Issues with Star Alignment using Chroma Filters
13 replies667 views
William Gottemoller avatar
We use 14 Chroma filters for my astrophotography; 7 are 36mm LRGBSHO, 7 are 50mm LRGBSHO. The narrowband filters are 5nm (SII and OIII) and 3nm (Ha). In this post, we present two issues occurring with two different telescopes, both of which have the same (everything but size) filters.
1) Narrowband Issues With Chroma SHO Filters (see equipment for more information) on C14 EdgeHD
I, along with @Tamas Kriska, have detected some odd separation issues that grow particularly pronounced between the SII and OIII filters. Essentially, the centroids are WAY off, with the red (SII) and blue (OIII) channels almost completely separated. See the pictures below:
Image 1: Melotte 15 stars
The very far right is a star on the SHO frame, which has a sharp, bright Ha star with more diffuse blue (OIII) and red (SII) glows in the background. The two combined issues made an image of Melotte 15, whose frames were truly exceptional, unsalvageable. For an example of this issue with Ha and OII, see:
Image 2: Horsehead Nebula in HOO
Horsehead Nebula (IC 434) and Reflection Nebula NGC 2023 in HOO
For the images above, we used this equipment:
  • Scope: Celestron 14" EdgeHD
  • Camera: ZWO ASI6200MM
  • Mount: Astro-Physics 1600GTO
  • Filters: 50mm Chroma LRGBSHO
    • SII: 5nm
    • OIII: 5nm
    • Ha: 3nm
  • Focuser: MoonLite CHL 2.5 inch
  • Reducer: Celestron .7x Reducer for C14
  • Software: SGP, TheSkyX, PHD2
  • Processing: PixInsight*, DeepSkyStacker^, Photoshop
* Image 1: all images registered, stacked, and aligned with PixInsight
^ Image 2: all images registered, stacked, and aligned with DeepSkyStacker
We have yet to image, stack, and align in RGB on the 14" Celestron EdgeHD, but an issue on another scope forebodes a similar issue on the 14".
NOTE: Images are binned 2x2, so the scale is about .56"/pixel, and the pixel size is 7.52 microns; seeing is about 1.5-2", so we assume that our atmosphere is not the issue (see below). We are probably not too oversampled either.
2) Broadband Issues With Chroma RGB Filters on Stellarvue SVQ100
I have collected dozens of hours of data since we installed the new camera, the ZWO ASI2600MM, on our 100mm refractor in October. When I imaged the Pleiades, I discovered that the stars in the RGB channels were completely off.
Image 3: Messier 45 RGB stars*
* Registering, aligning, and stacking done with DeepSkyStacker
Image 4: Messier 45 RGB Stars*
* Registering, aligning, and stacking done with PixInsight
For the images above, we used the following equipment:
  • Scope: Stellarvue SVQ100 f/5.8 Apochromatic Refractor
  • Camera: ZWO ASI2600MM
  • Mount: Astro-Physics 900GTO
  • Filters: 36mm Chroma LRGBSHO
    • SII: 5nm
    • OIII: 5nm
    • Ha: 3nm
  • Focuser: Starizona MicroTouch
The red and blue are virtually separate in Image 4; thus, even with two different telescopes, the red and blue channels are off. We likely can rule out processing, for we used two different applications to register, align, and stack the subs. The only consistent pieces of equipment between the two scopes are the Electronic Filter Wheel (ZWO), the OAG (ZWO), the cameras (from my knowledge, the 2600MM and 6200MM have the same specs outside of the sensor size), and the filters. We assume that the issue is the filters, for monochrome cameras should not have centroid issues like this, and the channel separation is consistent between both scopes, where red and blue are essentially mismatched. Tilt is probably not an issue, also.
Does anyone know what our issue could be? Has anyone had similar issues with their Chroma filters? We'd like to be able to take full advantage of our equipment!
Regards,
@William Gottemoller
David Nozadze avatar
Hello William,
Thank you for sharing this very curious problem. I don't know much about this yet, but let me still ask two very obvious questions:
1. Do you run autofocus on filter change? Or at least change the focus to respective preset?
2. Did you confirm, that you have precise backfocus distance from reducer/corrector?
David
Helpful Insightful Respectful
AstroDivers avatar
Hello,
I have Chroma NB filters.
Last week during my weekly exercise for the streaming of post processing I noticed weird artifact like the one in the right image.
After trials and error and modification on various process parameters, I've found that I don't have this issue if I deselect the check on the bottom of the SCNR process.
I have not pixinsight here and I won't before 2 weeks, but I am sure there is only one check mark.
Try to deselect it and run SCNR again.
