Pele Johnson avatar
Hello,
I have the following camera systems that cover 3 scopes and 2 mounts.
Camera 1 system:
2600mc Pro
ZWO EFW
Antlia ALP-T 3nm HaO3 Filter
Antlia ALP-T 3nm S2O3 Filter
L-Quad
Camera 2 System
2600mm Pro
ZWO EFW
Antlia LRGB + 3nm SHO Filters
My 2600MC Pro is playing up and will need replacement or repair and so I want to add some Ha data to the HaO3 and S2O3 filters from my mono camera setup.
My Question is… that I if I swop around imaging trains to get the final bit of Ha I want….what would be the best way to combine the data from the HaO3 and S2O3 Multiband filters with the mono Ha, I would of used DBXtract for the two multi band filters in pixinsight if I could of continued the final night of HaO3 multi band.. that may still be the case for one part but I still need to add in the mono Ha. FYI Currently I have 19hrs of S2O3 and 9.5hrs of HaO3 multiband filter data.
Many Thanks
Combine Ha from Mono with the Ha extracted from the DB filter.
Álvaro Méndez avatar
Hello Pele,
I have two rigs, one with a 2600 OSC and another one with a 2600 Mono, so I’m quite used to working like that. My recommendation is extract the H-alpha using DBxtract, align it with your mono Ha, then use FastIntegration in Pixinsight. This will analyze each image and use weights. You can prioritize SNR or Resolution and this gives the best integration from my experience.
Pele Johnson avatar
Thank you Alvaro that is really helpful and is what I was looking for.
Thanks
Pele
ASI2600MC pro compared to ASI294MC pro. I am thinking of trading up.
I currently have an ASI294MC Pro camera and am thinking of trading up to the ASI2600MC Pro. Would there be a significant improvement in my images? Would I have to get a different filter drawer?
Covers ASI2600MC Pro camera setup and filter configurations.
Jan 4, 2024
Starfront observatory mono vs OSC
Hello everyone. Im planning on sending a rig to starfront observatory. I think i want to go with an OSC setup with filter wheel (l-pro filter , antlia ha-oiii , antlia oiii-sii ) and 2600mc I was wondering if the difference in image quality would be ...
Combines OSC 2600MC with mono data and filter wheel setup
Oct 28, 2025
ASI 533 MC Pro Uv/ IR cut
I would appreciate any feedback regarding the use of a UV/ IR cut filter on an ASI 533 MC Pro camera. If I add a Baader UV/IR cut filter as 'semi-permanent' screw-on to camera does this equate to the 2600MC out of the box? The screw in filter...
Combines OSC 2600MC data with mono camera; relevant to multi-filter workflow discussion.
Mar 28, 2024
Mono camera advice: 2600mm vs 6200mm for bortle 8+ astrophotography
I currently have a 2600mc that Ive been using for a little over 3 years and need some camera advice for a possible mono setup. I live in bortle 8+ and only get to dark sky once a month or so. I’m more into clusters and galaxies than nebula, but I end...
Combining OSC 2600mc with 2600mm Mono Data — Author owns 2600mc; discusses mono camera comparison.
Dec 7, 2025
Chroma 3nm for Fast Systems - Anyone using them?
I am considering replacing my present 6 nm Astronomik Max FR filters on my Epsilon 130D (f3.3) with the much narrower "Chroma OIII (3nm) Imaging Filter Optimized for f/2.8-f/3.6" (link is to the O3 but they have the others as well). Should ...
Combining OSC with mono data using 3nm filters; highly relevant setup.
Jan 8, 2025
