Automating ZWO ASI2600MM Dew Heater with NINA
Jerry GerberRick Krejci
28 replies350 views
Jerry Gerber avatar
Is there a way to automate the camera's dew heater using NINA's advanced sequencer so that if the humidity rises above, say, 70% or the dew point is within, say 8c from ambient temperature the dew heater will turn on and if it drops below a given value it turns off?
I'd love to find out if it's possible.  Right now, I manually turn the dew heater on and off, but it's probably on a lot when not necessary…
Jerry
Rick Krejci avatar
I just leave it on even though I’m in a dry climate. Better safe than sorry.
Quinn Groessl avatar
I use a Pegasus Powerbox, looking at the equipment in your photos I think you do too. So if you have that and their temperature/humidity sensor, you can just use their software and leave it on auto.
Concise
Jerry Gerber avatar
Quinn Groessl:
Hi Quinn,
Yes, I use the Pegasus Powerbox and it automates the dew STRAP on the telescope but not the dew heater in the camera.
I'm wondering if there's a way to automate the dew heater in the ASI2600MM..
Jerry
SonnyE avatar
Like Rick, I just set it, and forget it.
For the longest time I was a bit paranoid about it running on its own. But I grew up and decided to trust it while it is, after all, covered by ZWO warranty. (Which ain’t saying much in my experience.)
I have it on in NINA. No Problems. Let the camera decide.
Jerry Gerber avatar
The camera doesn't "decide".  It's either on or off, whether it's automated in NINA or whether it's done manually.
I prefer to have control over when it's on based on the dew point and humidity.   I'm glad you grew up but that really has nothing to do with what my question was.
Rick Krejci avatar
I understand what you’re trying to do and why, but unfortunately I don’t think there’s a way to automate it in Nina.
Jerry Gerber avatar
Rick Krejci:
You may be right, unless there's a script in Nina's advanced sequencer I don't know how to do it.  My scope is at a remote site where the humidity can range from quite dry to very high, so it makes sense to try and sync the camera's dew heater to the humidity.
Rick Krejci avatar
I asked chatgpt, and it pointed me to the post below in a thread on CN that, if you use the native driver,there’s a command to do it in a sequence. If that’s the case, you should be able to use the sequencer powerup plugins and set temp and humidity/dewpoint in variables and use the delta to turn it on and off.
I no longer have a Zwo camera (moved to Player one) so I can’t see if there’s an advanced sequence command to do it.
https://www.cloudynights.com/forums/topic/929173-nina-and-dew-heater/#findComment-13564691
Jerry Gerber avatar
Rick Krejci:
Yeah, I did the same thing, I asked Google and got the same answer, which is to use the native ZWO driver.  I am using the Native ZWO driver, not the ASCOM driver and I still am not clear as to how to set up the Sequencer Powerups (which I use all the time) to set this up.  I know how to tell the camera to turn on and off the dew heater with Sequencer Powerups but I don't know how to link it to the humidity..
Thanks for checking!
I'll keep investigating this.   I bet there's a way to do it.
Rostokko avatar
Jerry Gerber · Jan 8, 2026, 12:20 AM
If you have a weather device set up in nina, you could use powerups triggers based on an expression which uses the weather humidity (exposed as a variable automatically) to turn on/off the dew heater.
Rick Krejci avatar
I just tried this in Nina and it works!
I use OpenWeatherMap as my weather source, and it provides Temperature and DewPoint
Rick Krejci avatar
Actually, you’d probably want a hysteresis so it doesn’t toggle at the border value
Jerry Gerber avatar
Thanks Rostokko, yes, NINA is connected to the observatory's weather data.   Where can I learn to set up an expression? I see the Dew Heater command in the Advqnced Sequencer but not sure how to add the expression.
Jerry Gerber avatar
Rick Krejci:
OK I'll try to copy what you did Rick, not quite sure how to put the expression in, but I'll give it a try.
Does the Expression go in the Global Triggers or in the Main Instruction Set, or does it matter?
Rick Krejci avatar
If you hover over the white “i” in a circle on the left, it will list all of the parameters available. Just type them just as they appear there. In this case Temperature and DewPoint were defined in the weather column.
This made me think that I’ve recently added my own weather station to WeatherUnderground, so I added it to the weather option instead of OpenWeatherMap and connected. So now my temp and humidity are from a station 20 feet from my scope :)
You may be able to get it from your pegasus box if it’s listed in the hover parameters.
Rick Krejci avatar
Rostokko avatar
Jerry Gerber · Jan 8, 2026, 02:03 AM
Powerups documentation may be a bit cryptic at times, but it’s very useful. I myself would implement this as a When trigger probably: https://marcblank.github.io/CVE/#when. Rick provided good hints about the expression(s) you want to use.
Jerry Gerber avatar
Here's what I've done.
It's working.  Fantastic...
Rick Krejci avatar
Rostokko · Jan 8, 2026, 02:15 AM
Yea, you’re right on the when trigger if you want it in the trigger section. I’m very new (weeks) to the powerups, so learning a lot today.
Jerry Gerber · Jan 8, 2026, 02:47 AM
After reading the powerup docs, I guess I’m surprised that would work continually being in the global triggers section. I think Rostokko’s suggestion of using a when trigger which would execute between each instruction without it being in the instruction section would be appropriate. If I understand correctly, the if statements would normally be in the instruction area and be executed sequentially with other instructions there rather than continually in the triggers section.
Jerry Gerber avatar
Rick Krejci:
Yes, I see what you mean, that's the question I started thinking about.  In the Global Triggers section, I think it would only work once, at the start of the sequence.  When I try and drag "WHEN" to the anywhere in the sequence nothing happens...
Rick Krejci avatar
Jerry Gerber · Jan 8, 2026 at 03:30 AM
Rick Krejci:
You can’t drag “when” to the triggers section? That’s where it should go. There it will be evaluated and the associated instruction would run between each instruction in the main section. I would also put a little more space between the on and off condition in case the humidity is fluctuation right at the edge. Give it like a 1% buffer between on and off.
Concise
Jerry Gerber avatar
Maybe this is better and will work repeatedly as the humidity changes:
I dragged it to the Triggers section (not Global Triggers) and I think that's where it belongs.  It dragged successfully.
Rick Krejci avatar
I think you’ll need another to turn it off, maybe at <63
Jerry Gerber avatar
Rick Krejci:
That's what I think too, I'll test it out on the next clear night.
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Discusses dew heater solutions and practical experience with dew prevention methods.
Nov 28, 2025
MGP Box
I use the MGP Box to switch on (and turn off sometimes) my 10MicronGM1000 mount. I am finding that's all it's good for. It almost never connects to GPS satellites even though it's sitting on top of my scope, has a completely unobstructed ...
NINA integration with environmental sensors for automated dew heater control based on humidity.
Apr 20, 2025
My Solution:Turn an uncooled camera into a cooled one
I have a Player One Uranus-C planetary camera. This camera is uncooled. Player One uses passive cooling, which I wanted to improve. So I chose a smartphone cooler, the Shark FunCooler 3pro. It runs quietly with minimal vibration and features active c...
Automation strategies for camera cooling systems and temperature management.
Jul 7, 2025
Powering the asi2600mc
Dear AstroBinners, If I run the cooler at -25 below ambient - how long will a 10.000mAh power bank last on a 2600 camera? Thanks!
Dew heater automation discusses power management with ASI2600 camera.
Jun 14, 2024