I hope you can solve this as well. I have good hope because between the forth and the fifth  image the color change looks like SCNR was applied
AstroDivers:
Hello,
Noted. I do not have PixInsight, but I have contacted someone who does to see if he can resolve the issue with your proposed solution.
Bruce Donzanti avatar
Wow… Similar to you, I have been using Chroma filters (both narrowband and broadband) for about 3 years on my C11" EdgeHD and Stellarvue 80mm APO triplet with ASI 6200 and ASI2600 and have never seen either of these issues.  The only difference is that I do bin 1 and not bin 2.   So, unfortunately, I cannot help except to suggest that you contact Chroma Technology and ask them if others have reported this and if they have an explanation and solution for you.   I'd also be curious if others have had this issue as I have never heard of this until now.
John avatar
I have heard that with 3mm thick filters like Chroma, you need to add 1mm to your backfocus image train from the reducer or corrector. I'm still learning, so this may not apply or I didn't understand what I was reading in the article I picked up this information. But I add it here as a possible thing to check out and others to comment on.
Hope you find an answer soon.
Marc Dickinson avatar
I have this issue some and I don't have Chroma filters. Is the centroid separation in the stars the same from edge to edge?
Terri avatar
I too have gotten some of the 'pepsi' emblem stars, both in narrow band and broadband with Chroma filters.   I haven't figured out the why yet.     Astrosurface has a really nice channel alignment tool that I've used with some success.
Terri
psparkman avatar
While it could be an issue with the filters, it is very unlikely.  More likely is that this is the aberration of the Edge 14 at the corners when used with a full frame sensor.  Looking at the spot diagrams from Celestron's own white paper shows that the stars get pretty distorted at 20mm from the center which is close to the edge of a FF sensor.  Your corner stars look similar to the spot diagrams and will show color distortions accordingly when they are combined.
You are correct- you must add 1mm to get the correct backfocus.  However, I don't think that would have anything to do with what William is experiencing.
I agree that this is unlikely to be a filter issue.  I've used many brands on my C11" and now only Chroma and, like I said above, but I've never seen this effect using Chroma, Baader, Antlia, or Optolong filters.  The spot diagram for both the C11 and 14 are similar and I've seen a little bit of this issue at the corners with both an APS-C and FF sensors but not nearly as bad as displayed in the images shown.  However, what I just noticed in the original post that I missed previously was that the reducer is being used.  There is a history of this reducer causing problems with star colors, particularly in the periphery, which is why I ditched my reducer several years ago.  If Joh Hayes responds to this post, he can give his optical experiences with the C14.  Anyway, this is why I also think it is a scope design/setup issue and not a Chroma filter issue.
Terri avatar
I didn't realize this was only for SCTs.  I had issues with the pepsi symbol stars using an AP Stowaway and Chroma RGB.     But I did find out I had a bad filter, but to be clear I haven't necessarily correlated the bad filter to the star color issue.
Terri
skycamper avatar
Was this ever resolved?
Brian Puhl avatar
There is always some amount of distortion on the edges of images when the focal point changes (usually a refocus due to filter change)
I had the issue for a little bit… the solution was pretty simple.  Just turn on distortion correction in Star Alignment and re-align each frame.
Python script to generate target acquisition.csv file from image files in a format suitable for upload using AstroBin's upload csv dialogue
Update 28th October 2024 I have just released the latest version of the script. v1.3.11V1.3.11 changes 1.0 Fixes bug where running the script for the first time from the installation directory would fail 2.0 Deals with the case where the filter names...
Not relevant; script generation unrelated to filter optical issues.
Nov 23, 2023
Field curvature issues when merging data from 2 telescopes
Hello, This is my first real post and well it's kind of a doozy. I'm working on a project with a couple of other AP friends. We collectively gathered a bunch of data on M33. I gathered Ha and Oiii data and my friends did a bunch of time using...
Relevant; addresses merging data from multiple telescopes with potential optical problems.
Nov 1, 2023
Dual NB Imagery - Combining Blue and Green channel?
Hello, Despite not doing dual narrowband imagery with OSC anymore, I had recently a discussion with a friend on the ways to add the green and blue channel in order to get the full Oiii signal when shooting this way. I was shown some recent videos whe...
Relevant; discusses narrowband filter imagery and channel combination techniques.
Jun 13, 2023
FMA180 with focus issue
Hi all, I have some problems with focus with my FMA180. The focus is good for green and blue but red is complete out of focus. I have sent the FMA180 to my dealer and I got a new one for exchange. But the new one has the same issue and now the dealer...
Relevant; chromatic focus issues across wavelengths similar to filter separation problems.
Aug 28, 2023
