James Webb Space Telescope - the ultimate
Kevin HallAndy WraykuechlewAlan BrunelleJohn Hayes
75 replies6.4k views
Andy Wray avatar
Now that JWST has left planet earth, I thought I would start a thread.  Let's hopefully celebrate it's milestones and achievements.  For now it is on its way, it has deployed its solar panels which are generating power.  Next milestone the first correction manoeuvre.
Ben avatar
Who's going to try and image it?
Curious to know its change in brightness once the shields start deploying.
https://unistellaroptics.com/ephemeris/
Sean van Drogen avatar
Only another 6 months or so before it starts collecting its first data. Can’t wait to see the first results
kuechlew avatar
Well deserved apod dedicated to the JWST today smile
Let's keep fingers crossed that everything will go well in the upcoming stages of its way to L2.
Andy Wray avatar
First two correction manoeuvres completed, high gain antenna deployed and now starting the difficult stuff.  The sun shield deployment over the next two days.  This is really make-or-break stuff. Fingers crossed.
Kevin Hall avatar
Sean van Drogen:
I heard of it but didn't know the reason of such a term. Here is a good arcticle I've found on this topic
https://www.planetary.org/articles/jwst-first-images
Kevin Hall:
Sean van Drogen:
I sort of look at is as being the setup time for the telescope and a lot of testing involved.
Just image if we had to take more than 2 hours every time to setup before we could take pictures.
Kevin Hall avatar
I wonder if it is possible to find it with the scope now?
Kevin Hall avatar
https://www.youtube.com/watch?v=I2GhFSInBqA
Interesting video for those who wonder (for me too) why JWST has got such form
jratino avatar
Cool website, Where is Webb?, from NASA that tracks how far Webb is and it's various deployments
https://www.jwst.nasa.gov/content/webbLaunch/whereIsWebb.html
Rob Johnson avatar
Kevin Hall:
There’s quite a few images on Twitter and I managed to image it too 😊
https://www.astrobin.com/ooe1k2/
also
https://www.astrobin.com/deczfq/?q=James%20Webb
Don’t use the Unistellar ephemeris, it’s DEC sign is wrong, use JPL Horizons
John Hayes avatar
What a relief the launch went so well!
I spent many years working on JWST in different capacities.  Early in the program, I sat on the optical test review committee for a while.  One of our first jobs was to evaluate the two proposals made by the vendor groups who were vying to build the telescope.  These proposals were huge and they incorporated a thousand technical graphs and charts.   A key argument centered around how to meet a requirement to optically test the telescope at low temperature (50 K as I recall) in a vacuum.  It turned out that finding a vacuum chamber large enough to hold this telescope was a serious challenge.  Vendor A had access to a vertical test chamber and the other vendor had found a horizontal test chamber.  So vender A came in and gave a complicated technical presentation showing that the only way to test the telescope was by offloading gravity in a vertical test chamber.  They had a large number of charts, calculations, and measurements showing that the test was not possible with a horizontal chamber.  The next day, vendor B came in and demonstrated through calculations, charts, and measurements that the ONLY way to successfully test the telescope was to measure it horizontally!  They showed conclusively that a vertical test tower would not work.  Behind the scenes, we were all left scratching our heads!  Both groups had very effectively proven that the other group's method would not work–so which is it?  The calculations and data were all so complicated that no one could easily shoot down either argument.  So it will be interesting to see how well the telescope works when it gets on orbit.  As I recall, the telescope was tested horizontally.
I also ran a company called 4D Technology that supplied all of the optical metrology test equipment for the program.  Our Phasecam interferometers were used to test all of the optical components and I was lucky to install one of them at Tinsley where the primary mirrors were figured.  I remember standing next to one of the hexagonal primary mirrors on the polishing machine while it was being figured.  Since beryllium is so toxic, the machine was tented and we all had to wear gloves, clean suits, and masks.  I might have even set up the interferometer on another segment, but it may have been a dummy.  I don't recall.
We also made the multi-wavelength interferometer for testing the phasing process on the primaries.  Remember that all of those hexagonal mirrors don't just have be geometrically aligned.  They have to be adjusted in piston to have less than a quarter of a wave step between the wavefronts reflected from each mirror segment.  This is a very tricky thing to do so there were a lot of optics folks developing algorithms for doing the alignment and for evaluating the results.  In hindsight, this would have been a relatively simple job using AI but to my knowledge, that's not how it was done.  I think that it uses some sort of Kalman-filter to recursively align the mirrors.  Anyway our multi-wave Phasecam could measure how well the aligned primary mirror was phased during testing.
We also supplied a 100+ Mega-Watt speckle interferometer for evaluating the carbon-fiber backplane structure.  The backplane was large, it was flat black, and it was sparse, which is why the interferometer required so much power.  It used a 1 ns pulsed laser that only had a coherence length of 1 foot so it incorporated fiber path matching loops in the reference arm to get a signal back from the structure.  That interferometer had so much power that it was a little scary when we ran it.  We had to be VERY careful with our laser safety protocols.  Charlie Precourt who used to be the chief pilot/astronaut for the Space Shuttle told me that he managed the group at Northrup that made the backplane structure.  They used the speckle interferometer to look for defects in the structure and to characterize its thermal performance.
