UV/IR filter (L-Pro or Astronomik L-3) + L-Extreme in the same optical train
6 replies161 views
Frank "Voloire" avatar
Since I have an ASI 533MC Pro without any UV/IR filter, I was thinking of permanently mounting an Optolong L-Pro filter in the dedicated thread of an ASKAR SQA55 (Petzval design). I would then also use a ZWO filter drawer in the optical train to sometimes insert an Optolong L-Extreme filter when I need dual narrowband, or leave the drawer empty when I want to do pure broadband. Will this setup work? I also have an Astronomik L-3 filter, and I'm under a bortle 4 sky.
Happy new year and thank you!
Doug Crowe avatar
Not sure why you would want extra glass in your image train? If you have a filter drawer, wouldn’t it be just as easy to have a couple extra sliders and use a single filter depending on your target? Just my opinion.
Hey, thank you for taking the time. My biggest concern in swapping filters (I do it all the time) are basically the flats.
Since I have always the need of an UV/IR filter since the 533 get just a AR glass I was thinking to reduce the possibility of introducing dust mote and stuff while swapping the filters and then crushing into a "flat drama" so to speak :-)
But I got your point and it make sense to me.
Rick Veregin avatar
With the L-Pro there you will lose something like 5% to 10% of the light in Ha and OIII compared to use the L-eXtreme alone. The L-Pro also is not particularly great with halos and reflections, so doubling up filters is not the best idea, you may get reflections between them.
I know it is more expensive, but a filter wheel is a wonderful option. With the drawer option you probably want to have each filter in a separate drawer so you can easily slide them in and out quickly, with many filters this gets expensive too. Taking the time to unscrew and screw in filters increases the risk of dust and dropping them in the dark, etc.
If you ever think you want to expand your range of filters, for example the L-eNhance is an option I use as a strong LP filter, while the L-Ultimate is best for pure NB targets, or if you want to try SO sometime, which I do. So after using drawers I got a filter wheel and love it. Like you I hate doing flats: with the filter wheel get everything pristine once and then it stays that way. As I virtually never take my train apart, I have used wheel for 6 months and four filters so far and have never yet had to retake flats. It is so easy.
Rick
Rick Veregin · Jan 6, 2026, 04:07 PM
Rick
Yop, I already use a wheel for the other scope even with the 2600mc: no-filter, l-qef and l-ultimate :-) On this other rig was thinking about a shortcut, but hey everyone of you is completely right. Dropped the “idea” :-) Manually switching and call it a day! Thanks for taking the time to answer everyone.
Armin Lukas avatar
Under B4 sky, is there really an improvement with the L-pro filter? I think leaving the UV/IR filter in the image train and use the l-extreme for duo narrowband should be a good option. But there is some loss due on more glass in the optics.
The better option would be like Rick mentioned, to use a filter wheel.
Armin
Guillermo (Guy) Yanez avatar
Hi. I own an SVBONY filter drawer that comes with two drawers right out of the box. You may order an additional one and have your three filters easily interchangeable. That said, you will need to get new flats after any filter change. The filter wheel that someone already mentioned may also be a great idea, even if it is a manual wheel (those are cheap). For me, the filter drawer works great.
Under Bortle 4, I would try the Astronomik L‑3, as I do not see any advantage in using the L‑Pro over the L‑3 under such dark skies. You could still compare both and see what works best for you. Broadband Optolong filters are great but may introduce halos in your images. Try the L‑eXtreme when imaging nebulas.
I would not recommend using two filters at a time, as there are always reflections that may cause more halos and distortions, and you will also sacrifice a certain amount of light‑gathering power by going that route.
Well Written Helpful Engaging
ASI 533 MC Pro Uv/ IR cut
I would appreciate any feedback regarding the use of a UV/ IR cut filter on an ASI 533 MC Pro camera. If I add a Baader UV/IR cut filter as 'semi-permanent' screw-on to camera does this equate to the 2600MC out of the box? The screw in filter...
Discusses UV/IR filter mounting on ASI 533MC Pro camera with filter wheel compatibility.
Mar 28, 2024
UV/IR Cut Filters - Advice Please!
Hi folks: After recently working with data with more natural colour stars than I am able to get from my Optolong L-Pro even after SPCC, I've been rethinking my broadband imaging filter choice. I live in Bortle 7, and currently image with an Astro...
Directly addresses UV/IR filter selection and mounting for ASI 533MC Pro camera.
Aug 27, 2024
Pixinsight Help - Processing OSC data plus mono camera Luminance data
Hello, I recently acquired a mono 533mc camera. I captured luminance data on ngc 7331 with a uv-ir filter. I already owned a 533mc color camera and had some OSC data on the same target. I want to add the luminance data to my OSC dataset to improve th...
Processing OSC data with mono camera; discusses 533MC and UV/IR filtering techniques.
Sep 1, 2025
Would you replace the Built in UV/IR cut on a 2600MC with AR glass?
Hello All, I am looking to replace the built in UV/IR cut window on a 2600MC-Pro with AR window and using a better UV/IR cut filter with better cutoffs in the UV and IR (Baader cmos optimized UV/IR cut filter) so i get less UV and IR and better glass...
Replacing built-in UV/IR cut; explores external filter alternatives for ZWO cameras.
Sep 18, 2025
Filter Drawer Solutions and Mono Workflow for RASA 8 with ASI 2600MM Pro
Hi everyone,I recently bought a RASA 8, which I plan to use with my ASI 585 MC Pro. However, I also own an ASI 2600MM Pro and would love to use it with the RASA 8. Unfortunately, I’m struggling to find a suitable filter drawer solution.I came across ...
Discusses filter mounting solutions for ASI cameras in optical train.
Nov 26, 2024
