Antlia Dark Series LRGB Pro Imaging Filter Set - 2" Mounted - anyone using?
11 replies285 views
JohnAdastra avatar
Is anyone using this particular filter set under dark (Bortle1-3) skies? Our remote imaging group needs a new 2” filter set and the Antlia has nice overlap between R, G & B. I have heard many complaints about Antlia filters having bright star halos and wonder whether this was solved with the newer Pro series. The Chroma filters are nice but are a bit out of our budget. The Astronomik set is not overlapped as completely. Please get back if you have direct experience. Would love to hear about your results.
Thanks,
Brian Puhl avatar
Not sure where you’ve heard complaints about halos. Antlia are great filters. I run two sets (V pros, not the darks) and I've never had halos, even on Alnitak. Same goes for just about everyone I know, and most my circle of friends use Antlia.
JohnAdastra avatar
Thanks Brian. Glad you’ve had a good experience. The halo issue has been well documented on Cloudy Nights. There is a cautionary note before you buy some of the Antlia filters:
“IMPORTANT: Please read this important note below before buying Antlia narrowband filters. No returns will be accepted for Antlia narrowband filters exhibiting halos around bright stars as disclosed below. Please note that some users may see halos around bright stars in images made with this filter. Such halos have been observed with filters from other leading manufacturers and in the previous generation of Antlia narrowband filters as well. These halos can be caused and/or made worse by other optical accessories in the imaging train, their relative positions, telescope design/optics, camera, software, or a combination thereof. In general, OIII filters seem to have a higher propensity to show halos compared to H-alpha or S-II filters, but in rare cases the latter filters can also exhibit faint halos around bright stars. Antlia has made great strides in their coatings to minimize haloing of bright stars, but you may still observe this effect to some degree. See the sample OIII image below of Alnitak (magnitude 1.74) and IC434 in Orion (SkyRover 155mm Apo, ZWO 6200MM-P Camera, 20 min exposure) provided by Antlia. In most cases, haloing will not affect your image unless you have very bright stars in the field of view. “
So whether this applies to the dark LRGB set is what I’m asking.
Tobiasz avatar
I am using the full set with the additional Red+ filter. No halos whatsoever.
JohnAdastra avatar
Thanks Tobiasz. That’s one confirmation that this set doesn’t yield halos. I feel this issue was more to do with their first gen NB filters, but has since been corrected. I have their 2.5nm OIII filter which performs without problems as well.
Brian Puhl avatar
I’m kinda in a belief that warning is more because people were returning good filters after their scope itself was causing halos; bad glass or reflections. Or maybe they were installing them backwards. People are always quick to blame the filters. I stand behind Antlia products fully. I have never been disappointed even the slightest.
Can't get better filters for the money.
Tobiasz avatar
Agree, I was looking & comparing filters from other manufacturers, but Antlia was just too good to ignore. No light pollution gap, good offband blocking and RGB overlap. AFAIK no other manufacturer offers filters with those features.
JohnAdastra avatar
Glad to hear all the positive feedback. There were some early runs of the narrow-band filters which had some halos due to internal reflections within the filter itself which seems to have been corrected. Vapor deposition of filtering strata onto glass surfaces is a high tech art unto itself I’m sure. Perhaps this situation never applied to the broadband filters.
Thanks for the responses.
Well Written Insightful Respectful Concise Supportive
Dan Watt avatar
I also use the Dark series in LRGB and R+. The R+ is fun to play with, lots of little m dwarfs appear when you blink the image. I’ve also noticed some neat details in very dusty areas that don’t show up in the regular RGB continuum.
No issues with halos at all. And the wonderful shades of yellow in reflection nebulas around stars like Mu Cephei really come through, I suspect those yellows live right in the cut off points of other filters.
Helpful Insightful Engaging
John Stone avatar
I’ve just replaced my 36mm LRGB Dark series with V-Pros because of halo problems
JohnAdastra avatar
That’s interesting. Of course you know the V-Pro series has that big gap in between the red and green filter transmission curves. I see they note this newer design is meant to reduce halos, so you may have made the right choice. I just ordered the dark series last night, so I hope I get lucky with no artifacts. You would think Antlia would take all this into account and make all their filters halo-free, if possible. We try to avoid super bright stars on the most part when we can.
Thanks for the info!
Seeking advice on Chroma LRGB filters for monochrome CCD cameras
I am planning to upgrade my LRGB filter set which is to be used with a monochrome CCD camera. I am considering the Chroma LRGB set of filters. I would very much appreciate hearing from owners of these filters about their experience with the filters a...
Alternative LRGB filter set for monochrome imaging; similar use case comparison.
Dec 9, 2025
Optolong L-PRO and SC8
Hello, I am looking to purchase a broadband filter with my SC8 to improve further my acquisition data. I was wondering if anyone is using it with an SC8 shooting at F10 or if you use it with a focal reducer (celestron or starizona). If you have any e...
Antlia filter set discussion; directly relevant to broadband filter recommendations and experiences.
Aug 14, 2024
Mixed filter thicknesses and SW esprit 100 and asi2600mm
Hi, Is anyone using a Sky-Watcher Esprit 100 with its field flattener and an Asi2600mm pro camera with a ZWO filter wheel with mixed 3mm and 2mm thicknesses of filters? Would i just be able to re autofocus on each filter without any noticeable focus ...
Filter set discussion relevant to author's interest in narrowband filter imaging.
Nov 22, 2024
Happy with this scope?
Hi! I’m going to take the plunge into higher reach and is debating whether to get the SCA260 or the RC10 (f6.4 reduced) from Teleskop-Service. The SCA would have about the same F as I’m used to from my Redcat, whereas the RC would be half as fast. Bu...
Discusses telescope selection; author seeks filter advice for imaging setup.
Dec 25, 2025
Opinions and Reviews for the Optolong LRGB set
Hello fellow astrophotography enthusiasts, I'm seeking your opinions, especially from those who use the Optolong LRGB set in their mono astrophotography setups. I'm in the process of renewing my entire set of LRGB and SHO filters, and I'v...
Directly addresses Antlia LRGB filters; author considering this exact product.
May 30, 2025