At the SPIE meeting last summer, Ritva Keski-Kuha, who is the JWST deputy telescope manager for NASA, told me that without 4D Technology, JWST would not have been possible. We had some VERY smart engineers working on all that stuff and I was very proud to hear that all of our hard work was so important to the program.  Some of those projects were really challenging and our guys did an amazing job delivering state-of-the-art metrology capability.
I can't wait to see the first images!
Well Written Helpful Insightful Respectful Engaging
kuechlew avatar
Thanks a lot for your insights John.
To be honest, as a project manager I would have done anything to get both tests done. Most likely just a matter of money.
Still quite some way to go and still a number of deployment steps to pass. I assume once the unfolding is complete in the second half of January the main risks should be mitigated. The upcoming two main steps - unfolding the sun shield and getting first and second mirror deployed - are most likely the most critical deployment activities.  Let's continue to hope for the best.
Respectful Supportive
Kevin Hall avatar
Jonh, your insights are so exciting to read! Thanks for sharing.
I have a hope, that JWST is definitely going to tell us something about Universe that we didn't know before.
John Hayes avatar
Each “Vendor” was a consortium of 8-15 companies vying to win the contract—one led by Lockheed and the other led by Northrop.   As I recall, those big test chambers cost somewhere around $60,000/hour to operate and that doesn’t begin to address the cost or complexity of mounting everything and configuring the chamber for the test.  JWST started out as a part of NASA’s bigger, better, cheaper program so there wasn’t an option to do both tests.  As the program progressed, the level of testing grew along with the costs.  JWST went through extensive test and analysis making it one of the most throughly tested optical systems of all time.  The disaster of Hubble was front and center in everyone’s mind—and there is no fixing this telescope.  Still this is the most ambitious optical system ever launched into space so there are a lot of risks.  It is the ultimate remote telescope!  There’s a pretty good chance that it will work, but it’s certainly not risk free.  Let’s all hope for the best!
Andy Wray avatar
OK, it looks like NASA have given themselves a day off after the stressful deployment of the side booms and the pulling out of the sun shield.  Looking at their site, things are starting to cool down nicely on the dark side (already down to -183 C, but some way to go.  Tomorrow (Sunday) and Monday are set up for the separation of the sunshield layers and the tensioning.  Fingers crossed (yet again).
Helpful Respectful Concise Engaging
kuechlew avatar
I'm a bit worried about the deviation from the planned timeline. Layer tensioning should have started already.To me this is a sign that something doesn't (didn't ?) work out as intended and that there are (were ?) some unplanned difficulties to overcome. I don't think they give themselves a day off, would be very unusual and hard to justify in such an important project. Let's hope for the best.
Ruediger avatar
Hi Kuechlew,
everything is fine. Here are some more information https://blogs.nasa.gov/webb/2021/12/31/first-of-two-sunshield-mid-booms-deploys/
Resp full blog: https://blogs.nasa.gov
Rüdiger
Andy Wray avatar
Now down to -192 degrees Celsius  … heading in the right direction … let's see how sunshield separation of layers and tensioning helps that
Andy Wray avatar
OK, they've decided to spend today characterising the operational behaviour of JWST's power systems and monitoring the temperature of various deployment motors.  So, no sunshield tensioning today.  We all need to wait another 24 hours.
Well Written Concise
John Hayes avatar
I was looking for something else and I came across a photo of the phasing test on the primary mirror using the Muti-wavelength 4D Phasecam system (on the left side between the two workers).  I thought that you guys might enjoy seeing what it looked like.  I got the photo sometime in March, 2017.
Jeff Kisslinger avatar
Andy,
Thanks for starting this thread, I've been waiting for the JWST to go up for a while, this is very exciting! I'm really looking forward to seeing some of its first images, especially the earliest galaxies and stars.
John,
That's a great picture, thanks for sharing! I had no idea you were a contributor to this magnificent telescope.
-Jeff
Andy Wray avatar
OK, layer 1 of the sunshield has been fully tensioned and they have moved on to layer two smile
kuechlew avatar
Indeed, I'm very relieved. In their teleconference they revealed that they had some challenges to overcome related to the temperature of the motors involved. The project manager pointed out that the sunshield deployment is one of the most critical steps in the overall procedure and once they managed to achieve it they will have passed about 75% of the 344 single points of failure. They seem to progress well, at the time of writing they have deployed the three layers closest to the sun with two to go. On a side note: with 344 single points of failure, assuming a 99.99% probability to mitigate each single point of failure you still end up with only 96.6% success rate (assuming independent probabilities). Making this project a success is an awesome achievement.
It looks like the "Where is Web" website is not updated properly. Temperature is still about the same as the days before but with 3 sunshields deployed there should already occur a quite significant change.
Kevin Hall avatar
I can say that JWST full unfolding is the most anticipated event of the 2022 year!
I'm Wondering About Dead Planets
Let's say there's a solar system somewhere in a galaxy and the star of that system reaches the end of its life-cycle. The star may collapse into a black hole, or it may explode into a supernova, but what happens to the planets? Do they get va...
Not relevant; focuses on stellar death cycles rather than JWST mission.
May 2, 2023
Australian Photographic Prize: Astrophotography Winners!
In a very close contest, congratulations to the Australian Photographic Prize, Astrophotography Competition winners! Astro Landscape: Tristian McDonald "Double Helix" Tristian provided the following information about his image. After the ma...
Not relevant; celebrates astrophotography competition winners, not JWST achievements.
Jul 28, 2023
