Paramount MYT + Nina + PHD2 guiding issues
8 replies203 views
Steeve Body avatar
Hey folks, quick question for anyone running a Paramount MYT with NINA and PHD2.
My Paramount is doing my head in. Everything is set up correctly as far as I can tell, SkyX, ASCOM, all that. But every now and then PHD2 throws up the error “your mount doesn’t support pulse guiding”. When I check the ASCOM interface, the “Direct Guide” box has unticked itself for no reason. I tick it back on and things work again… until it randomly happens again.
It’s driving me mad. Sometimes I have to fully restart PHD2 just to get guiding back, and I’m losing way too many subs because of it.
Has anyone run into this and found a fix?
Have you tried launching PHD2 without going though NINA first and see whether this happens at all?
Steeve Body avatar
No I have not tried that… is that a know fix for this? so I would launch SkyX, then PHD2, connect them and then NINA last I assume
I running a 24/7 sequence in NiNA so I’m hoping to be able to get it stable enough so it mostly behaves
I was suggesting that by connecting to PHD2 alone you'll be able to ascertain whether the ASCOM driver is to blame for the loss of the server connection or it is NINA, somehow. You run NINA but do not connect to PHD2 in this scenario. Obviously, it would be either manual handling if changing targets (stop PHD2, re-start PHD2) or just do one side of the meridian target. It is just for testing, obviously, not as a permanent feature.
Larry Ammann avatar
I also am running a MyT+Ascom7+NINA+Phd2 with the latest version 7.0 of Ascom2XMount and version 13960 of TheSky64 on windows 11. I always start Phd2 from NINA and never have had this problem, so I don’t think this is coming from TheSky64 or Phd2. Have you turned off all usb power saving control in windows 11?
vikas chander avatar
i had the exact same problem. i switched to Windows 11 and switched off power management in all usb ports.
whenever there is an update sometimes these power management check boxes get ticked so always check that. hope u solve the issue, it can be really frustrating.
📷 WhatsApp Image 2025-09-27 at 11.30.01.jpegWhatsApp Image 2025-09-27 at 11.30.01.jpeg
Steeve Body avatar
Thanks for the advice guys! Ok I have just checked and power management on the usb ports was turned on, so I have now turned it off! Hopefully this will resolve this issue… I have a good feeling about this :)
Nick Grundy avatar
I had the same issue and tried the USB fix. Seems wacky, but I haven’t the issue in months.
Curious how you all are setup for platesolving in NINA? Astap or TSX? I get strange windows debugging errors sometimes. Like the NINA call to platesolve in TSX crashes.
ASTAP. Never fails (except when it does, when too few stars are in the field e.g., with NB filters).
CQ350 Tracking Issues
Have recently bought a CQ350 mount for use with my GSO RC12 and I having an issue with the mount. I wonder if anyone out there can help with advice and/or experience. This is the 1) When the RA drive clutch [not the best design in the world] is locke...
Not relevant - Different mount model; guiding software setup rather than mechanical issues.
Mar 8, 2024
New Mini PC user
Hi guys! I need some tips for the mini pc. I switched from ASI AIR to the mele quieter 4c mini pc. I set up a persistent hotspot and nina and everything. However i found the the whole setup to be quite unreliable! For one, the Hotspot is very weak an...
Paramount MYT + Nina + PHD2 guiding issues — NINA software problems similar to author's
Nov 29, 2024
PHD2 crashes when looping is enacted despite reinstalling all software and drivers
PHD2 crashes when looping activated. History: I switched out guide cameras and from that point on PHD2 crashes when looping is enabled. I have switched back to the original camera. I have deleted all astronomy software and reinstalled including NINA,...
Paramount MYT + Nina + PHD2 guiding issues - PHD2 looping crash troubleshooting.
Nov 4, 2025
