itel CPU should do the same.
TiffsAndAstro · Jan 15, 2026, 03:22 PM
Richard Jones:
There are a bewildering number of options. In truth I have had virus and disk problems with Windows , which is why I switched to Mac. My last PC died on me after a year with disk problems and was painfully slow because of anti-virus ware. NINA does look nicer and cleaner, more professional and more expensive but I really just want something that works.
Rainer Ehlert avatar
Richard Jones · Jan 15, 2026, 03:31 PM
NINA is free of charge… 🤔
bigCatAstro avatar
Rainer Ehlert · Jan 15, 2026, 05:14 PM
I think he may have been referring to getting a new miniPC/laptop in terms of the cost in order to run NINA. Granted, as others have noted, Bootcamp could be potentially used if the CPU is an Intel made one.
Personally, I believe the OP’s original plan of using a RPi 5 with StellarMate OS will be fine. A RPi 5 kit is about $175 and StellarMate OS is $65, those two items are still cheaper than buying a miniPC like the MeLe Quieter 4C.
There are cheaper fanless stick miniPCs or ones with fans (the DreamQuest looks interesting), so if the OP wants to run NINA there are many low cost options (used laptops, etc.) out there.
Tom Gray avatar
Hi Richard. I am one of those users who looks to lower cost/DIY options where possible, partly to encourage others with what is possible with a lower cost setup. I use RPi5 single board computers running Stellarmate OS with two setups, a widefield camera/lens on a Skywatcher star adventurer 2i and a vintage Meade 8” SCT on a secondhand EQ6 r-pro mount. I use low cost software - principally Siril and SetiAstro Pro and support developers who freely offer their products to the community.
(a) Is there a trick to using the Sky-Watcher inbuilt finder , when you cannot get down low? Yes, you can use an inexpensive right angle viewer - mine is from an old SLR camera.
(b) What is the best free software to capture images fromSV705C? Stellarmate OS (indi) is low cost, but many others - APT astrophotography tool (ASCOM), Sharpcap, etc
(c) What is the quickest and easiest method way to align my mount with few visible stars? Use inbuilt reticle in StarAdventurer (with right angle viewer) to place polaris within polar alignment rings as SA Console App. This is good enough for basic imaging. For an accurate polar alignment, use software based polar alignment routines using platesolving to make fine adjustments.
Hope this helps. Tom
bigCatAstro avatar
Tom Gray · Jan 16, 2026, 01:47 PM
Interesting mention with APT, I totally forgot about that platform. APT is a good platform to pair with DSLRs and there is a generally “easier” learning curve to it.
However, I believe NINA has surpassed it as a “modern” system with NINA being a more powerful tool.
Tom van Peer avatar
I have a 2012 MacBook Pro here running Sequioa. If you are willing to spend some time on it, there is a way to get your MacBook to run the latest version of MacOS as well. The tool needed is called OpenCore Legacy Patcher and it supports Apple systems going back as far as 2008. I would advise to only use this if you have 8GB or even 16GB memory in your system. MacOS will run in 4GB but you also want to run some memory hungry applications if you want to do image processing.
Wim van Berlo avatar
Richard Jones · Jan 15, 2026, 12:24 PM
I started out with Ekos/Kstars an a raspberry pi before it had usb3 ports and before it was 64 bit. I then moved to the same on a Rock64 sbc. Both configurations required a lot of tinkering, but that was years ago, long before NINA or ASIAIR. Astroberry on a Raspberry Pi 4 was easier, and more stable, but Astroberry hasn’t been updated for several years now, as far as I know. I switched to Stellarmate which I have installed on a Raspberry Pi 4 and a Raspberry Pi 5 as backup, because of its stability, and because I wanted to contribute to the development. Stellarmate has been stable out of the box, just make sure that you have star catalogues (index files) that match your imaging setup. I connect to it over vnc, rather than the app, because I’m used to it, and because the app isn’t stable on my old Galaxy Tab. Stellarmate has a built in 3 point polar alignment routine. If you need to set up for every session, I suggest that you mark where the legs of the tripod should be positioned to get an initial alignment. Either drive three nails into a wooden deck, or (what I did) drive three fence post anchors into the lawn where you set up. If you have your own back yard, consider making a pier from concrete blocks and either leave the mount head on that (covered) or make a mount base for easy set up.
Btw, the main causes for possible instability in Ekos are insufficient wifi signal strength or insufficient power. I use an ethernet cable to connect the Raspberry Pi to my home network and a 3A 5V power supply, and that has never failed me.
Wim
Best astrograph for under $500
I'm looking at getting a better telescope for astrophotography. But my budget is limited. It has to work with a star adventurer 2i so reflectors are probably out of the picture. I found this would it work? https://a.co/d/be0MO4V
Software solutions could help maximize value from limited astronomy hardware budget.
May 8, 2024
CG-4 Polar Alignment & Autoguiding Options
Hello, I am very new to the hobby and currently have a Celestron CG-4 mount. I have started to get curious about if there is any way to autoguide with this mount despite it being kinda low-end. I briefly did a little bit of googling and it seems like...
Addresses budget software solutions for connecting mixed astronomy hardware together.
Jan 13, 2024
Paramount MyT + TheSky + Nina
Hi All, I bought a new MyT recently and finally got it out for a test drive last night. I've mainly used ioptrons with Nina prior to this so it was a learning experience. I'm wondering how many of you just use the TheSky for imaging control, ...
Budget software solution for connecting mixed hardware to imaging setup.
May 30, 2024
SVBONY, Any good?
SVBONY seems to pride itself on budget Astro equipment. As a beginner in astro photography it is useful to hear of real world opinions, as the cost of getting up and running can be expensive. I am not at all interested in equipment snobbery, such as ...
Budget software solutions align with author's focus on affordable astro equipment.
Jan 11, 2025
Optimized Newtonian - Is it worth it?
There are a lot of ways I can think of that the current crop of Newtonian Astrographs can be improved. Lets restrict the conversation to apertures between 6 and 10 inches. 1.) Lowering the focal plane relative to the side of the tube (eliminate the f...
Discusses Newtonian reflector optimization; author owns Bresser Solarix Newtonian.
Jul 28, 2025
