CMOS camera binning 2x2
6 replies100 views
Rainer Ehlert avatar
I am playing with the idea of getting a bigger chip for my Mewlon in order to reduce my resolution from 0.245”/px to 0.45”/px.
What is the opinion of the experts how to bin correctly.
I know binning with CMOS chips is not that elegant as binning with a CCD chip.
Is it worth or do I get more trouble then efficiency?
Thanks for you ideas and comments…
Rainer
Tobiasz avatar
from a CMOS perspective I would always BIN (or “resample”) in post processing. There you can decide how much you want to resample based on your image "FWHM” and gain SNR.
You can check out if you’re under-, well or oversampled with RC Astro’s MTF Analyzer: https://www.rc-astro.com/mtf-analyzer/
If your image FWHM is in the rough ballpark around +-3 pixels you are well sampled and you do not have to bin. Just check out your subframes in Pixinsight with the tool “FWHMEccentricity” and measure the median FWHM of your stars.
Regards
Helpful Insightful Respectful
Tobiasz · Nov 30, 2025, 06:24 PM
Regards
Thank you. will take a look into it and try to understand it.
quote:”If your image FWHM is in the rough ballpark around +-3 pixels”
Is this valid for any focal length?
Rainer Ehlert:
Rainer
*For anything but the best seeing Earth can offer that image scale is wasteful but you can always do it (binning) in post-processing, depending on the sensor pixel count and how much processing power you have at hand. Some CMOS chip can do a hardware binning which saves on the RON but I guess not many (Moravian might have it in their high end FF cameras).
Tobiasz avatar
Rainer Ehlert · Nov 30, 2025, 07:37 PM
Regards
Image FWHM depends on several factors, which is seeing, focal length and pixel size. So yes, focal length is a factor. More focal length gives you more reach and finer sampling.
Regards
andrea tasselli · Nov 30, 2025, 07:40 PM
Hi Andrea,
Do you mean I am exaggerating with 0.245”/px?
one of my images with 0.245”/px
https://app.astrobin.com/u/NHSA_Observatory?i=0njoij&r=B#gallery
Yep. Halve the image scale and you'd still see the same details. What the heck, halve it again and I bet you would still see the same details but your SNR goes up by a factor of 16.
Discusses telescope mounts; author focuses on camera chips and binning techniques.
Mar 10, 2026
