This forum is helping a lot ... Just starting to learn how to use Starnet
3 replies356 views
Andy Wray avatar
I'm learning a lot from all of you and just wanted to say thanks.  Below are two images of the Crescent nebula with the same relatively weak data.  The second one was where I used Starnet to take out the stars, boost the Crescent and the nebula and then add the stars back in.  I didn't realise how useful Starnet was until I came on here.
Quick and dirty Crescent
AstroDarkSky avatar
Nice! I also absolutely loved Starnet once I saw what it can do. If it continues to be a tool you use frequently, check out the 'fix' that lets you use your GPU to run Starnet several orders of magnitude faster (if you have an NVIDIA card).
https://darkskies.space/pixinsight-starnet-cuda/
Well Written Concise Engaging Supportive
Scott Badger avatar
I was having an issue with it leaving behind a lot of dim stars, but then read a tutorial that mentioned needing to reduce drizzled images back to original size before applying, which made a huge difference. Is this well known and I missed it along the way? Just DSLR data? Just my DSLR data?....
Scott
Dale Penkala avatar
Yes Starnet is a very powerful tool Andy! I love it as well! Its hard to believe this is a free program!
As @AstroDarkSky mentioned, there is that “fix” but if you don’t have that you can use “swap” folders and it will help out as well. Not a fast as the GPU, but it does help.
Keep up the good work!
Dale
[RCC] Heart nebula. First time looking for feedback!
So I've always been more of a lurker of forums than interacting, but I've enjoyed where the astrophotography journey has taken me and would love to know more about how to do more with my images and such. Going to do an info dump below on the ...
Shares nebula imaging feedback; similar post-processing and image enhancement discussion.
Oct 9, 2023
First light with new setup including Mono-Camera and ZWO AM5! Wow, what a difference!!
Hey all, This is my first forum contribution reporting my first light with a new rig I built. I just wanted to say hi and maybe have a conversation. First off, I started astrophotography about two years ago and I had a lot of fun since, so I decided ...
First light setup discussion; relevant to learning astrophotography techniques and community sharing.
Nov 30, 2023
My Return to Astrophotography - Alberta, Canada
Hey! I'm not actually that new to astrophotography, and got into this hobby back in February of 2023, and hell, I'd even say I got good within just a few months. I won't lie, it helped that the nearest Bortle 2-3 transition zone was a mer...
Return to astrophotography journey; similar learning progression and community engagement theme.
Nov 29, 2023
