Multiscale Adaptive Stretch MAS in PixInsight
Rainer EhlertFerran Bosch (S.A.C.)Robert Houghton
36 replies1.3k views
Rainer Ehlert avatar
Two days ago I heard about MultiscaleAdaptiveStretch
I have been playing with it and as an advanced beginner I like it. It saves me a lot of pre-stretching time with HistogramTransformation (Sorry, Never understood GHS 😵‍💫?
I also tested VeraLux… but with MAS I got a result that I liked faster than with VL…
Below an example of one of my wide field of HT and MAS. Sure I need to refine the settings but as a first result for me it looks quite good. What I like is the possibility of defining the background value and so you always get the same? background value. Also the ability of stretching the single LRGB Ha OII and SII images is great as you get the same background value of all. Which was nearly quite impossible using HT. IMHO
What do you think about MAS? if you have tested it.
HT stretching and fiddling around + NXT
MAS stretched and fiddling around + NXT
From other tests of MAS verses VLS I’ve seen it looks like they both get you to very much the same place with VLS leaving behind a slightly nosier result.
Tom Marsala avatar
Played with it all day today. It's not too aggressive and creates a great starting place. If you change some default settings on STF you can achieve similar results.
Tom
Ferran Bosch (S.A.C.) avatar
Rainer Ehlert · Jan 1, 2026, 06:49 PM
For me, Veralux ‘paints’ the colour, making it very pleasing to the eye, but it does not respect the highlights, saturating the bright cores too much, such as the cores of M31 and M42, to give two well-known examples. I always use Masked Stretch for this reason, it stretches the image very well and protects the highlights excellently, however it ‘washes’ the colour too much for my taste, so I have found a way to combine the stretching of Veralux with the unbeatable highlight protection offered by Masked Stretch. I am working on a script that is a mixture of both, good colour and lighting, and proper protection of the highlights. Veralux does not use masks, so even if you add a mask to the unstretched image, Veralux does not take it into account, and that is what I have solved. As for MAS, it is very similar to Veralux, but it respects colour and contrast much more, although sometimes that is a matter of taste. I think we are in a competition of stretchers, from which only good things can come, as competition always produces benefits for everyone.
Robert Houghton avatar
I’ve looked all over and cant find it . It says its installed .
Cyril Richard avatar
Ferran Bosch (S.A.C.) · Jan 2, 2026, 09:27 AM
If you use the veralux from the Siril application, cores will not be saturated.
ArchStarGazer avatar
Robert Houghton · Jan 4, 2026, 06:07 AM
Do you mean Multiscale Adaptive Stretch? MAS came with the latest update (1.9.3 build 1646) and you find it under Processes (both under <all Processes> or “Intensity Transformation”).
Well Written Helpful Concise
Arun H avatar
For those who have used it - is it a game changer?
BryanHudson avatar
MAS motivated me to do my first update to PI in two years.
I'm getting the results that I want in less time. I don't want to grind with PI processing using GHS. It is the tool for people who want to go deep and spend extra time processing.
However, I don't think the squeeze is always worth the juice.
When I'm watching a YouTube tutorial and someone starts using GHS, I go somewhere else. :-)
Intensity Transf.
Rostokko avatar
If you don’t find MAS after installing the update, go under Process > Modules > Install Modules and press the Search button; it will typically tell you that one (or more) modules were found; click Install; done.
Cyril Richard · Jan 4, 2026, 07:03 AM
And why does it saturate in PixInsight?
Arun H · Jan 4, 2026, 08:42 AM
No, IMHO, I use Masked Stretch and then a curve transformation, and honestly, I don't think there's any difference, especially considering that after running MAS, I continue to process the image and make changes to colour and intensity.
GiffS avatar
I have played with MAS a number of times now and I have to say it is very impressive. Of course you can arrive at the same result, or close, with STF , GHS and Curves adjustments but this gets you there in one go. Depending on what you’re after in terms of a result some additional work in Curves or GHS will be needed but much of the early careful time spent in GHS and Curves is now not needed.
What is needed is a new workflow. What I have been doing is BXT(correct only)>SPCC>SPFC>MSGC>MAS. (Of course in order to do the early steps it is helpful/necessary to use STF) As I have said before, I think PixInsight is probably the best money I ever spent in astrophotography. In terms of what it has done for my end result and how straight up professional they are about updates and improved functionality it isn’t even close.
GiffS · Jan 4, 2026, 02:37 PM
Why do you calibrate the colour first instead of the flow? Can you explain why?
What is really a game changer?
I tested it and now I am using it and it saves me a lot of HT, HT, HT, … and I get to a better result faster which then I can tweak finer, maybe maybe not. I made some images and I did not even find it necessary to do any tweaking.
It is a question of R&D or Trial & Error…
¿game changer? I do not know but a Time Saver, Yes for me
George Hatfield avatar
I have yet to see anyone using MultiscalAdaptiveStretch for starless images. My routine is to always work on the stars separately, which gives me good control. For the starless image, I either use SetiAstro’s statistical stretch and/or GHS. So the new tool does not seem to be that useful, at least for me. Am I missing something?
bigCatAstro avatar
George Hatfield · Jan 4, 2026 at 05:40 PM
I’m still using SA’s statistical stretch too, however; I did see that Frank has updated stat stretch for SAS, but will not be updating the PI script. I hope the PI script isn’t discontinued, but as a precaution, I will start experimenting with MAS.
Tomvp avatar
Same here. I practically always split my images to process stars separately. Then GHS for the starless image and SetiAstro starstretch for the stars. And I keep them separate in Photoshop, so when I change the colours in the starless image, the stars aren’t affected.
George Hatfield · Jan 4, 2026, 05:40 PM
You are not missing anything IMHO
If what you do works for you nobody is going to force you to use a tool which does not fit into your workflow
It is just that easy 😉
Ferran Bosch (S.A.C.) · Jan 4, 2026, 03:07 PM
Rainer Ehlert · Jan 4, 2026, 06:52 PM
Ferran Bosch (S.A.C.) · Jan 4, 2026, 07:14 PM
I did put an answer but was bot sure about it. Sorry.
I wrote that maybe that could have been a typo. First I need to check if it is possible to SPCC before SPFC…
¿OK?
… and I have not yet found how to delete an answer. Looks like it is not possible ¿?
Gordon Pegue avatar
¿OK?
If I remember correctly, I believe SPFC is needed before using MSGC. I’m not sure that using SPFC before (or after) SPCC does anything useful. But since I’m still on the middle slopes of my personal processing learning curve, I could be entirely wrong about this….
Rainer Ehlert · Jan 4, 2026, 07:21 PM
¿OK?
Hola Ferran,
OK, just tested it and yes you can SPCC before SPFC…
That was my incognita…
y nuevamente Mil Disculpas por poner un puntito…
How dark is really the dark DSO background?
Hi, Somewhere in the Internet I read the darkness of the DSO background is 27.42 mag per square arcsecond. What would that be in RGB values ? 🤔 I always try to get my background between 10,10,10 and 20,20,20 … ¿? 📷 image.png
Discusses PixInsight processing techniques relevant to background level adjustments.
Dec 30, 2025
Strange grainy artifacts in background when applying NXT - normal or error?
Is this normal or am I doing something wrong? When I apply NXT, I get really strange grainy artifacts in the background. It looks like colored specs all over the image (see below). Doesn’t appear to matter whether I do NXT early in processing on line...
NXT artifacts may relate to post-processing stretching issues similar to MAS workflow.
Sep 29, 2025
