Guiding Issue
22 replies384 views
Ari Paulechen Junior avatar
Recently I disassembled my HEQ5 for lubrication and bearing replacement.
However, after putting it back into operation, the guiding is not behaving as it should.
Without guiding, in 120-second frames, about one out of every five shows a star trail.
But with guiding, all frames show trailing.
Could something be mechanically too tight or too loose, or could it be a software issue?
Here are two comparison images — one with guiding and one without. In the PHD2 graph, there are no spikes that would justify the star trail.
The trail is perfectly aligned with the movement of the RA axis.
Has anyone ever experienced something similar?
I’ve already tried various settings, both mechanically and in PHD2.
Thank you very much!
Well written Engaging
Brian Puhl avatar
Without knowing your guiding setup, this smells like a flexure issue between the guide scope and OTA.
It would help us figure things out a bit better if we saw a photo of your setup, at least a little more details on what you’re using to guide with.
Well written Insightful Respectful Concise Supportive
Alex Nicholas avatar
Without knowing any details at all - this sounds like either Flexture as Brian said, or you need to re-do your calibration…
Though, given you say that the PHD2 guide graph shows no movement - I’d say Brian will be correct - this will be flexture somewhere in the system.
Guide scope/Camera wobbling, imaging camera moving in the focuser or imaging scope focuser has some slop in it… something to that effect… Make sure everything is bolted down/tensioned tightly…
Jim Raskett avatar
Hi Ari,
How did the mount perform before the rebuild?
Post rebuild, what did the PHD2 calibration graph look like?
Did you change anything in the guiding setup?
Well written
Brian Puhl · Nov 12, 2025, 04:25 AM
📷 Imagem do WhatsApp de 2025-11-12 à(s) 08.33.08_f7f55671.jpgImagem do WhatsApp de 2025-11-12 à(s) 08.33.08_f7f55671.jpg📷 Imagem do WhatsApp de 2025-11-12 à(s) 08.33.20_40e1ae7a.jpgImagem do WhatsApp de 2025-11-12 à(s) 08.33.20_40e1ae7a.jpg📷 Imagem do WhatsApp de 2025-11-12 à(s) 08.33.45_2e608da7.jpgImagem do WhatsApp de 2025-11-12 à(s) 08.33.45_2e608da7.jpg
guiding details:
60 f4, FL 240mm
asi 220mm +uv ir cut.
I went to double check the guide scope again and noticed that one of the screws holding the dovetail to the shoe was a bit loose... (It wasn’t completely loose, but maybe just enough to cause the problem).
When I have clear skies to test, I’ll come back here with the results. I’ve also left a few more images in case they help identify the problem.
Alex Nicholas · Nov 12, 2025, 05:24 AM
📷 image.pngimage.pngI recalibrated several times. Some turned out better than others, but none of them seem to fix the problem.
It might be caused by a slightly loose screw I found, which I described in the comment above.
Jim Raskett · Nov 12, 2025, 10:56 AM
Hi Ari,
It was showing some guiding spikes, and I noticed the grease wasn’t great, so I decided to take it apart. It wasn’t performing perfectly before, but it was definitely better than it is now with guiding.
What confuses me is that it’s producing good frames without guiding (something it didn’t do before) and bad ones with guiding hahaha. If it were the other way around, I’d understand!
Jim Raskett avatar
Looking at the calibration graph, to me it looks like there was a bunch of backlash in DEC???
with the amount in the home position and the clutches locked, can you move the vertical rod shaft and see any movement?
have you run the PhD2 guiding assistant and checked DECbacklash?
If it isn't the guide scope (which incidentally is poorly mounted) then it is well possible that the primary mirror is shifting. Mine used to do that in summer, not all positions obviously.
Jim Raskett · Nov 12, 2025, 12:51 PM
You are right. That was one of the issues I was expecting to solve with the hypertune hehehe.
Jim Raskett avatar
Ari Paulechen Junior:
How did the worm adjustment go post rebuild?
Were you able to adjust the worms where there was no obvious physical movement when moving the axis back and forth with your hands while not binding the worm?
The reason I am asking is because when I rebuilt mine, I could not adjust enough to eliminate the axis play before the worm started to bind. At best, there was noticeable play in DEC.
I disassembled the mount again and started from scratch. This time, the DEC axis worm adjusted perfectly. There was no obvious play in the axis and the worm moved easily when turning the gear by hand.
The mount has been running great since.
Jim Raskett · Nov 12, 2025, 06:26 PM
My case seems very similar to your description. Even after adjusting to the binding point, there's still play when moving the DEC axis. This play already existed before and continues now, even after replacing the bearings. When you disassembled it the second time, do you remember doing anything different? (It's a problem I want to solve, but first I need to look into the RA issue.)
