Question about GM1000
7 replies207 views
Jerry Gerber avatar
Yesterday there was a huge power outage in San Francisco where I live. It's still happening.
My GM1000 mount is at a remote observatory in New Mexico and I am unable to access it as my Wi-Fi & power is down.  All the equipment is turned off so my concern is that the roof was open last night and the temperature got down to 28F, humidity around 55-60%.
Should I expect there to be some damage to the mount or other gear given that nothing was powered on and the dew heaters were also not functioning?
Jerry
That should be rather mild temperatures for a mount or anything else in the rig in fact.
Arun H avatar
This of us without access to remote observatories routinely leave our mounts in far worse conditions. If the conditions you describe damaged the GM1000, it wouldn’t classify as a mount worth its reputation and price.
Not a worry Jerry…
Willem Jan Drijfhout avatar
These sound like mild conditions for regular astro-equipment. Should not be a problem.
Can you connect via cellular?
Jerry Gerber avatar
Willem Jan Drijfhout:
No, but the power is back on after 22 hours so I can connect now.   I never realized what an electricity-addict I am...
Frédéric Ruciak avatar
Hi Jerry,
I am preparing a remote setup to be installed in Spain remote hosting facility and their very first recommandation is to use a UPS (Uninterruptible Power Supply) between the main AC power and the setup to be sure that in case of power outage, there will be enough time with UPS to park and keep everything safe, the roll off roof is powered with their own UPS too. They give advice too to setup a special trigger in NINA in case of unsafe conditions (as weather station sending one or AC power outage) to stop the capture sequence and park the mount / close the roof while there is still power in the batteries. UPS is another investment to keep your rig safe and to sleep well ;-)
CS Frédéric
Well Written Helpful Respectful Concise Engaging Supportive
TiffsAndAstro avatar
Ups for your router might be necessary in under developed places such as SF ;)
I once had a power outage in Sheffield. It's ok, I'll just watch TV. Oh. Oh well I'll read a book. Oh well…
Thankfully my neighbour had stockpiled candles smile
10Micron GM1000 mount polling interval slower than NINA expects
I’m using the 10Micron GM1000 mount with NINA. Nina’s logs are warning that the mount’s interval polling is slower than the default 2 seconds that NINA expects. Sometimes the mount takes over 6 seconds to report to NINA. Should I change the polling i...
GM1000 mount issue; discusses same equipment and potential troubleshooting approaches.
Oct 19, 2025
Dew Heating when the Roof is Closed
My scope is in a fairly large observatory with about 8 other scopes. There's a dew strap around the scope, a dew heater in the camera, and a heater in the flip-flat cover. When the roof is closed due to cloudy weather, is there a best practice fo...
Not relevant — discusses power outage affecting remote mount equipment.
Jul 3, 2025
Choosing a Remote Telescope Site
I've been imaging for about 16 months and am at the point where I desire darker and more consistent sky conditions. In choosing a Remote Telescope Site, I have some questions. 1. Would I be able to ship my telescope and mount to the site or must ...
Involves remote observatory setup and mount management from distance.
Mar 31, 2024
