DavesView avatar
NINA is not recording exposure info, not adding target name to file, not running any triggers such as AF after HFR increase, not running AF after filter change, not setting last filter on autofocus, not flipping at meridian. 1st time I’ve encountered this. Anyone seen this?
Linwood Ferguson avatar
Short answer: no.
To realistically get help, you need to provide a NINA log file, and best place is Discord, though if you put it here a few people might be able to help.
When you provide the log, knowing at what time the issues started is helpful. As a general rule it is best to concentrate on the first error.
fjwidmann avatar
It is possible to inadvertently run a version of NINA that is not configured with your presets.
SonnyE avatar
Hi Dave,
Have you run any updates lately?
I recently had to go through a bunch of malarky with several of my Apps to run my equipment. It may sound harsh, but when I get a multi-failure like that often the quickest fix is to remove, then reinstall the offending program. I did that with NINA recently.
And everything came back hunky-dory. Drastic - yes. Fixed - yes
I’ve gotten to where I just hate updates! They’re so buggy.
And Windows updates treat our open-source programs like they are targets at a shooting gallery, blowing holes in the drivers.
DavesView avatar
Linwood Ferguson · Dec 12, 2025, 01:10 AM
Short answer: no.
Posted in Discord. Thanks!
DavesView avatar
SonnyE · Dec 12, 2025, 01:24 AM
Hi Dave,
I haven’t updated recently and I’ve run several sessions without a hitch since I did update.
DavesView avatar
fjwidmann · Dec 12, 2025, 01:19 AM
Not sure, but it connected everything with one click connect. I look and it is running my configuration.
DavesView avatar
So Marc and Linwood on the NINA forum figured it out. I had mistakenly put my Smart Exposures outside of ‘Instructions’ in the sequencer.
DavesView avatar
DavesView · Dec 12, 2025, 01:44 AM
Short answer: no.
Ahhh! Linwood… I see the connection now. Thanks a lot!
Yeah…. I sent you there because smarter people are there (Isbeorn wrote NINA, Marc wrote powerups), but also you can just drag and drop log files, focus runs, sequences, etc. there.
I’m not a huge fan of discord, but it’s definitely the place to go for NINA help.
Focuser trouble when NINA starts
Hello, I’m new to NINA (was using ASIAIR before), I was able to connect and set everything and to perform two nights of imaging. Here is my issue, the last two times I turned all my equipment on, my focus was lost (I mean stars wereway out of focus, ...
NINA software issues; autofocus and trigger problems directly relevant.
Sep 3, 2025
Autofocus questions
In the past, I've generally run an autofocus every 30 minutes (I don't have a temperature gauge on my rig). But I've recently switched to NINA and have used the autofocus on HFR change (default of 5% over 10 images). But no autofocus run ...
Autofocus questions; directly addresses AF trigger issues mentioned.
Aug 13, 2025
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Meridian flip problems; author mentions flip not running.
Oct 28, 2025
What do you do when PHD2 sees ghosts?
I have been chasing a problem in my guiding for several hours yesterday night and tonight. I use an OAG with a SCT (C8); PHD2 (managed by NINA) is the brain. The experienced problem was that, for a specific target, guiding would work well “in most ca...
PHD2 and NINA integration; guiding system affects autofocus triggers.
EdgeHD 8 Focus Point Moving
Hello! Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently. It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the fo...
Focus point issues; relates to autofocus problems in NINA.
22 days ago
