Rainer Ehlert Ā· Nov 29, 2025, 07:29 PM
Both images have no processing at all except Plate Solve after LRGB combination and then SPFC and SPCC. No stretching at all be it GHC or HistogramTransformation so the histogram I presented is from the linear image.
It is interesting you mentioned that the upper image has not neutralized background and nothing mentioned about background from the bottom image which has also not a neutralized background at all.
In the same way as you do I see a bluish cast on the top image which is Āænonexistant in the bottom image? which was made with LRGB combination and RGB filter calibration applied.
quote:āIf you use SPCC properly, you can achieve correct color calibration.ā
I do LRGB combination, Plate Solve and then apply SPFC and then SPCC. Āæis this the correct way? Thanksā¦
regards Rainer
Hi Rainer,
Simply running SPCC on a LRGB image does not necessarily produce a color calibrated imageāas you have discovered.
The proper way to color calibrate is to first create a RGB plate solved image. Then remove any gradients. There are a lot of tools for that job. Then perform SPCC using the appropriate white balance. In most cases the best white balance with be the āAverage Spirial Galaxyā, which is the default. If the background comes out with a blue-ish (or any non-neutral) background, the background limits in SPCC need to be adjusted. If in doubt, you can tell if the background is right by running BackgroundNeutralization. If the background tone changes, thereās a problem with the settings in one of those two tools. When the background is properly neutralized, you should see very close to R=B=G for empty space no matter where you sample the background and it should appear to be a neutral gray. Thatās what your second image looked like on my monitor and why I didnāt mention it. Once your RGB image has been color calibrated, stretch it. If youāve done everything correctly, it should look like a spectacular image at this point. The background should be neutral and the color vibrant with a proper white balance at the high end.
Now itās time to combine it with your Lum signal. The Lum signal should have gradients removed as well and it should be stretched with the same parameters as your RGB image. You also need to roughly match the brightness and dynamic range of the Lum image with the brightness of the RGB image so you may need to use HDRMT before doing the combination. It is very important to adjust the Lum signal so that it does not produce saturation at any point in the image. Adding the Lum signal should help to bring out additional detail and show much fainter stars than what the RGB data shows. I go over all this stuff in my GalaxyStudio presentation on TAIC so it may be helpful to review it there if you havenāt already.
My point is that in order to get proper color calibration, you do not have to calibrate your filters, which was your original question. The procedure youāve described strikes me as being very similar to using the LinearFit tool to match RGB color channels, which again, is not necessary if you are using SPCC to do color calibration.
