RGB + H-Alpha Galaxy Star Formation Knots
9 replies901 views
Mau_Bard avatar
Hi All,
I am asking for your advice. I have recently elaborated an image of NGC2403, having RGB data and H-Alpha plus OIII. I used the NBRGBC process in PixInsight to combine the NarrowBand and RGB data. This is the image https://astrob.in/pqncwq/B/
One passage I was not able to manage properly was to isolate in the HA image the star-formation-"knots", in order to avoid that the full image RGB image gets a red tone from the HA. I tried also to develop a "Knot mask" extracted by the HA image, with no success.
The fact is that I could not get rid of the core of the galaxy that had a similar luminosity of the star forming regions.
I would appreciate your suggestions and experiences about techniques you use to extract a clean "H-alpha star formation knots" image.
I wish you a nice holiday season, and clear skies into 2022!
Mau
Respectful Engaging
David Nozadze avatar
Hi Mau!
This is a short video, showing how I processed my M31 session.
Please turn on the captions, to see the explanation of each step. Hope this helps.
https://youtu.be/ofAF4f7HAP8
David
Well Written Concise Supportive
Wei-Hao Wang avatar
Just add H-alpha to the R channel in the initial linear stage, and dial down the R during color balance.  Then the red knobs will naturally stand out.
Mau_Bard avatar
Thanks David for your video, and Wei-Hao for your suggestion.
Adding H-a to RGB before the color calibration makes all the process way simpler! I will reprocess my image using the sequence you suggest for sure.
I express to you both all my appreciation - many thanks.
And on the occasion, I wish you a nice holiday season and a healthy new year!
Mau
Wei-Hao Wang avatar
BTW, you don't even need to do a straight R + Ha.  You can do things like R + 0.2*Ha.  (0.2 is just an example.  You can try different factors and find out what you like the most.)
My personal experience is that just a little additional Ha (like the 0.2 factor) plus subsequent saturation boost after color re-balancing is sufficient to give you very nice red nebulas along the spiral arms.  A factor that's smaller than 1 can also reduce the impact of noise in the Ha image, if the exposure time for Ha is not very long.  (I typically give Ha a total exposure time that's only about 1/3 of R.)
Wei-Hao
Mau_Bard avatar
Dear Wei-Hao thanks for your valuable additional advice! It is key in post processing steps to have good staring parameters and the conceptual background as well!
Mau
Fluorine Zhu avatar
Mau_Bard avatar
Thanks Fluorine, and congratulations for your M31 image: it is really gorgeous!
Leonardo Landi avatar
I use another method, well explained in the book "mastering pixinsight". I use pixelmath with a max expression.  In other words, it replaces the r pixel with the ha pixel if the latter has a highter value. I do not remember the expression but I have an icon in my set. Give me your email and I'll send you.
Mau_Bard avatar
Thank you Leonardo, grazie.
I have just sent you my mail address in a private message here in astrobin.
The idea to pick the maximum is brilliant.
Probably the H-a's and Red image's medians have to be equalized before maximization, but I suppose that the PI formula takes care of that.
Following the interesting discussion here I was landing on averaging the R and H-a with Pixelmath, but definitively the Maximum is a more direct solution.
I am looking forward to see the math expression.
The second point I take from your post, is that the book "Mastering Pixinsight" is worth to be read. I enjoyed a lot W.A. Keller's "Inside Pixinsight", and it looks that Rogelio's book is giving additional perspective.
Thanks again, and I am looking forward to reading from you.
Happy new year! Ciao,
Maurizio
HA processing experiment , what do you think ?
Hi all , I was looking for a way to get pure Ha and color stars , so I came up with this after some time , it might be something stupid, but I like the result I shot LRGB and Ha with a mono camera . I processed Ha as normal streched, removed stars an...
Discusses HA processing techniques relevant to author's star-formation knot isolation challenge.
Dec 7, 2023
