ZWO ASI2600MM Pro and QHY CFW3-M filter wheel connection adapters?
3 replies74 views
Leandro DC avatar
Hi everyone,
I wanted to ask if anyone here is using this combination:
  • ZWO ASI2600MM Pro camera (P25)
  • QHY CFW3-M filter wheel
If you are using them together, which adapters did you use to connect them (M42, M54, spacers, etc.)?
If you can share your exact imaging train (camera → adapter → filter wheel → rest of the setup) or a photo of the assembly, that would be extremely helpful.
Brian Puhl avatar
While I don’t have an ASI2600MM, I know enough about the camera and the QHY ecosystem to explain what you need.
The camera and filter wheel will get screwed/bolted together like any other camera and filter wheel would. The difference is ZWO uses 2.5mm screws and QHY uses 3mm. You can mount up the QHY filter wheel but you will need to purchase an assorted 2.5mm countersunk screw kit.
Well Written Helpful Concise
ItsMeAstro avatar
I’m always ordering my adapters from PreciseParts, superb quality, not cheap.
Select your equipment and specify your adapter backfocus on link below. There are numerous options to connect both.
https://preciseparts.com/ppmain/index.html
Leandro DC avatar
Brian Puhl · Dec 7, 2025, 02:29 AM
Hi Brian! It was just as you said. Thank you so much for your help!
Moravian C3 camera
Hi! I want to buy a C3-26000 PRO CMOS, but I already have the ZWO filter wheel and OAG-L. Is it possible to bolt the ZWO EFW to the camera? If not, which adapter do you recommend? Cs
Discusses ZWO camera and filter wheel compatibility, directly relevant to adapter question.
Jan 9, 2026
Connecting ASI2600MM Duo to Sigma (Nikon) Lens
I want to image wide angle areas of the sky, and for that I am using a Sigma lens with an astro camera, but I can’t obtain the focus. I have tried different backfocus distances, see below, but I’m unable to get anything close to focus. Does anyone ha...
ZWO camera adapter compatibility relevant to connecting lens with astro camera.
Mar 29, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
ZWO camera fan vibration issue relevant to ZWO ASI2600MM Pro imaging setup.
Nov 18, 2025