Well written
Jim Raskett avatar
My apologies for my faulty memory, but it was the RA axis that had play.
Unfortunately, I didn’t see anything upon disassembly but after re-assembly, the worm axis adjusted easily and there was no apparent play in the axis.
Sorry for the confusion!
Well written Respectful
Paul Macias avatar
Whenever I would get something like this, it was almost always some sort of flexure from the guide scope. The rings might not be tightened down enough, the shoe might not be tight enough, etc.
Did tightening the screw fix your issue?
Well written Concise
Paul Macias · Nov 13, 2025, 06:26 AM
I dont know yet, we are in the rain season here… maybe next week some clear skies show up
Update: The “loose” guider wasn’t actually the problem.
I took more frames, both with and without guiding, and I found that there’s really no pattern, sometimes guiding is bad, sometimes unguided is bad.
When I reassembled the mount, I noticed that unlike in the video I followed where after releasing the RA axis the mount would make 3 or 4 full turns when a torque was applied to the counterweight shaft (with no counterweights), mine was only making about 1/3 to 1/2 turn.
I decided to open it again and put the old bearings back in. Now I’m getting a little over one full turn.
I’ll try using it like this over the next few days, and if I still don’t have success, I’ll open the bearings and remove all the original grease. (I suspect there’s an excess of factory grease, which for our application ends up dragging the axis.) What do you think?
Tim Ray avatar
Did you shim the mounting when reassembling. I mean that shims are required on each shaft. The shims provide the exact spacing for the worm alignment to the respective axis gear. Without, the worm might not seat or mesh correctly causing backlash during operation and adjustment…
Tim Ray · Nov 16, 2025, 03:26 PM
📷 Imagem do WhatsApp de 2025-11-10 à(s) 09.41.14_086d22f2.jpgImagem do WhatsApp de 2025-11-10 à(s) 09.41.14_086d22f2.jpgWould it be this red washer like in the image? If so, when I disassembled mine it didn’t have one on either axis. Since it’s a second-hand mount, maybe the previous owner lost it.
Tim Ray avatar
Yes, Since you can only adjust the worm basically in and out towards the main gear, you have no adjustment on the height of the worm to get it to seat properly with the main gear. That shim moves the main gear instead to make that adjustment… I hope that makes sense… Tim
Tim Ray avatar
There are many videos on YouTube about reassembly of these mountings. An Atlas or EQ6 video would work as well. Look for how to measure for that shim. You need a micrometer (analog or digital, nothing fancy) and a little math. I might have a few extras. I redid my Sirius mounting several years ago and might have a few shims left of various thicknesses I could send you.
Tim Ray · Nov 16, 2025, 03:37 PM
Thank you for your help and willingness, but I live in South America hahaha. I’ll see if I can find something here that works for this purpose.
But I noticed that this washer is located after the main gear and the worm. It seems to serve to keep the two bearings from making contact with each other.
In your case, the washer would go here so that both the center of the worm shaft and the main gear shaft line up in height (green line). This makes it necessary to add a washer (in red) to raise the ring gear relative to the worm and keep them aligned on the same axis.📷 image.pngimage.png
Tim Ray avatar
If I remember I reassembled without a shim. then measured the distance from the center of the teeth on the main gear to the surface the worm gear housing mounts on. Then disassemble. Add shims to the front of gear (like your image) to raise it to match the same distance as the worm is to that housing surface. Reassemble and the two gears should line up. then adjust worm in and out as not to bind…
Jim Raskett avatar
I found these pictures of my HEQ5 Pro back when I disassembled the RA axis.
You can see the position of the red shim washer in relation to the RA worm wheel.
ONTC Tube Foam Sandwich Compression and Solution
I’ve been using a 10” TS Optics ONTC Newtonian as my primary imaging scope for a few years now. Overall it’s a great scope and I’ve been very pleased with its performance. It is, however, not without some issues. One issue which has plagued me from d...
Scope type irrelevant; post concerns mount guiding issues, not telescope.
Oct 22, 2025
PHD2 issue or hardware?
Hello all. I have an issue that arises every so often. It happened last night about 3:00 a.m., PHD2 lost pulse guiding to my mount. PHD continued to run and show the guiding graph but no corrective pulses were sent to the mount. I had to restart PHD2...
Guiding malfunction diagnosis after equipment changes; relevant troubleshooting approach.
Oct 6, 2024
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Meridian flip rotation shifts differ from post's guiding trailing problem.
Oct 28, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration causes star trailing; relevant mechanical issue to investigate.
Nov 18, 2025
