William Optics RedCat 71 focuser blues.
9 replies495 views
Steen Knarberg avatar
I was very fortunate and got my hands on a WO RedCat 71 from Teleskop Service about a week ago.
But I am having second thoughts because of the focuser which is very tight, the tightest I have ever experienced on any "lens". Though I haven't been able to measure the force needed to turn the focus ring, I would estimate it to be  around half a kg. It is not a smooth movement when it moves.
Also the helical focus gear ratio is not sufficient  to make it easy to get precise focus. In fact it's very hard to get it spot on, because moving the focus ring just a quarter of a mm makes a huge difference.
​​​​​​Apart from the tight focus ring, there are also almost one mm of focus backlash. Turning the focus also moves the ring about a mm back and forth in the scope length direction. To me this seems as rather high tolerances considering this is a premium product.
I have ordered a ZWO EAF, but the tightness and the backlash makes me wonder if an EAF will be able to get precise focus at all.
Has anyone else bought the RedCat 71 and do you also experience what I do?
matthew.maclean avatar
On the Redcat-51, there is a ring just in front of the focuser that controls resistance and also locks it in place. Is that not present on the larger one?
Simon Pepper avatar
On the 71 the resistance ring is now colour coded so maybe blending in.
Thanks for your reply Matthew
I to had exactly the same thought and I have tried to turn the black ring in front of the wide rubber focus ring. Unfortunately it doen't seem as it's made for adjusting resistance, as I am not able to move it. Unfortunately there also was no user manual with the scope and I haven't been able to find one online.
Thanks Simon, could you please point out it's position, as I see no colour coded ring?
https://optcorp.com/collections/william-optics-telescopes/products/william-optics-redcat-71-apo-telescope-red
Die Launische Diva avatar
Steen Knarberg:
Maybe it is the ring above the "[H]" annotation in the last image of the page? Disclaimer: I don't own the telescope
SemiPro avatar
https://youtu.be/38HapX3MBLk?t=580
Here ya go. In a nutshell, you loosen the dew shield.
Simon Pepper avatar
Steen Knarberg:
https://optcorp.com/collections/william-optics-telescopes/products/william-optics-redcat pretty sure it’s the red teethed ring and the bottom of the dew shield. Check out astrobackyard on YT he has done a tutorial where I think he mentions it.
Thanks a lot SemiPro, you made my day 😊👍 How did you find this, I've been searching and searching?
It's beyond any sense why WO does not put a manual inside the case pointing this out.
Steen
Respectful Supportive
SemiPro avatar
Steen Knarberg:
Steen
I searched up the telescope in Youtube and found a video that showed how to focus the thing. More luck than anything else I suppose!
Small but mighty tuning for the EQ6-R. Change the pulley!
Hey everyone, I recently purchased the Skywatcher EQ6-R. It is the "latest" Version with the USB Interface. To be clear: My worst guiding sessions with this mount are comparable to my best guiding sessions with my previous mount (Exos-2). W...
Focuser tuning may address tight focus ring issues on optical equipment.
Aug 23, 2023
Skywatcher Quattro 250P astigmatism tip, maybe helpful to others?
I am posting this info because my google searches turned up very little specifically about the issue I was having with my scope and the solution. This is on my Skywatcher Quattro 250P, but certainly applies to other scopes. I was experiencing astigma...
Scope-specific troubleshooting tips could help resolve WO RedCat 71 focuser problems.
Dec 5, 2023
Edge HD 8, I'm having trouble with Collimation
EDIT, STARTED NEW POST WITH MORE INFO AND SCREENSHOTS, HERE: Screen shots of my specific Edge HD 8 Collimation issue - AstroBin ——- I've been doing astrophotography with smaller refractor scopes for a year, know the basics. Using Sky-...
Collimation issues may relate to focus precision difficulties on telescopes.
Sep 19, 2023
