OAG setup with 585mm lens requires 10mm spacer for proper focus
3 replies56 views
Florian Wi avatar
Hey there!
I wanted to try out an OAG with my 585mm and the SV555. Yes I know no need for OAG with this focal length but since I have to carry everything up a ladder to the roof I figured smaller would help
My problem now is that I had to put a spacer between the EFW and the 585 to achieve focus with the OAG and the guide cam
10mm
Now the 585 isn’t screwed into the OAG anymore and has more distance to the filters
Thanks
Florian
Quinn Groessl avatar
https://i.zwoastro.com/wp-content/uploads/2025/03/7545e060197bb1b1d0fe98a18d9a540a.jpg
I don’t really see a question, but the link above is ZWO’s diagram for getting 55mm of spacing with an EFW.
Florian Wi avatar
True there is no question 🤣
The question is will there be a problem if I leave it like that?
This is the only way to get focus on the oag
I know the ZWO diagrams
Cheers
It depends. The further away your filters are from your sensor the more chance there will be vignetting, but with the small sensor of the 585 that might not be an issue. Otherwise if everything else works it’s fine.
Mixed filter thicknesses and SW esprit 100 and asi2600mm
Hi, Is anyone using a Sky-Watcher Esprit 100 with its field flattener and an Asi2600mm pro camera with a ZWO filter wheel with mixed 3mm and 2mm thicknesses of filters? Would i just be able to re autofocus on each filter without any noticeable focus ...
Spacer and focus adjustment techniques applicable to filter thickness compensation.
Nov 22, 2024
Samyang 135 backfocus calculating problems with zwo 2600+efw
Hi i have this lovely lens from 1 year ago. Till now i used whit my last 294mcpro but now i have zwo 2600mcpro+2600mmpro attached to efw filter wheel. The backfocus for this lens is 44mm (canon mount) so i removed the 2600 tilter+efw+m48 adapter (10m...
OAG setup with 585mm lens requires 10mm spacer for proper focus — discusses spacer/adapter solutions for backfocus issues.
Nov 18, 2024
Dual narrowband imaging issue
I'm new to using dual-narrowband filters in combination with a OSC camera, and I'm faced with the following problem. During one of the last sessions, I used an Antlia ALP-T 3nm Ha-OIII filter with a ToupTek ATR2600C camera. The filter is inst...
Relevant to filter spacing and optical train configuration issues.
Aug 6, 2025
Focal length of GSO 10" RC
I recently purchased a TS-Optics 10" Truss RC telescope in a package with their full-frame .8 reducer and 3 Inch Rack and Pinion Focuser. The 10" RC is from GSO and its design focal length is supposed to be 2032mm according to the TS-Optics...
OAG setup requires spacer adjustment; author dealing with similar backfocus issues.
May 12, 2024
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Relevant to OAG setup, filter spacing, and optical train configuration.
25 days ago
