Problem with NINA loosing pre set settings, and mount connection issues!
15 replies179 views
Mark C. Helton avatar
I have been a NINA user for quite some time, and very much like the program. I am not a software expert, and after a fairly long learning curve, I have been using this program pretty successfully. That was until last night. FYI, I am using the Beta versions. When I upgraded to the lasted edition, 3.2 a lot of my settings disappeared, and even when I try to go back an reset them, they seem to not stick. Some do, some don’t. I have a skywatcher wave 150i, which I was using with Green Swamp Server with good success. Now I can’t get GSS to connect the mount to NINA. GSS starts up in Simulation mode in NINA and won’t let me talk to the mount. I have gone back to using EQmod, which seems to work, but is not as user friendly as GSS. Has anyone else had this issue with loosing settings after an upgrade, or connection issues? Any thoughts will be greatly appreciated!
Thanks, and Clear Skies
Mark
Tom Marsala avatar
Oh no. I hope not, Mark. I just updated to 3.2 yesterday and haven't had a chance to try and connect yet. I hope others can chime in soon!
Tom
Tom Marsala avatar
What settings disappeared?
Tom Marsala · Nov 18, 2025 at 06:23 PM
I had to reset the camera and mount settings. Those went away. It was not talking to GSS but I seem to have figured that out. That seems to have been a comm issue with Windows. However I had not done anything for the computer to change those comm settings. My rotator is not connecting again, but focuser, filter wheel, camera, and PHD are. It seems like the main window went back to a default setting, and didn't save the way I had it set up. Again, maybe I did something wrong, but I don’t think I did!!
First, one should always save their own setup/options as precautionary measure, as major updates may disrupt the windows layout. Secondly, I just installed the update on two different PCs and nothing of that sort happened. Thirdly, COM ports assignments are somewhat variable depending on the OS you're using so any ASCOM drivers that relies on a fixed COM port assignment may going to draw a blank upon connection at first. Best way around this issues is to connect to each device one at the time and note down what COM port is assigned to it. If you are using native drivers then this shouldn't happen.
Tom Marsala avatar
Very interesting. My window dock settings remained. One thing I did notice was that the camera connect is now anticipating my camera (it lists it as not connected) whereas on 3.1 I had to search for the camera each sequence run. I'll have to try and connect to everything else to see. Keep us posted.
Tom
SonnyE avatar
Hi Marc,
You may just have to work inside of NINA and help it re-find your equipment.
I sometimes have to do that with my focuser, for example.
Also, you might find Cuiv’s NINA videos helpful. I sure did a few years ago when I went remote (75 feet 😅) with my equipment. Now I get it going and wake up to a pile of files.
Also, I kind of shy away from updates, at least until they’ve matured a bit. Buggy updates will drive you crazy.
andrea tasselli · Nov 18, 2025 at 07:21 PM
Thank you. I am not totally aware of all of the settings spots in NINA yet, and how to save them, but will research that. Appreciate your comments!
Mark
Daemon de Chaeney avatar
Is there a way in NINA to save all your settings &c, in one file that can be reloaded? How is this done?
Bottom Right
Thanks Andrea, does that include the various settings or just the layout?
Whatever is in the layout. You load the right profile with the settings for the gear you're using at start-up.
Although NINA did change some of my settings, and yes, I should have tried to save them before the update, I think that the main problem might be a comm port problem with windows. This is also a very frustrating problem that I have had with windows before. It does not seem to be assigning a comm port to my mount, and I can’t seem to create one no matter what I do. I know this leads to a totally different topic. I will learn to be more careful in saving my settings in NINA before I upgrade. I am a Mac users, and really wish that NINA ran on a Mac! I love the program, and so I am having to learn how to tolerate MS again, which I gave up years ago. Mac is not perfect, but it is a lot more user friendly. Thank you for all of your thoughts and comments.
Respectful
One last comment. Windows has a bad habit of upgrading to whatever the latest version of their OS, in the case 11, is, without asking. I have a funny feeling that that upgrade has created issues with my comm ports problems. I really like NINA, and I now do not think that NINA is the issue anymore. For a ”free”, software, it is amazing. But the platform it is running on, the MS OS, leaves little to desire. Clear skies
Tom Marsala avatar
I have been pausing Windows update for five weeks at a time, then updating during non imaging times - gives me more control.
Tom
SonnyE avatar
Mark C. Helton · Nov 19, 2025, 01:24 AM
Windows does NOT like anything that does not come from the Windows Store.
I’ve had their updates blow holes in my drivers often. It’s their little tantrum against our Astronomy programs.
Like others, I try to stay ahead of them blocking their incessant updates. I bought the computer, and the software, so I own it. I did not give Windows permission to invade my computer with their buggy updates. And most certainly not to damage my software.
did anyone meet the same problem when connect LX85 with nina
how to solve this problem.I have already reinstall the ASCOM Platform and the driver of Meade,but didn't work.Please help me.
Addresses mount connection issues and driver/settings problems like yours.
Jan 31, 2025
M-Tre with encoders
Hello folks Anyone has the Avalon M-Tre with encoders can report on any issues, successes, failures..? Thanks
Mount connection problems with control software; directly relevant troubleshooting experience.
Jan 30, 2025
Migration from NINA
Hello everyone! I'm considering migrating from NINA to Astroberry so that I can keep the pc at home and connect remotely while staying warm to check that everything is ok during the session. Right now my very basic setup consists of : - Star Adve...
Author migrating from NINA; connection issues relevant to their transition.
Dec 30, 2023
Mount limits on GS server
Hi,my name Is Valerio, i wanted to automate more my setup, i installed nina and GS server, i tried doing the meridian flip, i setted 0 minutes After the meridian, started the sequence and First thing nina did was the meridian flip, even if the target...
NINA mount connection issues relevant to author's automation setup problems.
Apr 6, 2025
My Problem with PhD2
I've never been able to get PhD2 to work as it should. I know that it's me, not the program. For background, my setup is an MtY, TSX, N.I.N.A. and an Esprit 120mm. I've had reasonable success simply using the above equipment for up to thr...
NINA connection issues may relate to author's calibration failure problem.
Jun 19, 2025
