Mike Butorac avatar
So my first crack using a dedicated astro camera and I get this as a master dark (in APP). What the heck?
Mike
AstroDivers avatar
What camera do you have?  Parameters?
I think it's not as bad as you may think
It's called amp glow
Some info, for example,  here
Mike Butorac avatar
It's a ZWO 294MC Pro. I kinda expected amp glow, but I don't really know what that is, or how it affects things. I think gain was about what the medium setting from my ASIAir Pro ~ probably around 150 ~ I was just guessing.
*posted before I read the link to the ZWO info page. Still, seems excessive to me.
Andy Wray avatar
My master dark (in PixInsight) with 300 secs exposure at unity gain on an ASI1600MM looks more like this (some amp glow, but not like yours):  Try deepskystacker or the free Pixinsight trial to see if you get the same result.  Also, how many seconds were your darks?
Cfeastside avatar
Yep, amp glow.  Mine does the same.  But your master dark should remove it from your calibrated lights
Concise
Entirely normal dark frame from that camera. Mine are just the same.
Adel Kildeev avatar
Yep, dark from 294 MM, I have the similar. Darks, flats and dark flats will handle it. Dark 600 sec., gain 120. offset 30, -25 C, BIN 2:2
Adel Kildeev avatar
For comparison -dark from 1600 MM-Pro, 600 sec., gain 139, offset 21, -14C, BIN 1:1. ASI 1600 has less evident glow as a proven fact. You would need only darks  to eliminate it.
AstroDivers avatar
Mike Butorac:
I would freak too as first experience, to be honest
However, if you carry on the normal calibration steps of your lights matching appropriately darks/flats, you will have very nice results
Padraig Farrell avatar
A lot of people use unity gain of 120. According to zwo specs graphs there’s no great advantage in setting you cooling below -15’c. I use -10’c myself.
Use dark flats instead of bias seems to be the way to go also.
There’s a lot talk on forums about calibration frames with 294mc…
so try using 4 seconds for flats and dark flats. It’s worked fine for me.
I think it’s a great Astro cam, great for EAA also.
Enjoy
Adel Kildeev avatar
Padraig Farrell:
Enjoy
I would fully agree with your statements with the only correction: -20C is the point where noise is negligible. http://www.astrosurf.com/buil/asi294mm.html Excellent review
I must give that a go, thanks. 👍
Have you seen this video. ?
https://youtu.be/3RH93UvP358
Dr. Robin Glover from Sharpcap
Adel Kildeev avatar
Padraig Farrell:
Very informative, thanks! As a summary: in subarbian f6 needs 180 sec with NB filters, cooling temperature -15 C, more or less. Sounds reasonable and scientifically based. You can also read wounderfull site of Buil, he is one of the fathers of modern CCD cameras, a lot to learn from him. ZWO states that -20 C is the perfect temperature for 294, Buil tested on -15 C, but mentioned the -20 C equivalent (see above). I am thinking to start imaging with 294 with gain 120/offset 30, BIN 2 (BIN 1 sounds too good to be true, it is 12 bit afterword in comparison with 14 bit BIN 2) and exposition 300 sec. I saw many images with the same camera and 180 sec.exposition - they lack of contrast, IMHO. May be I will switch to 180, possible too.
Andy Wray avatar
Adel Kildeev:
On my ASI 1600MM at unity gain -10C in a suburban area on an F4.5 scope I'm using:
30secs for lum
90 secs for RGB
Anywhere between 180 secs and 300 secs for 7nm narrowband; looking at the subs ADU numbers I should theoretically go with 240 secs
Of course this all depends on the target and I may be tempted to keep Ha at 180secs and push SII and OIII to 300 secs.
No point in going any longer with my light pollution.
Here's to moving house to a darker sky location one day
Adel Kildeev avatar
I tried darks BIN 1:1 120 gain/30 offset 300 sec.- amp glow is barely visible, unlike BIN 2:2, very interesting 🤔
Adel Kildeev avatar
I really need to try BIN 1:1 with my f6 APO
Faint amp glow in an ASI2600MM Pro
Hi All I have recently made the switch to N.I.N.A. - and in that process also rebuilt my DARK library. When I looked over my new 300 sec. master dark made with N.I.N.A. I noticed a, what I believe is a very faint amp glow on the right-hand side of th...
Discusses master dark issues with dedicated astro camera; directly relevant to troubleshooting.
Oct 23, 2023
Power cable for astro-cameras
Hi, I bought my first dedicated astronomy camera (ZWO ASI533MC Pro) one month ago and I did two imaging sessions since then. I don't use the original ZWO power supply, but I use one from Amazon, which has a cable with an angled connector. I find ...
First-time dedicated astro camera user; relevant for setup and initial configuration help.
Aug 3, 2023
