Player One + Nikon lenses?
3 replies54 views
jmarinotero avatar
Is anyone using a Player One deep sky monochrome camera (Poseidon or Zeus) with Nikon lenses? I am trying to decipher what a Poseidon/Zeus + filter wheel would look like attached to a Rokinon 135 (Nikon mount). ZWO makes this easy but I am entertaining other options. Anyone have experience putting a system like this together?
I entertained it and it would only work with a custom adaptor for the F flange.
alpheratz06 avatar
Not sure that would be feasible in terme of BF.
Nikon f delivers 46.5 bf, from which you have to substact sensor depth which is 12.5 without tilt adjustement ring
Remove 20mm for the filter wheel , that leaves 14 mm for the nikon f to m42 adapter… no way commercially IMHO
The solution 1 could be the zwo adapter with filter drawer which makes sense see https://www.zwoastro.com/product/zwo-new-filter-drawer/
The solution 2 needs some checking : zwo has a m54 nikon adapter compatible with zwo 2” efw from zwo ; it should be checked that direct mounting is possible with the camera today the efw https://www.zwoastro.com/product/zwo-zwo-nikon-lens-adapter-for-2-filter-wheel/
Solution 1 is bullet proof
Clara skies
Rainer Ehlert avatar
You could buy an macro ring set and use the 12mm ring. 3D print the adapter with thread to the Poseidon or Zeus camera. I have done 3D printed a lot of adapter rings with thread M42×0.75 with PETG and they are very strong.
Player One Astronomy Filters LRGB
Hi, Anyone apart from me using the LRGB filters from Player One Astronomy? I have got the curves for adding them into PixInsight via Filter Manager. Please PM me so I can sent then to you in a *.zip file regards Rainer
Discusses Player One cameras with filters and lens compatibility questions.
Nov 30, 2025
Monochrome or color camera for astrophotography?
Hello guys, My old astromodified DSLR just died (Canon 40D) and I am currently searching for a dedicated astrophotography camera. At the moment I have two cameras in particular which both seem like a good choice. The first camera is the Player One Ar...
Author comparing Player One cameras; lens compatibility question relevant.
Sep 11, 2025
Optimum sensor to use with Askar FMA180Pro
Hi All, I put together a portable rig to take to dark sites. I have bad arthritis now so I need something small and quick to setup so the FMA180 Pro is perfect for that. I am just now trying to decide on the best camera to use that would give me the ...
Explores monochrome camera options similar to QHY183C for deep sky imaging.
May 18, 2024
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Author uses Player One Poseidon camera; discusses setup and troubleshooting.
Mar 5, 2026
I'm getting terrible pictures with this Player One camera, can someone help?
Hi, I purchased a Player-One Uranus M in the spring right around the time QHY and ToupTek perfected HDR mode on their versions of the IMX585 cameras. At the time Player One did not have HDR mode but after talking with customer service and learning th...
Discusses Player One camera setup and potential configuration issues.
Sep 28, 2025
