Best telescopes for photographing planetary nebulae and small galaxies?
5 replies177 views
Kathleen Jordan avatar
My main objects of interest in astrophotography are planetary nebulae, small to medium-sized galaxies (in apparent size), and planets like Jupiter and Saturn. What are some of the best telescopes for this? Currently, I am eyeing the Celestron 9.25 EdgeHD, but I seriously dont know. What do you think?
Nicolas Molina avatar
Hi Kathleen
I’m using the Celestron 9.25 EdgeHD with good results on planetary nebulae and galaxies. Of course, aperture is the king. If you can afford it, and your mount can handle it, go for the bigger scope you can.
Nicolas
Rick Veregin avatar
Hi Kathleen
I have a Celestron 9.25 (not EdgeHD) and no experience with the Edge, just what I have read and heard. The advantage of the EdgeHD is that the full field is flat, the C9.25 doesn’t give perfect images right the edge of the field.
I do PN, planets, the Moon, and small galaxies to full field larger galaxies, as well as nebula of all sizes.
For planets and Moon close-ups (where you use a barlow) there is no advantage to the EdgeHD since you only use the center of the field anyway. For PN and all deep sky targets and a full image of the moon I use an f6.3 reducer from Starizona, which gives excellent images to the field edges, and obviously the faster f-ratio. My seeing is rarely better than 2” so it makes no sense to over sample with the full FL, the f6.3 is perfect FL for me. For planets one uses lucky imaging where a long FL is critical to take advantage of the lucky seeing, so the full FL and barlow is the way to go for planets.
The EdgeHD is slightly slower if you get the Celestron 0.7x reducer, but not a big deal.
To make a long story short if your seeing is often excellent then you may want an EdgeHD so you can image at f/10 full focal length deepsky targets that are bigger than maybe 2/3 a crop sensor, but not necessary for smaller targets, or planets where you add a barlow to get the FL you want. But note the Edge f10 ratio is high for deepsky objects that are dim. And again if you are mostly looking at small objects, you don’t need an EdgeHD, it only really shines for the full field at the full focal length, especially if you had a full frame camera. And cost is maybe 1.5x higher for he Edge vs the standard. The Edge 0.7X reducer from Celestron is about the same price as the Starizona f6/3 reducer for the standard C9.25, so that is a wash. The Celestron f6.3 reducer is not great, I would not recommend it with the standard C9.25
All this being said, the SCT’s like the C925 is very good for PN and planets. The C11 and C14 would be even better but are very heavy, need a good mount and generally will be more difficult to use. But as you see on AB, these SCT’s are the favorite for planets.
By the way, I have a Celestron CGX mount which I don’t use a lot anymore, it is not a great mount, even though it is supposed to be better than the other Celestron mounts. I have the Ioptron CEM70ec now with encoders for my C9.25 which is so much better. But there are a lot of other good mounts out there too, depending on your price point.
Good luck
Rick
The classic 9.5 is a good instrument and and will deliver on the kinds of targets you’re interested in. With that said, especially with the moon and planets, something magic happens when you get into large aperture territory. By this I mean 12 inches and up. If you have good seeing, a good C14 or a well designed 12” Newt can be absolutely killer on the moon and planets. I also would expect that you could do amazing things with smaller deep sky objects, especially PN. If you can afford the class of mount needed and have good seeing I would seriously consider it.
Bill McLaughlin avatar
It really depends on your seeing. You want to get the sampling/focal length of the scope in line with the seeing at your site. Being slightly oversampled by conventional standards can be helpful since things like BXT are helped somewhat by better sampling. Typically you will want 3-4 pixels or somewhat more across your typical best seeing. With a standard 3.76 micron pixel camera that means:
Best seeing 2 arcsec = sampling of about .5 to .7 arcsec
Best seeing 1.5 arcsec = sampling of .4 to .5 arcsec
Best seeing 1 arcsec = sampling of about .25 to .3 arcsec
You can figure your focal length from that
You also don’t want too slow, about f7.5 to f8 at the slowest.
Having said that, if your best seeing seeing is worse than 1.5 arcsec, I would not bother with those targets - you will never be able to produce high res images.
Helpful Insightful Concise
alpheratz06 avatar
I support the opinion about the importance of seeing.
Using a powerful tube in poor sky conditions will bring frustration.
That being said, there are several aspects to consider :
  • larger aperture will bring more resolution , up to seeing conditions of course
  • larger aperture will bring more photons for the same focal length and reduce exposure time
If you start with a 9.25 SCT, keep in mind this will have 2350mm of focal length, down to 1600 something with a reducer.
No major issue with planetary tracking.
For deep sky, this is another story : you should use a good quality mount, even if the load of a sct is not so high. Correct guiding at high F is not a trivial issue. So don’t bargain with the mount.
It is possible to obtain decent pictures with a good mount and an average+ scope.
The opposite isn’t possible. Full stop. So invest in a good mount as first important item if astrophotography capability is pivotal.
Helpful Insightful
Planet views with Takahashi TSA 120?
Hello, I am currently using a C8 AVX. This telescope takes a while to cool down, and with the seeing conditions in the UK I have had many nights of underwhelming views. I am going to be buying a shed to store it in, to hopefully decrease cool down ti...
User compares C8 to EdgeHD; relevant for telescope performance evaluation.
22 days ago
First image with new Edge 9.25 scope reveals possible discovery.... Can i get peoples opinions please
Hi guys, i’ve just processed my first image using my new edge 9.25 hd scope. Given that it is not a very eye catching image i don’t think many people are going to view it, but i would really like some input/opinions on my possible discovery. It is no...
Direct experience with EdgeHD 9.25; highly relevant for decision-making.
Jan 14, 2026
Celestron edge hd 9.25 is Perth, Australia too windy for it?
Hi guys. I've started taking interest in some small galaxies etc and i’m pushing the limit of my 683 focal length. I’m looking to get a celestron edge hd 9.25 but wanting to know from real life experience if it’s going to be a waste of money for me. ...
EdgeHD 9.25 user imaging small galaxies; directly matches author's interests.
Nov 26, 2025
what is the best smart telescope under $700
Hello, my name is Adam, I would like to know what is the best Smart telescope under $700 for viewing nebulas and galaxies.This is not my first telescope, my first telescope is the Sky-Watcher 90/900
Directly addresses best telescopes for galaxies and nebulae observation needs.
Jan 2, 2026
What advanced Telescope should you buy after A Beginner One?
Hello and welcome. I'd like to ask everyone here if you ever had a standard beginner telescope like the Celestron power Seeker 60AZ. What advanced Telescope did you buy afterwards? Those telescopes have the functionality to control them remotely....
Covers telescope choice for observing planets, nebulae, and galaxies mentioned in post.
Aug 16, 2024
