Please help identify why Asrobin is displaying image with a line through it.
Support requests are handled via the support form so they can be tracked and resolved properly. This section is for community discussions about the AstroBin platform.
Gina Knight avatar
Hello - can anyone kindly help me identify what is causing Astrobin to display my image with a line running through it? This is the first time I’ve encountered itThe image was processed in PixInsight and there is no line appearing in PI or in Photoshop. I asked CHatGPT to help me troubleshoot and the suggestion was to remove the ICC color profile which I did, but still the same issue. Have any of you encountered this issue?
Salvatore Iovene avatar
Hi Gina, can you link to the image please?
Quinn Groessl avatar
Salvatore Iovene · Dec 11, 2025, 07:37 AM
https://app.astrobin.com/forum/topic/207046?page=1#post-220507
It’s the first one in her gallery. It has a horizontal yellow line near the top.
Thanks Quinn, I see it.
Gina, that line is also visible in the file you uploaded to AstroBin, called “GeckoHorizontalTIFF copy.jpg”.
I checked that file straight from storage, where AstroBin copies it byte by byte, not changing anything.
So there are 3 options:
  1. The upload got some bits flipped randomly. Extremely rare, almost impossible. Upload it again as a new revision if the file looks good on your computer.
  2. The file looks good on your computer but the browser displays this issue. To see if this is the case, open your GeckoHorizontalTIFF copy.jpg directly with your browser on your computer. You can drag and drop the file from your file system to your browser, to verify.
  3. The file actually has that yellow line and you didn't notice. Please verify GeckoHorizontalTIFF copy.jpg locally again.
Hope this help and please let me know what you find!
Thanks,
Salvatore
Gina Knight avatar
Thank you Salvatore!
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Vertical bands in images; flats troubleshooting similar to line artifact issue.
Nov 23, 2025
Stacking issues with rotated field causing luminance lines in Seagull Nebula
Hello! I’m working on the Seagull Nebula, NGC 2335. I took my first batch of images with two dual narrowband filters before deciding I hated the composition and rotated the field for the third and ongoing nights. When I stacked all the data I was lef...
Stacking issues causing luminance lines; directly addresses line artifacts.
Jan 27, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Camera producing artifacts in images; relevant to troubleshooting image defects.
Nov 27, 2025
