Another useful ChatGPT use: Compute RA and DEC offset for a comet image
3 replies154 views
Sean Boon avatar
With the short window we have for Comet C/2025 A6 Lemmon right now, I don’t have time to fiddle with trying to frame the comet in such a way that the comet nucleus is on the corner and the tail runs diagonally across the frame so I can get as much comet tail as possible. Usually I would use orbitals plug in or go into framing and work to reset it manually. Not anymore. Maybe you all have a better way to do this already, but I just tried to see if Chat GPT could compute the RA and DEC offset for me based on my set up and sure enough it did. I was able to even tell it to give me a 8% buffer so it wouldn’t just be smack dab in the corner. At any rate, just thought I’d share another use case for it that just saved me a ton of time.
A ton of time? Really? It takes me maybe 2 minutes to get the right framing on my planetarium…
Kevin Morefield avatar
That’s a cool idea Sean! It’s interesting figuring out what the AIs are good at and not good at.
Thomas avatar
I use SkySafari on my phone. It already has my fov and rotation angle put in so all I have to do is frame it up how I want and copy the coordinates. Has been so bang on accurate that I pre-programed coordinates for an imaging run at like 5am at my remote observatory and the comet was perfectly framed how I wanted when I checked my images after waking up.
Finding the Dolphin Head RA and Dec Center to export to NINA
I am trying to frame the Dolphin Head Nebula. I am not able to see how to frame it in Telescopious or NINA. I see the bright star but no outline of the nebula. I have an Askar 500 so will have a 500mm FOV. Any suggestions on rotation and coordinates....
Computing RA/DEC coordinates for deep-sky objects similar to author's need.
Dec 25, 2023
GPT5 minimalist work flow in PixInsight.
I asked GPT 5 for a minimalist workflow to process a dual narrowband OSC image in PixInsight. I asked it to consider all the freely available 3rd party plug ins as well native PI processes and to recommend the best process for each step. I constraine...
Author used ChatGPT for astronomy calculations; similar AI workflow discussion relevant.
Sep 10, 2025
Want to image NASA's Orion Spacecraft During Artemis II?
Artemis II could launch as early as 1-April; sending humans back around the moon for the first time since Apollo. During this mission the Orion spacecraft will perform an extra orbit around earth to allow time for systems checkouts as well as a docki...
Computing RA/DEC offsets relevant to tracking spacecraft trajectory data.
14 days ago
